RE: Unofficial    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: Unofficial
Page: <<   < prev  118 119 120 121 122 123 124 125 [126] 127   next >   >>
Login
RE: Unofficial - 12/2/2012 3:27 AM
Scubaru Steve
Score: 100
Last Login: 4/14/2013
Status: offline
any pics of the build? im tempted, or buy one of these kits...
Hide Signatures
(in reply to BIG22BIRD)
       Post #: 3126
RE: Unofficial - 12/13/2012 10:57 PM
seehuusen
Score: 100
Last Login: 5/25/2013
Status: offline
hey Steve, if you click the gallery link above, you should see all images in this thread.
There should be a bunch detailing what needs to be done
Hide Signatures
(in reply to Scubaru Steve)
       Post #: 3127
RE: Unofficial - 12/19/2012 12:00 AM
biznitch
Score: 100
Last Login: 4/17/2013
Status: offline
Wondering how the impeller is held on the shaft?   Do they come loose?  How to re-attach?
                               Thnx.
Hide Signatures
(in reply to seehuusen)
       Post #: 3128
RE: Unofficial - 12/20/2012 9:03 AM
seehuusen
Score: 100
Status: offline
there are groves on the shaft, which you squeeze the prop over. Sits pretty tight on the original shaft.
If you want to go custom, say stainless because you run it in salt water... You can just epoxi it on
Hide Signatures
(in reply to biznitch)
       Post #: 3129
RE: Unofficial - 12/21/2012 1:44 AM
biznitch
Score: 100
Status: offline
  Thanks for  your help. I have bought some spare ones and I couldn't figure out how they went on the shaft.
Hide Signatures
       Post #: 3130
RE: Unofficial - 12/21/2012 2:53 AM
Mikeup
Score: 105
Last Login: 5/13/2013
Status: offline
< Message edited by Mikeup -- 12/21/2012 9:57 AM >
Hide Signatures
       Post #: 3131
RE: Unofficial - 12/21/2012 3:54 AM
damfurst
Score: 100
Last Login: 4/28/2013
Status: offline
quote:
ORIGINAL: Mikeup
I've been reading the thread and a ?. Bearing, where does it go? The only place i can place it is where the shaft attaches to coupler which would be best . There would be alot less friction compared to sleve.
On page 119 I show a picture of the bearing and where it goes on the front of drive behind the motor coupler. It replaces the rubber seal that is there. The bearing is 10mmX3mmX4mm. I would post the picture here but can't find it on my computer right now.
Hide Signatures
(in reply to Mikeup)
       Post #: 3132
RE: Unofficial - 12/21/2012 4:17 AM
Mikeup
Score: 105
Status: offline
Found my answers by email.
< Message edited by Mikeup -- 12/27/2012 11:44 PM >
Hide Signatures
(in reply to damfurst)
       Post #: 3133
RE: Unofficial - 12/25/2012 2:27 AM
duckdogs14
Score: 100
Last Login: 5/23/2013
Status: offline
Having to part with my boats if anyone is interested... Search listing number 890028 in the buy & sell page. I am NOT interested in breaking it up.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 3134
RE: Unofficial - 1/18/2013 6:59 PM
Mikeup
Score: 105
Status: offline
? for the knowledgeable boaters. When putting the jet body in, should the grate area be first gooped in or should the shute area be put in. I can't walk and chew gum. Hope you follow me on this as goop sets up fairly fast and with 2 areas that need the goop, doing equal justice to both comes into play. Thanks!
Hide Signatures
(in reply to duckdogs14)
       Post #: 3135
RE: Unofficial - 1/18/2013 10:21 PM
sundogz
Score: 129
Last Login: 5/22/2013
Status: offline
Install the large piece (jet body) first, by putting goop around the rim of the intake and around the outlet (in other words, everywhere it contacts the hull). When it set up, install the stator housing/steering nozzle using silicon caulking or something you can peel off easily if you need to remove it.
_____________________________
Arpro Mono,Genesis,Tenshock Essenz, PowerJet Viper,ABC Jet Ski,TearInto Jet Sprint, Legend & Discovery Sailers, JetCat proto
Hide Signatures
       Post #: 3136
RE: Unofficial - 1/19/2013 2:26 PM
Wheelnut
Score: 161
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: sundogz
Good advice, thanks
If it''''''''s not broke, fix it until it is
Hide Signatures
(in reply to sundogz)
       Post #: 3137
RE: Unofficial - 1/28/2013 3:04 AM
seehuusen
Score: 100
Status: offline
doing a rebuild of my original jetboat, as well as building a new one! I ended up buying two remote controls, as I want someone to race against when out... But the usual thing is, that your mates just don't have a jet boat... so I thought, why the heck not build another one?
I've ordered a couple more of the 2200mah Nano tech batteries, they are great for this application I reckon My idea is to run 2 batteries in each boat, as 3S2P, having one battery on each side.
I'll try to run one of these ESCs in each boat, http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17441
They've also been ordered Reason I am trying these is simple, it's the same internals as in my 180amp ESC, which I really like!!
In the new boat, i'm going to re-use some, of not most of the original r/c boxes and mounts. I've managed to modify the servo a bit, and with a few modifications of the mount, it fits perfectly... The Radio box might have the Rx in it, I'm not sure yet, it's pretty bulky... Other than that, I've finished the sleeve mod on the new jet drive, it came up pretty good.
