Did you use right thrust on your 35% sukhoi
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> Did you use right thrust on your 35% sukhoi Page: [1]
Login
Did you use right thrust on your 35% sukhoi - 10/1/2008 3:35:35 AM
husafreak
Status: offline
I am ready to mount a ZDZ 80 on my 102" Sukhoi, should I build in right thrust, I think it will need it so what did you guys that have them flying do?
       Post #: 1
RE: Did you use right thrust on your 35% sukhoi - 10/1/2008 6:10:32 AM
Barry Cazier
Status: offline
I added about 2 washers worth on mine. I'm flying with a DA100. Seems about right but if I let it build up a bit of speed in a vertical climb it stills pulls to the left. But it's manageable. It hovers nicely and does everything I ask of it. But you'll need some RH thrust in it.
thanks
Barry
(in reply to husafreak)
       Post #: 2
RE: Did you use right thrust on your 35% sukhoi - 10/1/2008 6:22:22 AM
Eagleburger
Status: online
I have 2-2 1/2deg in all mine. I would put in 2 and go from there. I had a 60size pattern ship years ago that was zero deg on everything, I ended up putting right thrust after one day. you can never have the perfect amount of right thrust for all situations, but 2 1/2 seems to be the closest.
(in reply to Barry Cazier)
       Post #: 3
RE: Did you use right thrust on your 35% sukhoi - 10/1/2008 6:31:23 AM
Tired Old Man
Status: offline
What kind of flying is your primary interest? Fun flying and 3D? Then no right thrust. IMAC you're thing? Then about 1/2 degree or so of down and right may be what you want. Those that fly the upper levels of IMAC may prefer the zero-zero installation.
_____________________________
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to Eagleburger)
       Post #: 4
RE: Did you use right thrust on your 35% sukhoi - 10/1/2008 7:09:08 PM
sailing1
Status: offline
Mine ended up about a degree of right thrust and 1/2 degree of down thrust, but I only put that in after I flew it a few times. It flew just fine without any thrust adjustment but was a little better for IMAC type flying after adding the washers. I'm not a real big fan of putting something extra into the design unless I have tried it first. I figure designer should get it pretty close to start with.
(in reply to Tired Old Man)
       Post #: 5
RE: Did you use right thrust on your 35% sukhoi - 10/1/2008 11:17:59 PM
flatspinjim
Status: offline
Mixing a little right rudder to throttle is a great way to go also. More throttle, more rudder
Why did kamikaze pilots wear helmets??
(in reply to sailing1)
       Post #: 6
RE: Did you use right thrust on your 35% sukhoi - 10/2/2008 7:00:59 AM
Tired Old Man
Status: offline
flatspinjim,
Your method is a lot easier to reverse mix out, especially if the reverse of one input is less in the second direction. As an example only, mixing 2% right or left rudder for a power on upline while using a zero degree rudder mix on a power off downline. Using an offfset engine thrust line will always have an effect on a power off downline due to residual thrust developed with a windmilling prop.
(in reply to flatspinjim)
       Post #: 7
RE: Did you use right thrust on your 35% sukhoi - 10/7/2008 1:37:08 PM
colled
Status: offline
I agree, no offset added to mine just mixed it out so straight in up as well as down lines.
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU4
