Spektrum 6 DXi not binding
Tower Hobbies
Logged in as Guest
  Printable Version
Hitec HS-5965 MG Brand new untouched - RTF
Seller:  kmac425
Details:   $70.00   |  11/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Spektrum 6 DXi not binding
Page: [1]
Login
Spektrum 6 DXi not binding - 9/6/2008 1:27:16 PM
vasek
Status: offline
I have a AR6200 that i had in a plane and had a "bind" with the Tx.
I put the Rx in another plane and want to re-bind it to a different name in the same Tx.
The second plane flew before with 75mhz so there's only a TWO wire switch installed. So i plugged the Bind Plug into an open channel in to the Rx; turned the Rx ON but in blinked just once... no blinking as required to begin the binding process.(?)
The Rx still works under the first model and doesn't want to bind to the second one.
Plugging the Bind Plug directly into an open channel works for the AR6100 so it should work for the AR6200 right?
What am I doing wrong?
< Message edited by vasek -- 9/6/2008 1:35:22 PM >
_____________________________
I am a proud Canadian >living in Europe;-)
       Post #: 1
RE: Spektrum 6 DXi not binding - 9/6/2008 1:52:34 PM
BarracudaHockey
Status: offline
The bind plug will only do anything when plugged into the BIND/BAT port on any of the spektrum recievers.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to vasek)
       Post #: 2
RE: Spektrum 6 DXi not binding - 9/6/2008 2:23:45 PM
vasek
Status: offline
Thanks BH for the prompt reply.
I switched the battery lead with the bind plug & it works like a charm!
cheers, V.
(in reply to BarracudaHockey)
       Post #: 3
RE: Spektrum 6 DXi not binding - 9/6/2008 3:22:42 PM
BarracudaHockey
Status: offline
Cool. Happy flying.
(in reply to vasek)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.232RCU3
