RE: Redcat Custom Monster Truck
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Custom Monster Truck
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Redcat Custom Monster Truck - 9/26/2008 3:52:37 PM
jpilkinton
Status: offline
quote:
ORIGINAL: el_tonto
where's the brakes?
In case you haven't thought about it already, I'd recommend putting the brakes on the front. So leave the front dogbones and diff assembly in place so that you can mount the brake disc to the diff input.
THEN you can lock up the front (well, if you have a 3-channel radio) and light up the rear! wooooooo!
Brakes?!?!?!? Ummmmm.... brakes........? Yeah, I could use some brakes... 8-)
I actually thought about using the front diff for brakes also. That will be the next thing after the front steering assembly.
_____________________________
AllAboutFunHobbies / Himoto Racing USA
Redcat Racing / Himoto Racing
(in reply to el_tonto)
       Post #: 26
RE: Redcat Custom Monster Truck - 9/26/2008 3:54:41 PM
jpilkinton
Status: offline
quote:
ORIGINAL: tylervalentine
have you already planned everything out or are you going one thing at a time?
cant wait to see a video! but when you do make the video make sure to go all the around the truck so we can see all of your handy work.
One thing at a time. No problem, I will do a spin around the truck before she gets dirty.
Thanks guys.
(in reply to tylervalentine)
       Post #: 27
RE: Redcat Custom Monster Truck - 9/27/2008 7:48:58 AM
jpilkinton
Status: offline
Just got the steering assembly finished. The only thing left for steering is some clevis' .
I don't have any longer rods to fit the screw-on clevis' that I have. Gotta go to the LHS in the morning.
The next to final stage is the fitting of the fuel cells. I'm trying to have one on each side. I am using the fuel cells from the 1/16 kits. I think they are about 50cc each?????? Which would give me plenty(100cc) of fuel for ripping some mud. I also have to get me some tees so I can tie each tank to each other. OK, scratch the dual tanks...not enough room on this chassis. The next one will be about 2"-3" longer so I can use one fuel cell.
I also got the fuel cell mounted.
Silly me, I had to pull the engine back out to put the clutch shoes and springs in.... I must have gotten in a hurry...
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to jpilkinton)
       Post #: 28
RE: Redcat Custom Monster Truck - 9/27/2008 12:11:53 PM
tylervalentine
Status: offline
i cant wait to see it run
PBS style Redcat Lightning
       Post #: 29
RE: Redcat Custom Monster Truck - 9/27/2008 9:05:33 PM
jpilkinton
Status: offline
Well.... I fired it up this afternoon and it ran pretty darn good. But it didn't run long!
I sheared the rear input shaft gear!!!!
I made a 10 foot(kinda muddy) dirt section in my back yard and the first 2 or 3 runs were good. This engine is running very rich as you can tell from the smoke!
On the last run, well......... it probably went 4 or 5 feet and the rear end gave up.....
Good thing I have a spare from the front end gearbox! I wonder if they make the metal ones for the tremors???
Editing video right now. Will be up later...
       Post #: 30
RE: Redcat Custom Monster Truck - 9/27/2008 9:59:28 PM
jpilkinton
Status: offline
Here is a picture of a good(top) input shaft and the one I just pulled out(bottom):
I did notice they have a washer shim on the backside of the gear. I wonder if there was not enough gear mesh that caused this.....
I will try with two shims and see if the gears are meshed too tight.
Click for fullsize
< Message edited by jpilkinton -- 9/27/2008 10:01:48 PM >
       Post #: 31
RE: Redcat Custom Monster Truck - 9/27/2008 10:13:18 PM
jpilkinton
Status: offline
Here are the videos:
For some reason on the third video, the video playback is slower than the audio?!?!?!? I don't know what the heck happened there!
http://s441.photobucket.com/albums/qq135/Nitromaster_2008/?action=view¤t=Part1-1.flv
http://s441.photobucket.com/albums/qq135/Nitromaster_2008/?action=view¤t=Part2-1.flv
http://s441.photobucket.com/albums/qq135/Nitromaster_2008/?action=view¤t=Part3-1.flv
http://s441.photobucket.com/albums/qq135/Nitromaster_2008/?action=view¤t=Part4.flv
       Post #: 32
RE: Redcat Custom Monster Truck - 9/27/2008 10:52:11 PM
tylervalentine
Status: offline
that little thing is mean isnt it?!
what made it start to leak fuel?
and have you gotten the new shaft in it yet?
       Post #: 33
RE: Redcat Custom Monster Truck - 9/28/2008 12:40:35 AM
r\c justin
Status: offline
thats it.... why did u build ur own?
       Post #: 34
RE: Redcat Custom Monster Truck - 9/28/2008 3:08:48 AM
tihstae
Status: offline
thats sick man i like it, make me wanna build my own now haha
(in reply to r\c justin)
       Post #: 35
RE: Redcat Custom Monster Truck - 9/28/2008 3:51:56 AM
jpilkinton
Status: offline
Yes, she is mean as a snake!
Actually, that is oil. I use Traxxas Top Fuel and it has alot of oil in it. I am on the very rich side. I did noticed when I was running these engines with a prop that this one likes to load up and start spitting fuel and mostly oil out the front bearing. But she still runs like a beast and smokes more than I do. LOL! That is why she almost died on that one run. She was LOADED!!! I tried to lean her out but she doesn't like it much. I haven't had much time to get her tuned properly. I almost ran down my battery trying to start her because this baby has some major compression.
I have the rear end pulled apart and doing some major cleaning. I will paint the chassis tommorrow. What color would look the best? Please input!
< Message edited by jpilkinton -- 9/28/2008 4:02:13 AM >
       Post #: 36
RE: Redcat Custom Monster Truck - 9/28/2008 3:57:24 AM
jpilkinton
Status: offline
quote:
ORIGINAL: r\c justin
I love making things. That is another hobby of mine....metal working....
I bought these two new engines off epay about 5 months ago cheap and I finally got the tools to do the job. I know I could have just bought a RTM kit, but that isn't the same as building your own to your specs. Even though I did use parts from a RTM kit........It just wouldn't been the same....
       Post #: 37
RE: Redcat Custom Monster Truck - 9/28/2008 4:01:11 AM
jpilkinton
Status: offline
quote:
ORIGINAL: tihstae
Thanks man!
I just wished she would have held up a little longer! I'm thinking there was too much space between the diff and the input shaft. I will shim it some more and see if that will hold.
She will be fun in the snow! But here in arkansas, snow is almost extinct.
(in reply to tihstae)
       Post #: 38
RE: Redcat Custom Monster Truck - 9/28/2008 10:30:44 AM
tylervalentine
Status: offline
I watched the videos again after i sent that last one and noticed that it was a little to thick to be just fuel, so may bad.
With the color of it personally i wouldn't
