Ducted fan airboat?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> Ducted fan airboat?
Page: [1]
Login
Ducted fan airboat? - 9/23/2008 10:11 AM
sheograth
Score: 142
Last Login: 11/8/2009
Status: offline
Just wondering if anyone here has made or has a ducted fan airboat? I am considering a scratch build just for the fun of it.
_____________________________
www.mangosnake.com
Hide Signatures
       Post #: 1
RE: Ducted fan airboat? - 9/23/2008 2:17 PM
mb1387
Score: 100
Last Login: 11/2/2009
Status: offline
I got a fan and k& b 82 Ive been thinking the same thing, lets see what every one else comes up with
alcohol is for drinkin. gasoline is for cleanin . NITRO is for racin
Hide Signatures
(in reply to sheograth)
       Post #: 2
RE: Ducted fan airboat? - 10/1/2008 1:04 AM
alloutcustom
Score: 100
Last Login: 7/24/2009
Status: offline
HERE is an EPIC failure DF airboat vid on youtube, lol
If the boat doesnt fly, dont buy!!! ; )
Hide Signatures
(in reply to mb1387)
       Post #: 3
RE: Ducted fan airboat? - 10/1/2008 8:01 PM
pinky_d_brain
Score: 100
Last Login: 11/7/2009
Status: offline
I am currently building an EDF airboat it is taking for ever but that just because I don’t have anywhere to work on it or the time
I prefer duct fans they have a lower thrust line form small diameter allowing for lower CG. They come up a little short on power the thrust is much faster but more concentrated creating les pushing traction but much hire speed if you build light
I don't do normal
Hide Signatures
(in reply to alloutcustom)
       Post #: 4
RE: Ducted fan airboat? - 10/2/2008 12:27 AM
alloutcustom
Score: 100
Status: offline
WOW! very nice!!! Hurry up, because now i wanna see it go!!! lol.
Hide Signatures
(in reply to pinky_d_brain)
       Post #: 5
RE: Ducted fan airboat? - 10/29/2008 4:30 PM
kzimmerman
Score: 100
Last Login: 11/6/2009
Status: offline
Yes, I've built one. Gws 55 ducted fan on eight 650nimh, blue foam boat, about 30" long, 6" wide, slight vee bottom. Was started for inboard nitro, but wanted something for my son to tool around with. Actually went pretty well, so I tried two ducted fans, my son then drove straight under a dock, lost one fan, back to one only. Blows over easy. Was considering rebuilding it smaller, but already have too many projects.
Hide Signatures
       Post #: 6
RE: Ducted fan airboat? - 11/12/2008 2:28 PM
kzimmerman
Score: 100
Status: offline
Allright, I am gonna rebuild it, about 12"x6". Gonna be 1/32 balsa or 1/64 ply, can't decide. I'm also gonna go lipoly on it, and try to build it as light as possible. I may even build a mold and make it outa glass and poxy, I can build very light that way. In my experience with ducted fans, you need to build a nacelle for it, because there are specific ratios that need to be adhered to to get the most effeciency out of the fan. I believe that the intake needs to be 150% of the fan area, and the exit is 80% of the fan area. Note that the center hub does not count in the fan area, just the area of the blades.
kurt
Hide Signatures
(in reply to kzimmerman)
       Post #: 7
RE: Ducted fan airboat? - 11/15/2008 6:14 PM
supagloo
Score: 100
Status: offline
Does this count?
Not really a ducted fan but this surely helps to get rid of the turbulence created by the propeller.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Supagloo
Approved Vertical Rekitting Specialist
Hide Signatures
       Post #: 8
RE: Ducted fan airboat? - 5/30/2009 7:50 AM
krazikiwi
Score: 100
Last Login: 11/1/2009
Status: offline
Nice do you have any other pics would love to see more??
Hide Signatures
       Post #: 9
RE: Ducted fan airboat? - 5/31/2009 5:40 PM
johnnycat500
Score: 105
Last Login: 10/18/2009
Status: offline
Here is my proof of concept first try at any kind of boat. I have helicopters and wanted to use the spare parts I have. So I went to Kmart to see if I could find a low cost boat. I got this one for $16.99. I looked thru hobby lobby boat parts to find some rudders that would work. I machined some aluminum for the rudder shaft to fit in. I did not want to spend all a lot of time building a boat for this ducted fan because I know nothing about boats. So I went to the park near me that has a big lake. I  The rudders do a good job of steering it. The fan was loose and would turn a little bit and you loose steering. Did not have the tools with me to fix it at the lake. Did not matter anyway because the dx7 started beeping for low battery ..LOL  Hope in a few days I will get to try again. Here's a few pics..
