Sikk 25.4 hot up tips
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> Sikk 25.4 hot up tips
Page: [1]
Login
Sikk 25.4 hot up tips - 9/15/2008 10:13:54 AM
spudda308
Status: offline
Hi all, Have a Sikk 25.4cc engine and would like to know what steps can be taken to hot up these engines. Currently running a walbro wt-771 carby. Is there things that can be done at home in a shed apart from sending it to someone that can help make it run harder?
       Post #: 1
RE: Sikk 25.4 hot up tips - 9/15/2008 2:13:10 PM
OLD_SLOW and in the WAY
Status: offline
file .030" off the bottom of the piston skirt on the intake side, this will raise the intake timing to 150 deg... you can shave up to .040" off but try .030 first, 155 deg is about max before starting gets cranky
do a search for sikk mods
< Message edited by OLD_SLOW and in the WAY -- 9/15/2008 2:14:34 PM >
_____________________________
OLD...SLOW
AND IN THE WAY
(in reply to spudda308)
       Post #: 2
RE: Sikk 25.4 hot up tips - 9/16/2008 9:27:46 AM
spudda308
Status: offline
Cheers mate, Thanks for the advice and will do a search as well.
(in reply to OLD_SLOW and in the WAY)
       Post #: 3
RE: Sikk 25.4 hot up tips - 9/19/2008 6:18:51 AM
spudda308
Status: offline
Hi all what do you guys think about this for my sikk in a falcon 41 cat?
http://cgi.ebay.com.au/SIKK-CY-27cc-Terminator-Kit_W0QQitemZ110289967390QQihZ001QQcategoryZ34058QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
       Post #: 4
RE: Sikk 25.4 hot up tips - 9/20/2008 2:06:19 AM
MrMikeG
Status: online
I never heard of that guy, he has good feed back though. Personally I would rather spend my money to get someone to do it locally. Daniel Schafer (OMEN Engines) mods Zenoahs and has good prices, contact him and see what he says.
The biggest concern is Sikks have a big variance in their squish clearance, this kit might be ok for one with a big squish and too tight for one with a tight squish. Without measuring YOUR engine who knows if it will be good or not?
       Post #: 5
RE: Sikk 25.4 hot up tips - 9/20/2008 3:13:31 AM
Riggerman
Status: offline
I have three CY 25.4 engines and have managed to keep them all running well. With the two bolt head they are really not a good engine to modify much. On the two that I modded I just lightened the piston, made some small eyebrow cuts and smoothed out the transfers. If you do much more you will crack the jug near one of the head bolts. The most important mod is to replace the base gasket with the blue zenoah one or get a 0.020 copper one. Also make sure you have your pipe supported very well or the jug will crack under the exhaust port.
Jeremy Leaf - Manufacturer of cats and outrigger hydros under the company name: Purpose Built RC
(in reply to MrMikeG)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU4
