RE: Unofficial "NQD" Tear into Jetboat Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: Unofficial "NQD" Tear into Jetboat Thread
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Unofficial "NQD" Tear into Jetboat Thread - 2/25/2009 7:47 PM
DRAGONFIRE81M
Score: 100
Last Login: 3/21/2013
Status: offline
i thank the newer style of the nockoff drive is 2.3 but the older one like the first run are 2mm . the reson i know this is im useing a graupner u-joint on the white one and its a 2mm
Hide Signatures
(in reply to headhunter23)
       Post #: 51
RE: Unofficial "NQD" Tear into Jetboat Thread - 2/25/2009 7:48 PM
sundogz
Score: 129
Last Login: 5/21/2013
Status: offline
Yep, 2.3mm drive shaft and motor shaft. But it is a sloppy fit with stock connector that came with mine (larger hole). You can see the connector movement whem it runs slowly, and it vibrates badly when up to speed (that's why I have some foam under my motor - to calm things down). If you were to drill and tap 2 more holes in the other side (opposite existing screws) you could get that wobble out. But I'd rather get a proper connector than to go through that (to small to fool with).
_____________________________
Arpro Mono,Genesis,Tenshock Essenz, PowerJet Viper,ABC Jet Ski,TearInto Jet Sprint, Legend & Discovery Sailers, JetCat proto
Hide Signatures
       Post #: 52
RE: Unofficial "NQD" Tear into Jetboat Thread - 2/26/2009 3:31 AM
DRAGONFIRE81M
Score: 100
Status: offline
ok i was wrong . sorry headhunter and sundogz. you wher both right . 2.3 mm is it . doesnt really mater know though . since i put the 3mm in the nockoff drive . if anyone needs a replacement . hit me up .
Hide Signatures
(in reply to sundogz)
       Post #: 53
RE: Unofficial "NQD" Tear into Jetboat Thread - 2/27/2009 5:30 AM
beke6874
Score: 100
Last Login: 3/10/2012
Status: offline
Dragonfire, I might be interested in your extra impeller and shaft.
Hide Signatures
(in reply to DRAGONFIRE81M)
       Post #: 54
RE: Unofficial "NQD" Tear into Jetboat Thread - 2/27/2009 7:21 AM
sundogz
Score: 129
Status: offline
OK, I know it's been too long in coming, but (finally) here are some movies of my knockoff as taken a couple months ago. This was after I modded the intake, added a 2080KV Turnigy (20x40) brushless motor, a 35A Seaking ESC, water cooling, and a 3s 2800MA Lipo. Fun on the river. Some of the 'motor' sound is the vibration of the off-center motor coupler.
Fun on the river: http://www.youtube.com/watch?v=p2AIA7q6iTI
Snappy: http://www.youtube.com/watch?v=OFT0pWeOeMM
I've since installed a 3800KV 396W motor (and bobble heads on the figures) to try out. I'll be sure to post results - should be interesting! I've got to replace that coupler first.
Hide Signatures
(in reply to beke6874)
       Post #: 55
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/2/2009 7:44 PM
Torran
Score: 100
Last Login: 8/3/2009
Status: offline
Hi has any one had problems getting boat to plane, can some one post some pictures of
battery housing and were to mount.
Thanks Torran
Hide Signatures
       Post #: 56
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/2/2009 8:32 PM
DRAGONFIRE81M
Score: 100
Status: offline
nope no prob planeing out . i mount my battery in front of the drive line or with two battery on there side . what is your set up
Hide Signatures
(in reply to Torran)
       Post #: 57
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/2/2009 9:26 PM
Torran
Score: 100
Status: offline
Hi i have my battery mounted above motor and jet unit , i am using 3500kv motor with 30A esc on 7.2 battery but have just orderd
li-po 11.1v 2450 mha .
Thanks Torran
Hide Signatures
       Post #: 58
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/2/2009 10:26 PM
DRAGONFIRE81M
Score: 100
Status: offline
is it a standerd 7.2 . if so the 11.1 lipo will help . your boat needs a deit .
Hide Signatures
       Post #: 59
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/3/2009 5:40 AM
beke6874
Score: 100
Status: offline
I've got the same problem. The 7.2 stick pack is just too heavy. I am reluctant to get into lipos because i really don't understand them yet. I tied two 7.2 packs but that was way way too heavy. Has anyone ever tried using AA size batteries?
Hide Signatures
       Post #: 60
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/3/2009 6:15 AM
sundogz
Score: 129
Status: offline
Dragon is right, those are heavy, underpowered batteries. You need to switch to Lipo's. Personally I think 3s (11.1v) is better than 2s (7.4v) because it's easier on the motor and more efficient, not to mention faster (with the same motor). If you get a good quality balancing charger then you needn't worry about lipo's any more than nicads or nimh. Just follow the instructions, and you won't have any problems.
