Servo Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Servo Question
Page: [1]
Login
Servo Question - 9/30/2008 5:26 AM
ply2win
Score: 100
Last Login: 9/11/2010
Status: offline
I am having something strange happen with one of my servos that I have never seen before. I am using a 72mhz radio and if I extend the tx antenna when I am standing by the plane one of the aileron servos doesn't respond. When I move the stick nothing happens and then all of a sudden it will deflect by itself and then return to neutral.
The plane uses two servos for the wing and they are connected to the receiver using a y-harness. If I push the tx antenna back down then the servo works fine or if I leave it extended and just walk about 6 feet away from the plane it also seems to work fine. This is only affecting one of the aileron servos, the other one always operates normally.
Does it sound like the servo should be replaced or it is just interference from standing too close to the plane?
Hide Signatures
       Post #: 1
RE: Servo Question - 9/30/2008 5:45 AM
dignlivn
Score: 136
Last Login: 5/18/2013
Status: offline
If you have another servo try it.
Me, I would try a new servo. There is a
possibility of a dirt pot on the tx also. If
no joy with the new servo, then tx or rx
are suspects.
Hope that helps,
Bob
Hide Signatures
(in reply to ply2win)
       Post #: 2
RE: Servo Question - 9/30/2008 8:18 AM
Gray Beard
Score: 314
Status: offline
And if you have one try another Y, I have seen more problems with Ys then servos over the years.
_____________________________
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to dignlivn)
       Post #: 3
RE: Servo Question - 9/30/2008 9:31 AM
JohnW
Score: 100
Last Login: 6/21/2011
Status: offline
If it only happens when very close to the receiver, then there is a issue in the transmitter or receiver, i.e. overdriving the RX. I've actually seen this before on specific setups. Kinda wierd it is only one channel, so I doubt it is the TX/RX. but rather the servo. So if it happens all the time as I suspect, then it is probably a bad pot/wiring in the servo. If I understand your symptoms, I don't think a bad Y would cause the full defelction and return to neutral unless you moved the TX stick that way, but if I misunderstood your description, Y's or any connection for that matter can be sources of problems as greybeard pointed out.
Hide Signatures
(in reply to Gray Beard)
       Post #: 4
RE: Servo Question - 9/30/2008 11:13 AM
ply2win
Score: 100
Status: offline
I guess I was hoping that maybe this is a "normal" thing that sometimes happens. Like I said, if I don't have the tx right next to the plane the servo seems to work fine.
I did try a different y-harness and that didn't help so it sounds like the servo is bad. I will just go ahead and replace it, I don't want the aileron getting a mind of it's own during a flight.
Hide Signatures
(in reply to JohnW)
       Post #: 5
RE: Servo Question - 9/30/2008 5:39 PM
JohnW
Score: 100
Status: offline
OK, I don't know about "normal", but I have seen the issue before if it is only when close to the RX. In every case I have seen this there have been zero issues at range. Only acts up if within a few feet or so of RX. I don't know your radio, but there is a specific issue I can recreate on demand with a 9ZAP, synth module and PPM receiver that mimics this, but is effect all channels.
Try a differnet servo, or just swap channels. If the probelm follows the servo, it is a bad servo. If it stays with the channel, look at the RX. Do you have another RX to try? Maybe reroute the antenna?
Hide Signatures
       Post #: 6
RE: Servo Question - 10/1/2008 9:51 AM
ply2win
Score: 100
Status: offline
I plugged the servo into another channel and still had the same problem so I just went ahead and replaced the servo. It's working just fine now.
Thanks to all for the help.
Hide Signatures
(in reply to JohnW)
       Post #: 7
RE: Servo Question - 4/29/2009 7:33 AM
jackdunn
Score: 100
Last Login: 5/22/2009
Status: offline
I have run across some servos witth the wires cut off. They have one black and one red wires coming off the motot. and three white wires coming from the Pot. I've no idea how to connect up a connector to this. Can anyone suggest how to wire up thes servos?
Hide Signatures
       Post #: 8
RE: Servo Question - 4/29/2009 8:22 AM
sugarfox
Score: 100
Last Login: 11/10/2012
Status: offline
Jack, are you saying there are 5 wires coming out of the servo? What is the name of this servo? I have never seen such a thing. This has got to be some kind of special servo for something other than what we are doing................sugarfox
Hide Signatures
(in reply to jackdunn)
       Post #: 9
RE: Servo Question - 4/29/2009 8:36 AM
superflea
Score: 100
Last Login: 6/21/2009
Status: offline
If I understood him correctly, he is saying he has the normal wires coming out of the servo itself, but the wires have been cut at some point in time and have since been fixed with three white wires soldered in place so instead of red black yellow, as on my hitec servos he has white white white.
Don't know why he didn't just start a new thread though.
Hide Signatures
(in reply to sugarfox)
       Post #: 10
RE: Servo Question - 4/29/2009 10:25 PM
Stick 40
Score: 103
Last Login: 11/21/2012
Status: offline
quote:
ORIGINAL: jackdunn
Are you saying , you have the servo apart and are looking at the inside of it.
Like said before , you would get more help if you started a new thread. Go back to the main pape and click on "new post"
Then enter your question, not a problem just thought you would get more help that way.
good luck
sticks
"born to fly, bound to crash"
Hide Signatures
       Post #: 11
RE: Servo Question - 4/29/2009 11:51 PM
-pkh-
Score: 167
Last Login: 12/8/2011
Status: offline
Not sure why the antenna position would cause the problem. I have seen bad servo extensions or y-connectors make the servo overshoot and return to the proper position (pretty freakin' scary if it happened while you were flying).
Paul - Helis: Two Raptor 50V2s, Venture 30CP, Blade CX2
Planes: Twist 60, Tribute 36, Two PZ BL P51s, Two F27C Strykers
Hide Signatures
(in reply to Stick 40)
       Post #: 12
RE: Servo Question - 4/30/2009 5:07 AM
Gray Beard
Score: 314
Status: offline
A standard servo cost from $9.00 to about $15.00, give some thought to just tossing these servos and get something that hasn't been changed or worked on, it may be cheaper then a new plane?
Hide Signatures
(in reply to -pkh-)
       Post #: 13
RE: Servo Question - 4/30/2009 5:34 AM
j.duncker
Score: 121
Last Login: 5/19/2013
Status: online
I have had the same problem when using 5 cell rx packs that are fresh off charge. Wiggle the controls a few times and it goes away. Futaba 9C Tx and GMS Rx.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
       Post #: 14
RE: Servo Question - 5/22/2009 7:29 AM
expo
Score: 100
Last Login: 5/16/2013
Status: offline
I  had servos with this wire arrangement on an old Aerobird Challenger electric from Horizon Hobby.   The 3 white wires were nested together.   These servos won't work with a standard RX since the Aerobird had a circuit board, not a standard RX for control.   All there is inside is a motor.
Practice safe dining...use condiments
Hide Signatures
(in reply to j.duncker)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.764RCU1
