RE: Tamiya Jagdpanther IR Unrealistic shots    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: Tamiya Jagdpanther IR Unrealistic shots
Page: <<   < prev  1 [2]
Login
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/7/2008 8:25 AM
ksoc
Score: 100
Last Login: 5/23/2013
Status: offline
The IR emitters are a mass produced commodity product, NOT high tech or high precession. Most are probably used in remote controls where a wide spread would be a plus. We had one club member who's tank would work great on the bench, and died in battle. Turns out his IR emitter did work at ranges over 5 or 10 feet! Even if you install everything perfectly, the emitter could be bad. That SEAD page also list the Radio Shack info on replacement emitters, and TANKHOBBY.com sells some small target circuits that clip onto the top of a 9V battery. A couple of these can help you test things in a hurry.
If you don't have a second TBU, you could try setting your tank into "TEST MODE". That lets you shoot yourself. Then with a white piece of paper or mirror you can test your system.
As far as using them in battle, I haven't seen anyone use a laser pointer or camera system. Mostly 'dead reckoning' aiming. Our old battlefield was set up to discourage 40' shots. Since we often have 8 vs 8, one sniper could lock down a big chunk of the battlefield. Those IR sensor don't have IFF
_____________________________
Kevin O''C <S.C.A.T> www.socalareatankers.com•Tamiya-Sherman/Tiger/Pershing/Pnzr IV/Kubelwagen•HL-Tiger, Pnzr IIIâ
Hide Signatures
(in reply to dyeager535)
       Post #: 26
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/7/2008 1:33 PM
Matdragon
Score: 100
Last Login: 1/2/2012
Status: offline
ok, thanks guys, i was just worried their may be something wrong with my tank. so from what ive collected, the IR beam is bouncing around in the tube and coming out of the barrel as a spray??
thanks,
Matt
HL Tiger non S+S, HL Bulldog S+S + IR, Tamiya Jagdpanther FO + IR.
Hide Signatures
(in reply to ksoc)
       Post #: 27
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/7/2008 6:03 PM
darkith
Score: 101
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: dyeager535
I would have assumed any sort of light emission short of a laser to spread out in a fairly predictable cone pattern until so dispersed as to be unmeasurable, instead of "refocusing" as the Tiger apparently did in the diagram, but I'm no electronics whiz.
Predictable, yes. Evenly distributed, no. Most LEDs have a hotspot in the middle, some bigger than others. So, a hotspot down the middle can have longer range before it is attenuated and/or disperses below detectable levels.
If you have an LED flashlight, try shining it at a wall and moving it backwards and forwards, you should be able to see some fading and sometimes a hot spot in the middle.
D.
RCU Required Disclosure: Manufacturer of DBC battle circuit for Heng Long tanks.
Hide Signatures
       Post #: 28
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/8/2008 1:48 AM
Matdragon
Score: 100
Status: offline
thanks, i have the LED in its case now and all seems fine! will do tests tommorow after school!
thanks,
Matt
Hide Signatures
(in reply to darkith)
       Post #: 29
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 1:52 AM
James S.
Score: 100
Last Login: 12/13/2008
Status: offline
The Crown of the IR LED should be at least 9mm from the end of a 6mm inside diameter tube. Also be sure to paint the or cover the backend of the IR LED so you don't have "leakage" out the side of the mantlet. I built a jadgpather and put the IR LED In the mantlet works great here is a link to a photo
jadgpanther
Hide Signatures
(in reply to Matdragon)
       Post #: 30
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 2:11 AM
Matdragon
Score: 100
Status: offline
thanks,everything is sorted out now.
cheers,
Matt
CASE CLOSED. (lol ive always wanted to say that )
Hide Signatures
(in reply to James S.)
       Post #: 31
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 2:32 AM
Jeff489
Score: 105
Status: offline
I think your IR beam is diffusing because the beam is ricocheting inside the shiny aluminum barrel. You might try an experiment by installing the emitter in a test rig such as a piece of scrap tubing (same diameter as the emitter) with the inside of the tube painted flat black. It should yield a tighter beam.
Hide Signatures
       Post #: 32
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 2:35 AM
Jeff489
Score: 105
Status: offline
OOPS! I didn't see that the case was closed. Glad you got it sorted.
Hide Signatures
(in reply to Jeff489)
       Post #: 33
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 4:25 AM
Panther F
Score: 135
Status: offline
Yep ... the case is closed to the Tamiya Jagdpanther IR Unrealistic claim.
Hide Signatures
       Post #: 34
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 7:20 PM
Matdragon
Score: 100
Status: offline
thanks for that panther F
Hide Signatures
(in reply to Panther F)
       Post #: 35
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 7:35 PM
Panther F
Score: 135
Status: offline
quote:
ORIGINAL: Matdragon
You're most welcome lad!
Hide Signatures
       Post #: 36
RE: Tamiya Jagdpanther IR Unrealistic shots - 9/9/2008 8:20 PM
googlydoogly
Score: 110
Last Login: 5/29/2012
Status: offline
And you didn't even need the Hardly Boys for this mystery.
Hide Signatures
       Post #: 37
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
