Finally Ordered a 75cc
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> Finally Ordered a 75cc
Page: [1] 2 3 4   next >   >>
Login
Finally Ordered a 75cc - 9/14/2008 8:52 PM
Lins
Score: 100
Last Login: 11/1/2009
Status: offline
Well, I finally did it, I ordered up the 75cc Extra 260. Not from Aero Works directly, but through the (somewhat) local hobby shop. I've been humming and ha-ing about it for a while now. I've had the ZDZ Super-80 sitting in a box for almost a year waiting for a plane to show up and I figured the best way to tidy it up off the shelf was to mount it to something . It likely won't fly until spring though, as it will be getting very cold here quickly. That's ok, I think I prefer the building part over the flying (even if it is an ARF). I have most, if not all, the servos for it already, just need the battery setup and spinner pretty much. Once I maiden it I will be looking at a 100cc size likely next with the possibility of a turbo-prop .
Hide Signatures
       Post #: 1
RE: Finally Ordered a 75cc - 9/14/2008 11:58 PM
zzw26n
Score: 100
Last Login: 10/24/2009
Status: offline
With the QB Series, you'll have it assembled in 10-12 Hours. Mine has served me well and I'm very impressed with Aeroworks.
Hide Signatures
(in reply to Lins)
       Post #: 2
RE: Finally Ordered a 75cc - 9/15/2008 12:11 AM
Lins
Score: 100
Status: offline
Well, I likely won't see the plane for a few weeks, and by then it will be around freezing, and I will also be in the middle of moving!
Hide Signatures
(in reply to zzw26n)
       Post #: 3
RE: Finally Ordered a 75cc - 9/15/2008 1:26 AM
Lins
Score: 100
Status: offline
Does anybody who has installed a ZDZ Super 80 in one of these have any pointers?! How did it balance? Thanks!
Hide Signatures
(in reply to Lins)
       Post #: 4
RE: Finally Ordered a 75cc - 9/15/2008 11:42 PM
gregman50
Score: 100
Last Login: 11/7/2009
Status: offline
I don't have the Extra but I do have the 75cc Yak with the ZDZ Super 80 and it's a rocket! I had no problem with the balance so I would think you will be fine also. The QB series planes are some of the best out there.
Hide Signatures
(in reply to Lins)
       Post #: 5
RE: Finally Ordered a 75cc - 9/16/2008 12:20 AM
juanes1969
Score: 100
Last Login: 10/28/2009
Status: offline
I have one with the 80RV, not the super but weights almost the same. You can install everything where the manual states and just play around with the batteries to find the perfect CG.
It´s a rocket with the rv, the super will be monster power for this plane!!
_____________________________
Just fly it!!
Hide Signatures
(in reply to gregman50)
       Post #: 6
RE: Finally Ordered a 75cc - 9/16/2008 12:42 AM
Lins
Score: 100
Status: offline
Do you guys have pics of the install? What spinners did you use, metal or carbon fibre? Thanks!
Hide Signatures
(in reply to juanes1969)
       Post #: 7
RE: Finally Ordered a 75cc - 9/16/2008 4:12 AM
rodney tanner
Score: 100
Status: offline
Juanes - I am planning to buy the 75cc for an 80RV I have. I am planning on using a JBM header and cannister. Do you have any idea of the drop required for the header?
Many thanks.
Rodney
Hide Signatures
(in reply to Lins)
       Post #: 8
RE: Finally Ordered a 75cc - 9/25/2008 12:34 AM
Lins
Score: 100
Status: offline
Well, I have received the wings and cowl so far, just waiting for the fuselage box and everything else. Hopefully it arrives in the next day or two, before the weekend.
Click to see fullsize image.
Click for fullsize
< Message edited by Lins -- 9/25/2008 1:26 AM >
Hide Signatures
(in reply to rodney tanner)
       Post #: 9
RE: Finally Ordered a 75cc - 9/26/2008 2:17 AM
Lins
Score: 100
Status: offline
Fuselage showed up today! Too bad I can't do much with it until I move into my new house next week
Click for fullsize
Click for fullsize
< Message edited by Lins -- 9/26/2008 2:20 AM >
Hide Signatures
(in reply to Lins)
       Post #: 10
RE: Finally Ordered a 75cc - 9/26/2008 5:31 AM
Lins
Score: 100
Status: offline
A little size comparison!
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Lins)
       Post #: 11
RE: Finally Ordered a 75cc - 9/26/2008 11:16 PM
Ferocious Frankie
Score: 100
Status: offline
Looks great! Now get moving! Pun intended!