Hide Signatures
       Post #: 61
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/3/2009 1:52 PM
DRAGONFIRE81M
Score: 100
Status: offline
if you just dont wont to make the switch yet . no prob . youll need to run a smaller pack more along the lines of a 1/18 scale like this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTYW5&P=SM if you run two i beleve youll come in just under the wight of one standerd pack and youll can have up to 14.4v if your setup can handel the volts
Hide Signatures
       Post #: 62
RE: Unofficial "NQD" Tear into Jetboat Thread - 3/25/2009 6:06 PM
damfurst
Score: 100
Last Login: 4/28/2013
Status: offline
I've been trying some brushless motors in the knock off and thought I would post some pics and results. I did try the 2700kv motor first (purple one). It worked, but was slower than anticipated. I then tried an emp 3200kv on 9.9v and it was a whole new boat. I am finally liking how this boat runs.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 63
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/17/2009 10:03 PM
blizzzarddemon
Score: 100
Last Login: 9/21/2012
Status: offline
hey guys i cant find the tear into anywhere they all say out of stock i have foudn this one is this jet drive
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250406463159&_trkparms=tab%3DWatching
and will it work with this motor
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4704&Product_Name=KB20-40-15L_3800kv_Brushless_Motor_(FIN)
this esc
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=658&Product_Name=TowerPro_W30A_Brushless_Speed_Controller
and this lipo
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8357&Product_Name=ZIPPY_Flightmax_4000mAh_2S1P_25C_Car_Lipoly
Hide Signatures
(in reply to damfurst)
       Post #: 64
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/17/2009 10:44 PM
DRAGONFIRE81M
Score: 100
Status: offline
your set up looks good but you can go to 3s 11.1v if you like . i wouldnt get that hull it dont do very well . ill post a vid of mine with a set up close to what you have picked out . just watch ebay they come in sperts look for the seller mideatoys thats where most of us got them from .
http://www.youtube.com/watch?v=a-MmplBQ_zY&feature=channel_page
Hide Signatures
(in reply to blizzzarddemon)
       Post #: 65
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/17/2009 11:59 PM
blizzzarddemon
Score: 100
Status: offline
so the larger hull wont work as well as the smaller one
Hide Signatures
       Post #: 66
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 1:54 AM
DRAGONFIRE81M
Score: 100
Status: offline
its a totaly diffrent hull the cracker is flat which it slids around easyer but it hopes like crazy no speed b/c the drive losses prime . where the jet sprint is a shallow v . but very wide and short witch make for a better jet drive hull
Hide Signatures
       Post #: 67
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 1:59 AM
DRAGONFIRE81M
Score: 100
Status: offline
here look on this page where i posted pic before mods where done . http://www.rcuniverse.com/forum/m_6523863/mpage_74/key_/tm.htm
Hide Signatures
       Post #: 68
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 2:24 AM
blizzzarddemon
Score: 100
Status: offline
dang i have a nitro hammer got from friend and i have not got it wet ye he only broke it in. and i love the jet drive idea but the crackerbox seems to hoppy and driftiy to be a lot of fun. im also looking for a cheap cheap rc boat for a retrival system im coming up with where the cheap boat pulls fhishing line from shore to the dead boat goes around it then your use a fishing reel to reel in both boats it wont strain the boats motor at all.any suggestions on how to make that jet drive work. im tempted to get it and make my own boat hull out of plexiglass i and lexan. im also tempted to install a brushless jet drive into my kyosho blizzard and use 2 small boat huls like reefracers fill them with insolation foam and use them as pontoons for floats only thing is i dont want to cut up my rare blissard too much
Hide Signatures
       Post #: 69
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 2:29 AM
blizzzarddemon
Score: 100
Status: offline
i would love the jet sprint or tear into which is the knock off but i am at college and will be home may 6 and go back to work may 12 and would liek a project to occuply my time when hoem before i work and the cracker is all i can find right now unless someoen has a hull tht the craker jet drive will work in
Hide Signatures
       Post #: 70
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 3:58 AM
blizzzarddemon
Score: 100
Status: offline
or if you know a hull that the jet drive will work in that i can get cheap ?
Hide Signatures
       Post #: 71
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 6:58 AM
headhunter23
Score: 100
Last Login: 3/10/2010
Status: offline
dude buy the ebay ndq fake jet sprint, it is literly the cheapest best way to jet boat, just swap motor n servo n batt with something from 2000's! Any other hulls are completely hit or miss. I've gone through 5 differnt hulls for jet drives, none have worked the way I wanted them too without modding the hell out of them. Heck im lookin for yet another hull for my 28mm kehrer... keep thinking yet another jet villain but i want the hull 4 in shorter than a villain.
Ivan.
Hide Signatures
       Post #: 72
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 8:23 AM
blizzzarddemon
Score: 100
Status: offline
the jet sprint no one has its out of stock everywhere
Hide Signatures
       Post #: 73
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 8:29 AM
damfurst
Score: 100
Status: offline
I agree with headhunter. I also just shot some of video of my knockoff but won't be able to post it until tomorrow. These pics are of the intake that I modified by opening up & then used a piece of exploded metal for grating. This boat rocks now.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 74
RE: Unofficial "NQD" Tear into Jetboat Thread - 4/18/2009 2:45 PM
DRAGONFIRE81M
Score: 100
Status: offline
found one so far but its in australia. http://www.stanbridges.com/index.cfm
here one in the uk http://www.zipsales.co.uk/ourshop/prod_323176-New-Remote-Control-Electric-Air-Jet-Racing-Boat-RC-RTR.html
< Message edited by DRAGONFIRE81M -- 4/18/2009 2:56 PM >
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
4.047RCU1
