Building the Hangar 9 Cessna 182 Skylane
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> Building the Hangar 9 Cessna 182 Skylane
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 7:14:57 AM
AndyF
Status: offline
I just got my Hangar 9 Cessna 182 Skylane. It is truly beautiful.
I'm pretty sure but not quite, but I think I'm going to use the RCS 180 Gas Engine on it. It looks like it will fit.
I will post pictures in a little while.
If anybody else got their's, chime in.
Andy
< Message edited by AndyF -- May 25 2003 4:54AM >
_____________________________
[size=2][color=blue]Nothing focuses the mind like the threat of a hanging or loose wing bolts.[/color][/size]
       Post #: 1
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:17:47 PM
AndyF
Status: offline
I just unpacked everything and I must say that this airplane is in much better shape that my GP Patty Wagstaff Extra 300. There is virtually no damage to this aircraft. The only minor damage that I found was in the vertical piece of balsa on the fin that was snapped, but a little CA it will be fine.
This truly is a fine kit. Hangar 9 has done an outstanding job of paying attention to details. There are a lot of scale features. This thing even has velour covered seats! and a fully painted interior.
It is magnificent!
Attached are the pictures of its unboxing.
Andy
Click to see fullsize image.
Click for fullsize
(in reply to AndyF)
       Post #: 2
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:18:26 PM
AndyF
Status: offline
Opening the box
Click for fullsize
(in reply to AndyF)
       Post #: 3
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:19:07 PM
AndyF
Status: offline
Looking at the parts
Click for fullsize
(in reply to AndyF)
       Post #: 4
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:20:03 PM
AndyF
Status: offline
Looking at the accessories
Click for fullsize
(in reply to AndyF)
       Post #: 5
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:20:51 PM
AndyF
Status: offline
Fuse side view
Click for fullsize
(in reply to AndyF)
       Post #: 6
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:21:38 PM
AndyF
Status: offline
Fuse top view
Click for fullsize
(in reply to AndyF)
       Post #: 7
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:22:11 PM
AndyF
Status: offline
Fuse front view
Click for fullsize
(in reply to AndyF)
       Post #: 8
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:22:50 PM
AndyF
Status: offline
Cowl and seats
Click for fullsize
(in reply to AndyF)
       Post #: 9
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:23:27 PM
AndyF
Status: offline
Cowl side view with seats
Click for fullsize
(in reply to AndyF)
       Post #: 10
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:24:15 PM
AndyF
Status: offline
Me and my Fuse
Click for fullsize
(in reply to AndyF)
       Post #: 11
Building the Hangar 9 Cessna 182 Skylane - 5/25/2003 11:27:13 PM
AndyF
Status: offline
That is all the pictures I have for now. As I start working on it I will post more pictures. I will tell you that I am very particular about my airplanes and this one truly meets my high standards.
Based on what I have seen so far, I would recommend this to anyone who has a love for the 182.
Andy
(in reply to AndyF)
       Post #: 12
Building the Hangar 9 Cessna 182 Skylane - 5/26/2003 9:22:21 AM
sj3cub
Status: offline
Hi Andy,
I also have very high standards with my models. I could'nt agree
more that this is one beautiful model. I am about half way done
with mine. It goes together very fast and everything fits precise.
What are you going to power yours with. I'm trying to decide if
a 120 4-stroke will be enough.
Scott
(in reply to AndyF)
       Post #: 13
Building the Hangar 9 Cessna 182 Skylane - 5/26/2003 9:47:41 PM
AndyF
Status: offline
Hi Scott,
I am having that same debate with myself right now.
This is what I have considered so far. The main problem being the discrepancy in the weight of the plane. The Instruction Book says 16.5 to 18.5 LBS the website says 13 to 16 lbs.
A Saito 180 develops 1.85 HP
I have an OS 160 Gemini twin that says it will develop 1.9 HP
An RCS 140 gas engine develops 2.95 HP and develops 15.62 lbs of static thrust. Its displacement is 22 cc which is one less than recommended
An RCS 180 gas engine develops 4 HP, its displacement is 30 cc which is below recommend max.
RCS makes the 180 in both rear induction and front carb models, I have not checked the distance from the fire wall to the front of the cowl, but the rear induction motor is 7.3 inches long and the front carb version is 5.75".
I am lean toward gas be cause I know that I will have the extra power that might get me out of a problem and I can always throttle back to achieve scale like flight, but I am still undecided as to which to go with.
The 120 will have even less power and I guess if you keep it light it should fly well. My major concern about the 182 is that it is so wide it is like flying a bus so it may need more HP to haul it around the sky.
Have you looked at anything else at this point? I'm leaning toward the RCS 180 and once I measure the distance from the firewall to the front of the cowl I will make my decision.
Post some pictures if you have them. I'm sure there must be a bunch of guys building this airplane that would love to see them.
Andy
(in reply to AndyF)
       Post #: 14
Building the Hangar 9 Cessna 182 Skylane - 5/26/2003 9:55:34 PM
