Losi 1/10 Slider RTR
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Losi 1/10 Slider RTR
Page: [1]
Login
Losi 1/10 Slider RTR - 9/21/2008 8:47:17 PM
frittvilt
Status: offline
Hi.
I just want to know if this battery:
http://cgi.ebay.com/Integy-EP3000-7-2V-6-Cell-NiMH-Stick-Pack_W0QQitemZ170264256106QQcmdZViewItem?hash=item170264256106&_trkparms=72%3A1205|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
works/fits with the Losi 1/10 Slider RTR:
http://www.losi.com/Products/Features.aspx?ProdID=LOSB0290
and if the battery fits with this charger:
B6 Cells Li-Po NiMH LiCd RC Battery Digital Lcd Charger
http://cgi.ebay.com/B6-Cells-Li-Po-NiMH-LiCd-RC-Battery-Digital-Lcd-Charger_W0QQitemZ270277769935QQcmdZViewItem?hash=item270277769935&_trkparms=39%3A1|66%3A2|65%3A3|240%3A1318&_trksid=p3286.c0.m14
Thank you.
       Post #: 1
RE: Losi 1/10 Slider RTR - 9/21/2008 8:58:59 PM
emaXXman123
Status: offline
ya it should all work
_____________________________
mongoose 13.5t 18r,xl5 rustler,tmaxx,bandit,micro t,nitro rustler,mrs4,emaxx,maybe a race buggy :)
(in reply to frittvilt)
       Post #: 2
RE: Losi 1/10 Slider RTR - 9/21/2008 9:03:37 PM
frittvilt
Status: offline
thanks.
because I am thinking of buying it. it looks cool.
what can I expect from it?
(in reply to emaXXman123)
       Post #: 3
RE: Losi 1/10 Slider RTR - 9/21/2008 9:06:32 PM
emaXXman123
Status: offline
i personally like the late model over the slider but i think your gonna get your money worths
but i would suggest going lipo instead of haveing the hassle of NiMH
       Post #: 4
RE: Losi 1/10 Slider RTR - 9/21/2008 9:12:19 PM
frittvilt
Status: offline
yes, but it say that I need optional parts to put in a lipo battery.
Needed to Complete
To complete the 1/10 Slider you will need...
1. An approved battery pack. The 1/10 Slider will accommodate a 6-cell NiMH flat pack, a 2-cell LiPo battery pack or a 3-cell LiPo battery (2- and 3-cell LiPo packs require optional electronics).
2. A battery charger.
what do you think I need of optional electronics? would it be hard to place in the slider?
and what kind of battery would you suggest?
< Message edited by frittvilt -- 9/21/2008 9:36:45 PM >
       Post #: 5
RE: Losi 1/10 Slider RTR - 9/21/2008 9:41:26 PM
emaXXman123
Status: offline
all you reanny need is an external lipo cut off...its like 15 bucks
       Post #: 6
RE: Losi 1/10 Slider RTR - 9/21/2008 9:48:03 PM
frittvilt
Status: offline
ok.
do you have link to where I can get an external lipo cut off?
and do you have a link to a good battery?
< Message edited by frittvilt -- 9/21/2008 9:57:56 PM >
       Post #: 7
RE: Losi 1/10 Slider RTR - 9/22/2008 4:10:48 PM
frittvilt
Status: offline
I am thinking of buying this batttery: is it any good?
Lipo 4000HV 3S 11.1V Pack
http://www.maxamps.com/proddetail.php?prod=Lipo-4000-111-Pack-T&cat=183
or should I go for a battery like this?
http://www.maxamps.com/proddetail.php?prod=Lipo-5000-111-Pack-T&cat=183
but should I add an extra plug to the battery I buy?
would you recomend to add extra skin, balancing taps, wire or should I let everything stand on standard?
and what kind of charger should i choose?
I would prefer the charger to come from the same site.
< Message edited by frittvilt -- 9/22/2008 4:48:20 PM >
       Post #: 8
RE: Losi 1/10 Slider RTR - 9/30/2008 5:57:13 PM
Mid-Mo Hobby Shop
Status: offline
We just receivedour shipment they look really cool, but I had planned to use a Trinity 4500mah 2s lipo in them until I read the manual and for this on page 3 . . . .
• Do not attempt to use 2 or 3-cell LiPo or 7-cells NiMH;
doing so will damage the ESC and could result in fire.
I have never seen this before, I am aware of li-po cutoff issues. Does anyone have anything on this or is losi just covering their rear or have they done something to the esc to mhis happen in order to assure brushless system sales ?
John
       Post #: 9
RE: Losi 1/10 Slider RTR - 9/30/2008 7:06:00 PM
Lilredmachine
Status: offline
The ESC in it cannot handle Lipo as although the actual resting voltage of lipo is only .2 of a volt more than Nimh, when under load that gap increases drastically, so an ESC that can use 7.2 volt nimh packs but not 7 cell nimh is unlikely to be able to handle 2 cell lipo either. Say for an example a fully charged nimh 6 cell pack reads 9 volts off the charger, in the car at rest it sits at 8.0 volts but under load (say under hard acceleration or braking, where the esc and motor are under most strain) this drops down to 6.8 volts average over a 10 minute run. The Lipo comes off the charger at 8.4 volts, sits at 8.4 volts and manages an average voltage of 7.8 over a 10 minute run, you can see that the electronics have taken a far more severe battering from the 2 cell lipo than the 6 cell nimh.
I guess the Slider ESC is happy on 6 cells but not 7 cell packs or lipos.
(in reply to Mid-Mo Hobby Shop)
       Post #: 10
RE: Losi 1/10 Slider RTR - 9/30/2008 10:20:08 PM
Chris_RC
Status: online
Dont get Maxamps batteries. they are way overpriced and dont preform all that good. I would get a Orion 3800 or Trakpower 4900.
B-Fast RC
(in reply to Lilredmachine)
       Post #: 11
RE: Losi 1/10 Slider RTR - 10/1/2008 11:53:26 PM
Mid-Mo Hobby Shop
Status: offline
Thanks for tech tip lilredmachine. . . . We tried and it definitly will not work the esc thermals in just a couple minutes even dropped the pinion size down to an 18t and still not luck esc hit thermal shutdown with the motor just at 100 degrees. As far as batteries I sell max amps for many large mah apps and hv set ups and they are good though pricey the service is 2nd to none and quality is overall good. For 2 cell 7.4v apps I sell the trinity 4500mah a great battery in a hard case with the cutoff built in for a very reasonable price.
Just my 2 cents .
John
(in reply to Chris_RC)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
