What gearing you running in your Brushless Slash?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> What gearing you running in your Brushless Slash?
Page: [1]
Login
What gearing you running in your Brushless Slash? - 9/27/2008 8:18:55 AM
Hordsak
Status: offline
What gearing are you guys using in your brushless slashes? I just bought a 3S lipo, and put it in my brushless slash with 26/83 gearing, and it's a freaking monster. I need to make a front spoiler to try to help it keep the front end down. I've also tried 23/83 and 21/83. I checked my motor temp with the 26/83 (street use only) and the max temp was 150. If I take it off road, I'll be running no taller than 21/83, probably 18/83.
       Post #: 1
RE: What gearing you running in your Brushless Slash? - 9/27/2008 4:10:42 PM
overrev
Status: offline
I run 15/86 in my novak powerd slash running 7 cell 5000 mah venoms. The temp after two packs is only 118 to 125. thats about a little over an hour run time.
Mike.
< Message edited by overrev -- 9/27/2008 4:37:16 PM >
(in reply to Hordsak)
       Post #: 2
RE: What gearing you running in your Brushless Slash? - 9/27/2008 5:05:12 PM
john01374
Status: offline
19/83 with a VXL system. run in a mix of dirt, short grass, concrete. If i was doing all offroad I'd go down to 18/83 or 18/87. If you're running a different motor your gearing might be different. The MM motors need smaller pinions to keep cool.
(in reply to overrev)
       Post #: 3
RE: What gearing you running in your Brushless Slash? - 10/21/2008 6:23:58 PM
piccorevo.26
Status: offline
im setting up a slash with the cc mamba max 7700, and maxamps 11.1 5000hv 3s ,what would be a good safe gearing option for this setup thanks ,....
(in reply to john01374)
       Post #: 4
RE: What gearing you running in your Brushless Slash? - 10/21/2008 6:25:15 PM
piccorevo.26
Status: offline
       Post #: 5
RE: What gearing you running in your Brushless Slash? - 10/22/2008 6:37:07 PM
john01374
Status: offline
Hordsak - I run 32 pitch gears at 58/13 which is pretty close to 19/83 in 48 pitch. Thats with a VXL system and my max temp is around 150F running on different terrian.
piccorevo.26 - You're gonna have a hard time keeping a MM7700 cool in a Slash. It's designed for touring cars and light buggies not a 4+ lb truck. If it where me I'd sell the 7700 and buy a Velinion motor to run on the Mamba ESC. If you a set on running the Castle Creations motors you need to drop down to a 4600 or 5700 max. The 7700 is also not designed to be run on 3S as you could exceed the maximum RPM of the motor. I have run them on 3S in a touring car but it was only for a couple of short speed runs. If you're going to try it then start with 12/90 and work your way up from there. I remember all the problems I had keeping a 5700 cool in a rustler.
< Message edited by john01374 -- 10/22/2008 6:38:59 PM >
(in reply to piccorevo.26)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU4
