ErlendM
Joined: 11/7/2007 From: Uskedalen, NORWAY Status: offline
I''m still here! I haven''t had the maiden flight yet, due to some technical problems. The onboard-starter from Fema turned out to be too weak to my engine, so I decided to remove it. I then discovered that because of long fuel-tubes due to me putting a DuBro quick-fill-walve placed in the bottom of the fuselage, I got problems in priming the engine without choking the carb with my finger. This is of course not possible with the cowling on, so I had to look for an external choke-assembly. I found a couple, one for an OS120 and one for an ASP120. I have a SC180 (ASP180 is the same engine), and I bought both the choke-assemblies to see if I could use either one of them. I have to modify them a bit but I think this will do. I have also bought a Perry-pump which I will install as well to secure the fuel-flow, although I havent had any problems running the engine on the ground. Just to add extra security... I got the last items a couple of days ago, but due to many family-affairs this month, I''m grounded until May :-) That was a situation-report from Erlend!
_____________________________
Erlend Moen Folgefonn RC-klubb, Norway
