Fuel tank location and distance from engine?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Fuel tank location and distance from engine?
Page: [1]
Login
Fuel tank location and distance from engine? - 5/23/2003 6:28:22 PM
WA8INZ
Status: offline
I'm scratch building an airboat but want to place the fuel tank in the hull about 7 inchess below the carb, how far will an OS.91 4 stroke pull up the fuel?.
Bill
       Post #: 1
Fuel tank location and distance from engine? - 5/23/2003 10:39:25 PM
JWN
Status: offline
7" below the carb? Not a chance unless you install either a Perry micro-oscillating pump or a Cline regulator.
John
(in reply to WA8INZ)
       Post #: 2
Fuel tank location and distance from engine? - 6/4/2003 4:47:45 AM
Spaceclam
Status: offline
i got a .91 four stroke with a crankcase-pressure pump allowing it to pump fuel nomatter how slow it goes. i broke it in pulling it about 5 feet strait out of a gallon. that is how well that works. however, as long as your fuel tank is 7 inches above the hull aswell, you won't have a problem
_____________________________
Duct tape is like the force. It has a light side, a Dark side, and it holds the universe together.
       Post #: 3
Fuel tank location and distance from engine? - 6/4/2003 4:53:04 AM
JWN
Status: offline
How did you handle venting the crank on your .91? The only 4-strokes designed to not vent are YS's. All others will eventually fill the crank with oil and cause running problems.
John
< Message edited by JWN-RCU -- Jun 4 2003 12:00AM >
       Post #: 4
Fuel tank location and distance from engine? - 6/4/2003 7:22:04 AM
Spaceclam
Status: offline
it does have a crankcase vent, which turns back into the carburator. to be honest, the pump came factory installed. it is the os .91 surpass III with pump. it runs for about $325. but, the crankcase vent is hole is much smaller than the displacement under the piston, so the pump works really well.
       Post #: 5
Fuel tank location and distance from engine? - 6/4/2003 8:13:43 PM
JWN
Status: offline
Ah yes, I forgot about the pumped OS engines. I was afraid you hooked up a Perry pump to the crank vent and called it good.
John
       Post #: 6
Fuel tank location and distance from engine? - 6/4/2003 8:33:02 PM
Spaceclam
Status: offline
no. but those pumped engines are great. however, i am surprised that the 1.20 is pumped but the 1.60 FLAT TWIN isn't. nor is the 3.0 flat twin. as a matter of fact, i don't think their flat fours or their radials have them either.
       Post #: 7
Fuel tank location and distance from engine? - 6/4/2003 8:38:14 PM
JWN
Status: offline
I believe the .91 and 1.20 are more geared towards performance whereas the other engines you mentioned are aimed at sport/scale fliers who don't try to get every last bit out of their engines.
John
       Post #: 8
Fuel tank location and distance from engine? - 6/13/2003 9:16:07 AM
canadianjosh
Status: offline
I have built an airboat and this is a big problem, my boat is a twin engine rig powered by two OS .40 FX's, so i am running two 8oz tanks, now that gives it about 18 mins runtime, so i could go with smaller tanks, but i had them so i used them. The engines, tanks, servos for throttle and servos for rudders are all up in the nacelles, as well as the battery and receiver. If you build a hull with a large enough beam then you won't run into any tippy problems. 7 inches is a long way to draw fuel vertically. i don;t know the specific weight of fuel, but i think it is pretty close to that of water, So if you are using 1/8" id line, times 2.54 to get it into mm, divide by two and square, then multiply by pi, then divide 1 by that number to get length in mm of tubing that will take 1cc of fuel. this equals 13.33mm of tubing equals one cc. so 7 inches is 17.78mm which is 177.8mm
so 177.8 divided by 13.33 equals about 13.3338 cc
that equals 13.3 grams of fuel. to draw up which may not sound like a lot but it is. You could try using a perry pump i don't know how much they will pump up though.
       Post #: 9
Fuel tank location and distance from engine? - 6/13/2003 10:15:15 AM
Spaceclam
Status: offline
i think you just fried my brain
       Post #: 10
Fuel tank location and distance from engine? - 6/13/2003 9:26:23 PM
JWN
Status: offline
Any of the Perry pumps will handle 7" draw distance without any issues.
John
       Post #: 11
Fuel tank location and distance from engine? - 6/24/2003 9:47:33 AM
matt walch
Status: offline
My dad and I both built a dumas swamp buggy about fifteen years ago. I built mine to specs. and it runs great with an O.S. 15. He went overboard and raised the motor mount, put a K&B .40 with a perry pump and carb on it and put the tank down in the boat. The darn thing never did run right Here is the amazing part though. Last summer I stuck my .46fx on it and it ran like a top - sucked the fuel a good 6-7 inches up with medium fuel line. The problem was that the boat thought it was a sub. I attached a peice of metal off the back of the boat on an angle. It kept it on top of the water with a nice spray too. What we won't do to make a bad design work!
< Message edited by matt walch -- Jun 24 2003 1:12PM >
I drink RC cola. Hey, anything helps!
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