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to krazikiwi)
       Post #: 10
RE: Ducted fan airboat? - 5/31/2009 9:45 PM
rcbif
Score: 100
Last Login: 8/21/2009
Status: offline
quote:
ORIGINAL: johnnycat500
That looks neat. You should make a new canopy/motormount out of something lighter like a sheet of lexan so you can lower your cog too.
Hide Signatures
(in reply to johnnycat500)
       Post #: 11
RE: Ducted fan airboat? - 6/1/2009 12:40 AM
johnnycat500
Score: 105
Status: offline
Your right on top of it  rcbif   I have the plate made but I need input on the location of the ducted fan. Also is it better to have the DF blowing thru a extension maybe 2/3 inches long. Would that make it more efficient ?
Click for fullsize
Click for fullsize
< Message edited by johnnycat500 -- 6/1/2009 12:45 AM >
Hide Signatures
(in reply to rcbif)
       Post #: 12
RE: Ducted fan airboat? - 6/16/2009 7:29 PM
vamp131
Score: 100
Last Login: 8/31/2009
Status: offline
Wow i have got one of the small air boats tried to fit a 40 into it but when i tested it way to heavy lol it sank
Hide Signatures
(in reply to supagloo)
       Post #: 13
RE: Ducted fan airboat? - 6/19/2009 6:34 AM
srw1960
Score: 100
Last Login: 10/20/2009
Status: offline
I had never thought of using a ducted fan unit for an air boat until I saw this thread....Now I have another project...Needed it like a hole in the head but I think it will be fun..
I purchased a brand new ducted fan unit off e bay last night after reading this thread and have an idea for a very wicked looking shallow vhull boat.. I will post pics as soon as I begin construction and we will just see what happens ...I promise it will be very unconventional..im thinkin maybee vectored thrust instead of air rudder or any other type of rudder and very low cg so it will go way fast and still be way stable..Hmmmmmm  lots of ideas any thoughts from you guy's?  probably power it with lipo's ill have to learn about them have no experience with them at all but im a quick learner..
Ok nuff for now more to come I promise
Hide Signatures
       Post #: 14
RE: Ducted fan airboat? - 6/19/2009 6:43 AM
johnnycat500
Score: 105
Status: offline
can't wait to see your pics. I wanted to go to a vectored thrust but am a newbie to this and would think the boat would not have the control as with rudders. looking forward to your post
Hide Signatures
(in reply to srw1960)
       Post #: 15
RE: Ducted fan airboat? - 6/21/2009 9:02 AM
srw1960
Score: 100
Status: offline
Well I am definatly comited to this now .. Today I purchased the esc and a 4000 mah 14.8 volt lipo to run the fan unit on...
I am new to airboats as well have built prop powered for years but have just recently gotten into air and so far I LIKE IT...
I was worried that air rudders wouldnt be enough for my first air boat but when I got it on the water I quickly discoverd they worked great. so I am confident that a vectored thrust unit on the back of the fan will work just fine...I am planning on using thin wall pvc pipe and heating and reshaping the end of it to meet my needs and I am working on a gimble to attach it with to allow it movement  through both axis..
I will do my best to have some drawings posted here in the next couple days.I am not the best artist so itll take me a bit of time to do it...
Hide Signatures
       Post #: 16
RE: Ducted fan airboat? - 7/5/2009 8:45 AM
srw1960
Score: 100
Status: offline
Ihave all the parts in from china now to get this started. I will use a 89mm fan unit with brushless motor running a 14.8 volt lipo and a 40a esc.I stared laying it all out today and drawing templates as I go I will start a build thread probably monday hope you guys enjoy I think itll be a blast
Hide Signatures
       Post #: 17
RE: Ducted fan airboat? - 7/7/2009 1:57 AM
srw1960
Score: 100
Status: offline
Ok started a new thread tonight covering my ducted fan build hope yall enjoy it
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.000RCU1