I did think of putting the bigger Graupner drive into one of my boats, but that'd hardly make it fair when racing, so the idea got put on the shelf (I'm certainly going to do that one day )
Edit: Added some photos for you
Click for fullsize
Click for fullsize
< Message edited by seehuusen -- 1/30/2013 1:23 AM >
Hide Signatures
(in reply to Wheelnut)
       Post #: 3138
RE: Unofficial - 3/5/2013 3:25 AM
seehuusen
Score: 100
Status: offline
ahhhh $h.... I used shoe glue on the boat, thinking it was the ducks nuts... ehm, no! Two hulls are sitting in the living room melting away... I pray that the plastic will harden up...
Hide Signatures
       Post #: 3139
RE: Unofficial - 3/5/2013 3:38 AM
sundogz
Score: 129
Status: offline
Oh crap! Both hulls? Sounds like it was some powerful stuff. Maybe it will set up. Yeah, goop would have been the way to go if you could have located some. Or silicone caulking. I used 2 part 'plastic' epoxy on my last build, since I don't plan to remove it again.
Hide Signatures
       Post #: 3140
RE: Unofficial - 3/5/2013 4:18 PM
Mikeup
Score: 105
Status: offline
Acetate, check for this in other products, bad stuff!
Hide Signatures
       Post #: 3141
RE: Unofficial - 3/5/2013 11:55 PM
seehuusen
Score: 100
Status: offline
Acetate hey? Thanks Mike, I'll keep a sharp eye on that in the future!!
So, over night, the plastic hardened... GREAT! It's a bit "wonky" where it melted, one hull (of course the old one...) isn't too badly affected on the bottom... The other boat has a raised section, pics to come later, it will explain what I'm on about
I started planning out the old hull, where to put the new ESC and how to mount the servo again. Test with placing the battery in different spots, showed that the battery (2.2ah 3S Nanotec) did the best, being placed right in front of the motor, so it will go back there...
I found out that the Turnigy Marine ESC had slightly larger bullet connectors than the motors *sigh* so I'll have to get new connectors for that now, getting close now though
About time too, coz we've got MASSIVE amounts of rain water rushing down the creeks, time to get the current riding going again
Hide Signatures
       Post #: 3142
RE: Unofficial - 3/6/2013 1:44 AM
Mikeup
Score: 105
Status: offline
I bought a pair of lipos 1350 Gen aces and will saddle pack in 2S is a 4400 from Steve from downunder Sicrc. Steve is moving close to you and has jet hulls that you have to put together, so putting equipment in will be a snap. He has 2 or 3 colors. Sicrc Boat Mods. I got this info from RCGroups. They have a huge thread on jet boats.Hope it isn't to out of shape!
Hide Signatures
       Post #: 3143
RE: Unofficial - 3/6/2013 2:09 AM
millesm
Score: 100
Last Login: 4/29/2013
Status: offline
that's the Selly's product......  melts plastic in seconds.
Shoo Goo is what you really wanted.
Another option that I use is from Spotlight - Polyurathane glue.  Works a treat and is about $8 a bottle vs about $20 at bunnings.
Hide Signatures
       Post #: 3144
RE: Unofficial - 3/6/2013 3:07 AM
littledvl
Score: 100
Last Login: 5/12/2013
Status: offline
Been neglecting my nqd's, have aquired 3 since i built my first one (the black one)
the 2 white ones have been gutted and all parts ready to go back in, yellow one is gutted but no parts orderd for it yet.
Been too lazy to finish building them, hopefully ill get these built up before summer starts up, also wanna convert the reef racer to brushless.
Hide Signatures
(in reply to millesm)
       Post #: 3145
RE: Unofficial - 3/6/2013 3:54 AM
seehuusen
Score: 100
Status: offline
Thanks for this! I'll purchase some of that stuff for the next one
quote:
ORIGINAL: millesm
I think the boats will run OK, but I'm concerned that air will be a problem, due to turbulence... Only trial will show I guess
SicRC is in Maryborough from memory, looking at his eBay profile. I've bought from him before, but get it posted still.
He might not be THAT far away, but the cost of driving my car 200km return isn't as cheap as the mail-man
Hide Signatures
       Post #: 3146
RE: Unofficial - 3/27/2013 3:22 AM
prontozuk
Score: 100
Status: offline
this boat has been rebuilt since this video as went and played in the ocean and forgot to wash it out... new video next week after going away camping.
Same electronics new everything else and fitting some mesh to keep the pebbles out.
http://youtu.be/tqAEqdNHZF8
Hide Signatures
       Post #: 3147
RE: Unofficial - 3/27/2013 4:54 AM
SkR8Pn
Score: 100
Status: offline
Creeks are full and I think its time to hit the water again..
SCX10 Truggyx2, Wraith
Ota R31, 16FM, D3.
Hide Signatures
(in reply to prontozuk)
       Post #: 3148
RE: Unofficial - 4/9/2013 1:06 AM
prontozuk
Score: 100
Status: offline
another fun eater weekend.
I have to work on my camera angle though.
http://youtu.be/W9zn7_nwQsg
Hide Signatures
(in reply to SkR8Pn)
       Post #: 3149
RE: Unofficial - 4/21/2013 10:26 AM
SkR8Pn
Score: 100
Status: offline
I'm clearing off the bench for a new build and have some stuff to get rid of.
1. Modified jet drive. Smoothed extended intake, brass sleeve, custom balanced 6 screw coupler, custom drive shaft, custom drive cog and custom impeller to suit plus spare impeller. No steer nozzle!
Custom couplers (machined by me NOT Nqd's redrilled) 2.3mm-3.2mm x 2 and 3.2mm-3mm x 1
ALL SOLD!
< Message edited by SkR8Pn -- 4/27/2013 8:14 AM >
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 3150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
