RE: Shark XV Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Shark XV Build Thread Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Shark XV Build Thread - 9/24/2008 12:10:51 AM
franklin_m
Status: offline
Dave,
As the proud pilot of one of the smaller Shark's, this bigger brother is a really beautiful airplane. One the smaller one, I finally got the bugs worked out of my BigMig 0.049...now getting 19,000 RPM out of it with a Cox rubber duckie prop! It just sings.
On a related note, my 0.049 version is unthrottled, and I found a trick for making hand launches a bit easier. I trim the airplane for a steady but defined climb off the handlaunch. However, as the readers will know, were I to leave it this way, the plane will want to climb dramatically as it picks up speed. Rather than re-trim, I programmed in nose down pitch trim with increasing throttle. That way, my left stick becomes a separate trim slider. The nice thing is that when the power quits, all I do is pull the left stick back to idle, taking out the mixed elevator, and I'm trimmed pretty nicely for landing.
Can't wait to buy a couple S-XV kits....
Frank
(in reply to rainedave)
       Post #: 26
RE: Shark XV Build Thread - 9/24/2008 1:36:18 AM
rainedave
Status: offline
Frank, brilliant!!! I love that idea and I'm going to give it a try. Glad you like the S-XV.
My Solartex arrived today, so no excuses for not finishing up the project.
I might build a second one for this little gem. HB .15:
David
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by rainedave -- 9/24/2008 1:37:42 AM >
(in reply to franklin_m)
       Post #: 27
RE: Shark XV Build Thread - 9/24/2008 4:19:05 AM
SGC
Status: offline
Dam Dave,
I've got a couple of Enya 15's and 19's looking for homes too, so I guess my son and I will need a couple of the SS XV's too.
Stewart
       Post #: 28
RE: Shark XV Build Thread - 9/25/2008 1:11:52 AM
iflyg450
Status: online
MUST HAVE ONE! Would an OS 25 VF-DF engine be to much????
(in reply to SGC)
       Post #: 29
RE: Shark XV Build Thread - 9/30/2008 5:35:05 PM
rainedave
Status: offline
I think a hot .25 is too much. I designed it to be just strong enough with a .15, yet still as light as possible.
The wing and tail are covered.
David
Click for fullsize
(in reply to iflyg450)
       Post #: 30
RE: Shark XV Build Thread - 9/30/2008 6:08:49 PM
planebuilder66
Status: offline
Silkspan and dope or koverall? Or is it something else?
       Post #: 31
RE: Shark XV Build Thread - 9/30/2008 8:18:51 PM
exocet-RCU
Status: offline
This is the translucent Solartex, right? Is Solartex the same as Coverite 21st Century iron-on fabric? My LHS has some of that but I have never used it before. Who did you order the Solartex from?
edited: Also, while I'm at it, what is Micafilm, made by Coverite? Anyone used it before and with what results?
Tim
< Message edited by exocet-RCU -- 9/30/2008 8:22:22 PM >
(in reply to planebuilder66)
       Post #: 32
RE: Shark XV Build Thread - 10/1/2008 12:27:30 AM
Mr67Stang
Status: offline
Put me down for one
_____________________________
He who dies with the most toys wins!
       Post #: 33
RE: Shark XV Build Thread - 10/1/2008 12:51:44 AM
BSARGE
Status: offline
quote:
ORIGINAL: exocet-RCU
Tim
I have ordered it from Balsa Usa before.....it's good stuff....very easy to work with!
-Bill
(in reply to exocet-RCU)
       Post #: 34
RE: Shark XV Build Thread - 10/1/2008 5:38:03 AM
rainedave
Status: offline
Yep, it's translucent Solartex (they call them Vintage colors). They make opaque colors, too, but they're slightly heavier. And as Bill mentioned, I got it from BUSA.
https://www.balsastore.com/store/proddetail.php?prod=Solartex_2_Vintage_Meter_rolls
David
(in reply to BSARGE)
       Post #: 35
RE: Shark XV Build Thread - 10/3/2008 5:56:51 PM
rainedave
Status: offline
It looks like I'll have it ready to fly tomorrow. I've installed the servos and push rods. I'm using a Futaba 250mah square pack. The plane balances dead on the main spar which is the 33% point. It weighs 24ozs without the bottom hatch over the servos.
By putting the servos behind the wing I was able to get short and straight push rod runs. No slop or flexing.
David
Click for fullsize
Click for fullsize
< Message edited by rainedave -- 10/4/2008 5:44:03 AM >
       Post #: 36
RE: Shark XV Build Thread - 10/4/2008 5:41:39 AM
rainedave
Status: offline
More pics...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rainedave -- 10/4/2008 5:49:13 AM >
       Post #: 37
RE: Shark XV Build Thread - 10/4/2008 5:52:12 AM
combatpigg
Status: online
RD, she looks fantastic! Looks like it would lap a Doubler at least twice in a heat.
Led Zeppelin is NOT "old fogie" music.
       Post #: 38
RE: Shark XV Build Thread - 10/4/2008 6:07:26 AM
rainedave
Status: offline
Thanks cp! I went with a lighter NiMH pack and lost a little over an ounce. With my building methods it would be hard for me to do much better than this weight (23.8ozs).
I might build one without the rudder servo, no landing gear, use contest balsa and my Norvel .074 and I could maybe get under 20ozs. But, we'll see tomorrow how this one flies.
David
Click for fullsize
< Message edited by rainedave -- 10/4/2008 6:11:15 AM >
(in reply to combatpigg)
       Post #: 39
RE: Shark XV Build Thread - 10/4/2008 6:14:17 AM
fizzwater2
Status: offline
Dave, if you ever do stick your HB 15 in it, let us know how it does. I have a NIB HB15 that ought to have a proper home some day..
no matter where you go, there you are..
