RE: GAS/GLOW HOW TO....    Gallery
Logged in as Guest
    Search This Thread
Printable Version
O.S. Engines O.S. FT-300 Twin
Seller:  thunderbolt-RCU
Details:   $600.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: GAS/GLOW HOW TO....
Page: <<   < prev  11 12 [13] 14 15 16 17 18 19 20   next >   >>
Login
RE: GAS/GLOW HOW TO.... - 2/4/2011 11:26 PM
av8tor1977
Score: 665
Last Login: 5/19/2013
Status: offline
No problem. I totally understand!
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to fujiman)
       Post #: 301
RE: GAS/GLOW HOW TO.... - 2/5/2011 11:10 PM
dadandlad
Score: 100
Last Login: 2/8/2011
Status: offline
So if you wanted to you could start the engine and run it in reverse with no adverse effect with it being piston ported.
Also with the magneto/fan removed do you need a flywheel to aid tickover
Can anyone also provide me with details of a marine flywheel i:e the starter belt groove,as you may have summised my engine is going to be fitted in a boat
Cheers Mark
Hide Signatures
(in reply to av8tor1977)
       Post #: 302
RE: GAS/GLOW HOW TO.... - 2/5/2011 11:45 PM
w8ye
Score: 318
Status: offline
I don't remember what engine you have but the grooved flywheels are available for the Zenoah marine engines. You may could use one on your engine?
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.1359/.f
These are designed to use with a Vee Belt and a Sullivan starter. The belt after starting the engine lays about the pully/shaft but remains dormant.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to dadandlad)
       Post #: 303
RE: GAS/GLOW HOW TO.... - 2/6/2011 2:38 PM
av8tor1977
Score: 665
Status: offline
The only problem one encounters with running them reversed is that the flywheel nut is usually normal right hand thread. When we use them in an airplane with a propeller, the nut will often come loose when running reversed. The power pulses act like an air hammer, loosening the nut.
AV8TOR
Hide Signatures
(in reply to w8ye)
       Post #: 304
RE: GAS/GLOW HOW TO.... - 2/6/2011 9:38 PM
the Wasp
Score: 110
Status: offline
av8tor1977
what about E85/,, my friend ask me about Mixing 2 Parts E85 and 1 Part straight Methanol for a Super Tartan 44cc Twin (still a lot of these Twins out there)
these Super Tartan Engines have a 11:1 Compression Ratio and I'm wondering if the Ethanol will Pre-ignite ??
Jim
Hide Signatures
       Post #: 305
RE: GAS/GLOW HOW TO.... - 2/7/2011 1:18 AM
av8tor1977
Score: 665
Status: offline
I tried E-85 when we started this whole Gas/Glow thing, and didn't have much luck with it. It is methanol that causes the catalytic reaction that keeps the glow plug lit, and E-85 is ethanol. Didn't work well for me.
AV8TOR
Hide Signatures
(in reply to the Wasp)
       Post #: 306
RE: GAS/GLOW HOW TO.... - 2/7/2011 5:31 AM
aero nut
Score: 100
Last Login: 4/1/2013
Status: offline
Hi Robert!!! but they are going to replace the gasoline with E85 and use 1/3 METHANOL I think it should work, I used straight E85 with plug always lit it worked but les RPM then Gas/Glow.
Hide Signatures
       Post #: 307
RE: GAS/GLOW HOW TO.... - 2/7/2011 8:35 AM
WILLIAMSPC
Score: 100
Last Login: 4/17/2013
Status: offline
Dose anyone know where i can get a hub replacement for the flywheel and prop adapter for a sthil 26cc. it has a tapered shaft that is keyed
Mike
Hide Signatures
(in reply to aero nut)
       Post #: 308
RE: GAS/GLOW HOW TO.... - 2/7/2011 9:01 AM
fujiman
Score: 103
Status: offline
hi mike, PM me or reach me at hyperdude64@yahoo.com i can help you out.
Hide Signatures
(in reply to WILLIAMSPC)
       Post #: 309
RE: GAS/GLOW HOW TO.... - 2/8/2011 2:13 AM
WILLIAMSPC
Score: 100
Status: offline
Thank you fujiman I sent you an email
Mike
Hide Signatures
       Post #: 310
RE: GAS/GLOW HOW TO.... - 2/11/2011 8:16 PM
Beechbum
Score: 100
Status: offline
I got an adapter from fujiman. Good stuff!
I'm trying to find methanol locally. The best I can do is 117 bucks for five gallons at a chemical supply house. Anyone have good luck with HEET?
Hide Signatures
       Post #: 311
RE: GAS/GLOW HOW TO.... - 2/11/2011 9:05 PM
spaceworm
Score: 143
Status: offline
I get mine form a local speed shop for $5.00 a gallon in my jug. It has a small amount of undefined oil, I guess to keep cylinders of engines from rusting. I mix it with Klotz Tecniplate syn plus castor for FAI fuel for my ASP hi comp engines. Works great.
