opjose
MD, USA Status: offline
The FX .46 produces less power than say an AX .46, and they are a bit smaller too. Since you already have the engines, just make sure that you can get them maxing out at about the same RPM's then put them on the plane... As far as weight, put an extension on your battery pack and move it back in the fuselage, behind the canopy - IF - you have to, to balance the plane. I'll bet you will not have to move the battery too much to achive the recommended C.G.
_____________________________
- Build em'', fly em'', crash em'' and build more.
