Airforce RC Squadron
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Indoor & Micro RC Flight >> Airforce RC Squadron
Page: [1]
Login
Airforce RC Squadron - 9/3/2008 3:25:15 PM
Wheelnut
Status: offline
I found this at Raidentech under their mini rc airplanes. When I first saw it I thought how cool that must be. I remember when all we had was wind up rubber band and free throw balsa planes. I can remember thinking how cool it would be to attach some flight gear to it and control it from a transmitter. Back then the only other thing I knew of was the control line planes and I just didn't want one of those. Well here it is, someone made my childhood dream come true.
These little planes are the closest I have seen to the old balsa wood free throw airplanes with electronics attached so you can control it. I am sorry I didn't get pictures before I put them together. Out of the box, it took me about 15 minutes to put them together and about 20 minutes to charge the battery. The $19.00 kit comes with 2 planes (one fighter plane and one Bi-plane) and one set of electronics and one controller. The esc/receiver is wired to the two motors. All you do is snap the esc/receiver into plane, then as you can see in the pictures, the planes have plastic mounting slots in the wings for the motors. The motors are in-cased in a plastic housing that has mounting hardware. All you do is slip the motor in the mount and twist it into place. It stays there very nicely. This is also creates a very new and cool way to trim the flight. If it is turning one way you just twist/adjust one motor or the other to be a little off center to push the plane straight.
These planes fly very well. I wish they had two frequencies so my son and I could fly at the same time. These would be great for dog fights.
The only thing I found is that the foam is a little weak and when you crash the nose gets bent. I knew that over time it would get worse and the plane probably wouldn't fly very well. This was an easy fix. In the pictures you can see where I glued some carbon fiber flat rods to reinforce the plane. It is very stiff now and the problem is gone.
I would recommend these to anyone looking for some fun in the backyard.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Fly Like an Eagle
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU2
