RE: Unofficial    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: Unofficial
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Unofficial - 10/18/2009 6:38 PM
ryanwilson277
Score: 100
Last Login: 2/26/2012
Status: offline
i never knew you had to do that ( cut out the top )
Hide Signatures
(in reply to llDemonll)
       Post #: 151
RE: Unofficial - 10/18/2009 7:11 PM
nomobux
Score: 105
Last Login: 4/25/2013
Status: offline
which is best to order from ? raidentech or zhobby ? shp'g costs ? thanx
_____________________________
" I GOTTS NOMOBUX "
Hide Signatures
(in reply to ryanwilson277)
       Post #: 152
RE: Unofficial - 10/18/2009 9:50 PM
llDemonll
Score: 100
Last Login: 12/2/2011
Status: offline
they are both owned by the same company, so they should be the exact same. just add a boat to your shopping cart on each and check shipping costs from there and pick the cheaper one
Hide Signatures
(in reply to nomobux)
       Post #: 153
RE: Unofficial - 10/19/2009 4:24 AM
headhunter23
Score: 100
Last Login: 3/10/2010
Status: offline
Wrangle boy, I've tried the 5 min epoxy, no good, chips when hit. Did that with some automotive stuff too, same problem. You want something that holds yet has a bit of flex due to the hits you will implement on the boat. Go with goop, best thing is, it can be pulled out of boat if you ever pull drive out etc. No damage, but still need to do carefully and slowly. The epoxy stuff does not want to come out, u need to grind with dremel for some. If u ever pull out goop, grab needle nose, pinch and bit in the pliers and just rotate the pliers and it will come up off the plastic(or glass).
Ivan.
Hide Signatures
(in reply to wrangellboy)
       Post #: 154
RE: Unofficial - 10/19/2009 6:09 AM
westbeach
Score: 100
Last Login: 7/10/2012
Status: offline
Holy Sticks batman, Z-hobby is charging 75.00 to ship a 30.00 product to Canada! Raidentech is charging 30 to ship, which is reasonable I guess?? Someone said they're the same company? And they're both in Cali?
Hide Signatures
       Post #: 155
RE: Unofficial - 10/19/2009 6:37 AM
llDemonll
Score: 100
Status: offline
where in canada?
Hide Signatures
(in reply to westbeach)
       Post #: 156
RE: Unofficial - 10/19/2009 6:58 AM
westbeach
Score: 100
Status: offline
Abbotsford!
Hide Signatures
       Post #: 157
RE: Unofficial - 10/19/2009 7:13 AM
rockwerks
Score: 100
Last Login: 10/25/2009
Status: offline
Well I took one out today and stock they are a bit anemic to say the least. It was able to play in the waves though, some tweeking and it will be a ton of fun!
A few pics from today. sorry for the bad quality but the sun had already set
What bearing are you guys using to replace the bushing in this jet unit?
Hide Signatures
       Post #: 158
RE: Unofficial - 10/19/2009 7:18 AM
llDemonll
Score: 100
Status: offline
i regret not having driven mine as stock haha
if you want westbeach you can use some company (whatever's cheapest to ship from USA to CA) to calculate shipping to zip code 98229 (washington state) and ship it to me and i could "forward" it to you for maybe cheaper than what they want for shipping
Hide Signatures
(in reply to rockwerks)
       Post #: 159
RE: Unofficial - 10/20/2009 12:09 AM
ryanwilson277
Score: 100
Status: offline
hey rock works did u get a vid of it stock. the pics look like it got on plane
Hide Signatures
       Post #: 160
RE: Unofficial - 10/20/2009 4:12 AM
westbeach
Score: 100
Status: offline
quote:
ORIGINAL: llDemonll
if you want westbeach you can use some company (whatever's cheapest to ship from USA to CA) to calculate shipping to zip code 98229 (washington state) and ship it to me and i could ''forward'' it to you for maybe cheaper than what they want for shipping
Thanks for the offer Demon,
I am going to see what is going to be the best option in regards to shipping to Canada. will let you know. Thanks!
Hide Signatures
       Post #: 161
RE: Unofficial - 10/20/2009 7:24 AM
rockwerks
Score: 100
Status: offline
quote:
ORIGINAL: ryanwilson277
Yep it got up on Plane no problem, it moved at about 10-12 mph and handled quite predictably even with the stock radio equipment, sorry no video. I have the other one still in stock form and I will try to video it tomorrow
Hide Signatures
       Post #: 162
RE: Unofficial - 10/20/2009 7:25 AM
rockwerks
Score: 100
Status: offline
quote:
ORIGINAL: westbeach
quote:
ORIGINAL: llDemonll
Offer stands from me too. Im really close to Port Angeles and have been looking for an excuse to go see Victoria on the Island.