Plane: AW 50cc Extra 300
Radio: Futaba 12FG 2.4 GHz
Hide Signatures
(in reply to Lins)
       Post #: 12
RE: Finally Ordered a 75cc - 9/27/2008 12:11 AM
Lins
Score: 100
Status: offline
Trust me, Wednesday can't get here quick enough to be able to use my new shop!
Hide Signatures
(in reply to Ferocious Frankie)
       Post #: 13
RE: Finally Ordered a 75cc - 9/28/2008 1:12 AM
zzw26n
Score: 100
Status: offline
Some pictures from this spring, the Spinner is a NOVA Extra from Airwild. The picture doesn't do it justice, very shinny, high Quality.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Lins)
       Post #: 14
RE: Finally Ordered a 75cc - 10/4/2008 5:40 AM
Dblex
Score: 100
Last Login: 11/8/2009
Status: offline
Is there room for four HD Switches? I run two batt packs, ingnition pack and smoke main....
I see two on the plane, but is there 2 more spots? My hangar 9 sukhoi had two in front and two in the back..
Just curious
Hide Signatures
       Post #: 15
RE: Finally Ordered a 75cc - 10/6/2008 1:40 AM
zzw26n
Score: 100
Status: offline
quote:
ORIGINAL: Dblex
Just curious
Yes four will fit, I have three HD switches; two on the left side for Rx and one on the right side for IGN.
Hide Signatures
(in reply to Dblex)
       Post #: 16
RE: Finally Ordered a 75cc - 10/18/2008 5:19 PM
Lins
Score: 100
Status: offline
I've managed to get a little work done so far. Lots to do when you buy a house! A high of -5C today, so I don't think I'll be doing any flying until spring. I will at least run it though .
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: Finally Ordered a 75cc - 10/20/2008 5:39 AM
Lins
Score: 100
Status: offline
Well I got her running today! Not in flying condition yet, but she runs! I'll try and take some pics tomorrow and maybe video.
Hide Signatures
(in reply to Lins)
       Post #: 18
RE: Finally Ordered a 75cc - 10/21/2008 12:08 AM
DLEVETT
Score: 105
Status: offline
Good to hear you,ve got it running. If you,ve got some video of it that would be good.
I too ordered one through Great Hobbies last week, I can,t wait for it to arrive.
I,ve got a 3W-80xi engine arriving this week as well and am glad to see its a recommended power plant as per the manual.
Dave
Hide Signatures
(in reply to Lins)
       Post #: 19
RE: Finally Ordered a 75cc - 10/21/2008 1:12 PM
Dblex
Score: 100
Status: offline
So, Im assuming that since they mention 1.25 arms on the ailerons, that they are the same on the Elevator's? I started mine last night, so far so good. Starting the elevators tonight, but it doesnt mention on this part the size of the arm to use? I have some 1.5's from my sukhoi, but they look to be really misaligned with the horns.
Can anyone chime in?
Hide Signatures
(in reply to DLEVETT)
       Post #: 20
RE: Finally Ordered a 75cc - 10/21/2008 6:52 PM
Lins
Score: 100
Status: offline
I haven't checked my control throws yet, so I can't comment right now. I might get to that tonight. I just used the stock jr arms for now until I know where i stand. for high rate or 3D i'm assuming you will need at least 1.5" arms all around
Hide Signatures
(in reply to Dblex)
       Post #: 21
RE: Finally Ordered a 75cc - 10/24/2008 1:09 AM
DLEVETT
Score: 105
Status: offline
My Extra has arrived.
I came home from work to be greated by this. I can,t wait!
Dave
Click for fullsize
Hide Signatures
(in reply to Lins)
       Post #: 22
RE: Finally Ordered a 75cc - 10/24/2008 1:17 AM
Lins
Score: 100
Status: offline
Looks just like my boxes! I'm waiting to get a helper to come over to help do a run up to take some pics and video.
Hide Signatures
       Post #: 23
RE: Finally Ordered a 75cc - 10/24/2008 1:24 AM
DLEVETT
Score: 105
Status: offline
Yeah, I,m going to put my kids to bed early and then spend some quality time with the newest addition to the family.
Hide Signatures
(in reply to Lins)
       Post #: 24
RE: Finally Ordered a 75cc - 10/24/2008 1:48 AM
Sukhoi4Me
Score: 100
Status: online
Guys if its as much fun as my 100cc, you are gonna be so friggen happy with your purchase....Congrats.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.172RCU1