Hide Signatures
       Post #: 163
RE: Unofficial - 10/20/2009 9:22 AM
goldswim5
Score: 100
Last Login: 4/14/2010
Status: offline
Well I just ordered one of these babies from raidentech. Can't wait to get it and start playing around with it.
Hide Signatures
       Post #: 164
RE: Unofficial - 10/20/2009 4:49 PM
westbeach
Score: 100
Status: offline
Rockwerks,
Thanks for the offer too, maybe you can drive my NDQ over to the Island from Port Angeles. I might have to send out my DF Storm half way to meet up the little jet boat.
Cheers!
quote:
ORIGINAL: rockwerks
quote:
ORIGINAL: westbeach
quote:
ORIGINAL: llDemonll
Hide Signatures
       Post #: 165
RE: Unofficial - 10/20/2009 4:52 PM
westbeach
Score: 100
Status: offline
Rockwerks,
BTW, nice shots of your jet-surfing!! Is this hull prone to flipping over?
Hide Signatures
       Post #: 166
RE: Unofficial - 10/20/2009 8:08 PM
nomobux
Score: 105
Status: offline
Just ordered 2. I have a creek along the yard. It ranges in depth and is about 12 feet wide. Should be able to make a neat little course. I'll have about 150 of good vision upstream and rock obstacles along the way.
" I GOTTS NOMOBUX "
Hide Signatures
       Post #: 167
RE: Unofficial - 10/20/2009 8:29 PM
rockwerks
Score: 100
Status: offline
quote:
ORIGINAL: westbeach
Rockwerks,
It flipped over once that I had to receive it but in stock form the heaviest piece the battery pack sit right under the drivers in the top of the hull it is self righting in most cases. Im gonna try to video the other one in total stock form today after I get done working this afternoon
Hide Signatures
       Post #: 168
RE: Unofficial - 10/20/2009 8:33 PM
nomobux
Score: 105
Status: offline
quote:
ORIGINAL: rockwerks
quote:
ORIGINAL: westbeach
Rockwerks,
Self righting would be nice. How far from Gig Harbor are you ?
" I GOTTS NOMOBUX "
Hide Signatures
       Post #: 169
RE: Unofficial - 10/20/2009 11:35 PM
ryanwilson277
Score: 100
Status: offline
cool rockwerks i didnt know they got on plane stock. sothis video is wrong???????http://www.youtube.com/watch?v=9YfjwoT__dw&feature=channel
Hide Signatures
       Post #: 170
RE: Unofficial - 10/21/2009 1:13 AM
rockwerks
Score: 100
Status: offline
That appears to be about 1/2 throttle or less. I was getting some good air off of the waves with just a few feet of run up. Like I said after I get done with work today Ill see if I can con the wife into helping me get a video
Hide Signatures
       Post #: 171
RE: Unofficial - 10/21/2009 1:51 AM
wrangellboy
Score: 100
Last Login: 6/4/2012
Status: offline
Technically there is no 1/2 throttle on the stock setup. Mine was not proportional. I wouldn't be surprised if the factory has minimal (or no) QC and the folks in that video just got a bum boat.
Hide Signatures
       Post #: 172
RE: Unofficial - 10/21/2009 4:33 AM
ryanwilson277
Score: 100
Status: offline
ok cool. maby there batt was not fully charged. well im getting one soon!!
cant wait for vid!!!!
< Message edited by ryanwilson277 -- 10/21/2009 5:05 AM >
Hide Signatures
       Post #: 173
RE: Unofficial - 10/21/2009 7:07 AM
rockwerks
Score: 100
Status: offline
quote:
ORIGINAL: wrangellboy
Both of mine actually have decent control on both the steering and the throttle. I could cruise around with throttle control.
Hide Signatures
       Post #: 174
RE: Unofficial - 10/21/2009 7:11 AM
rockwerks
Score: 100
Status: offline
Well did not get to run today and have to be o the road all day tomorrow. but when I get home tomorrow night I will make up a 2/3A 9 cell nihm pack alot less weight than the stock pack, 30c discharge and 1600 mah. that should get it moving if it dont blow up the esc and stock motor LOL
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