Try speed shops or motorcycle or go kart racing shops or tracks or drag strips.
Sincerely, Richard
Hide Signatures
(in reply to Beechbum)
       Post #: 312
RE: GAS/GLOW HOW TO.... - 2/14/2011 3:05 PM
Beechbum
Score: 100
Status: offline
Local speed shop wants 160 a barrel.
Back in the day I used to work at an automotive machine shop. I swung by and talked to the owner and he hooked me up with a local nostalgia drag racer. He is gonna spot me a few gallons to see if I can get this to work. As soon as I get a test stand built up I'll give it a go. Maybe this weekend.
Edit to add:
I forgot to ask about how much residue is in the exhaust for this mix?
Hide Signatures
(in reply to spaceworm)
       Post #: 313
RE: GAS/GLOW HOW TO.... - 2/14/2011 3:51 PM
spaceworm
Score: 143
Status: offline
The residue would be the same as for the equalivalent percent of oil you have been using. I like and use a mix of syn and castor to a total of 20% oil for my hi compression 2 stroke glow engines. All synthetic or lower oil % will reduce the castor accumulation on the airframe. To me, a wipe down after flight is worth it to keep my engines happy.
You may be able to get nitro from your nostalgia drag race contact, bur I am trying to loose the use of nitro myself.
I am going to try the speed shop methanol on a gas-glow 16 cc Echo 2 stroke gas engine to see if I can use no nito for that also. I will mix the methanol 1 part to 2 or 3 of gasoline and add Pennzoil air cooled 2 stroke oil to a 1 to 32 mix. If glow plug ON for either just for start, or full time, doesn't work, I may reveret to the tried and true gas-glow fuel or go to ECDI and just gasoline.
Good luck with your projects. Keep us informed.
Sincerely, Richard
Hide Signatures
       Post #: 314
RE: GAS/GLOW HOW TO.... - 2/14/2011 5:12 PM
av8tor1977
Score: 665
Status: offline
Using the normal Gas/Glow mix, the oil content comes out to about 32:1. I don't see any more residue on the airplanes than I do with regular gasoline setups, which is to say almost nothing...
AV8TOR
Hide Signatures
       Post #: 315
RE: GAS/GLOW HOW TO.... - 2/17/2011 4:37 PM
Beechbum
Score: 100
Status: offline
Thanks.
Does a normal gas fuel tank and fuel lines work, or are you using something else? It's been a while since I read thru the thread and can't remember if that was mentioned or not.
Hide Signatures
       Post #: 316
RE: GAS/GLOW HOW TO.... - 2/17/2011 6:26 PM
av8tor1977
Score: 665
Status: offline
I use the same tank, stopper, and fuel lines I would use for a normal gasoline setup, which is to say Tygon and/or Viton.
I do use a special "Storage Fuel" however. You can look that up with a search here in the forum. I use this with BOTH my gasoline and Gas/Glow setups. I drain the normal flying fuel out, whichever type it is, and then fill the tank about half full with my Storage Fuel which is Coleman fuel mixed at 20 to 1 with Pennzoil for Air Cooled engines and a small amount of STA-BIL fuel conditioner/stabilizer. I then run the engine at varying throttle settings for a bit and then choke it to kill it. (You will probably need the glow power on for doing this.) Then leave the fuel in the tank until the next time you are ready to fly. Then remove it, fill up with Gas/Glow, and you are ready to go.
I was having serious carb problems in as little as six weeks time on my regular gasoline planes. My Storage Fuel idea virtually stopped this problem, and I now do it on all my planes, whether they are Gas/Glow or regular gasoline setups.
Note that I do not recommend flying with Coleman fuel in any case. Yes, I know that some people do so, but I still do not recommend it.
AV8TOR
Hide Signatures
       Post #: 317
RE: GAS/GLOW HOW TO.... - 2/17/2011 8:34 PM
Beechbum
Score: 100
Status: offline
Sounds like a good idea. If I don't go out of town on Saturday I'm going to give it a whirl.
Hide Signatures
       Post #: 318
RE: GAS/GLOW HOW TO.... - 2/17/2011 8:58 PM
Flight Risk
Score: 108
Last Login: 5/15/2013
Status: offline
Don't forget that if you use a fuel pump, it needs to be compatible with gas also.
RS
Just Fly It.
Hide Signatures
       Post #: 319
RE: GAS/GLOW HOW TO.... - 2/22/2011 4:33 AM
Beechbum
Score: 100
Status: offline
Well I didn't get to run it, but I did get the carb to finally draw fuel. Its brand new and just wouldn't pull anything out of the tank. Spent all my free time getting it to work, and by time it did it was dark outside. I'll give it a shot Tuesday. The bad part is I don't even know what I did to get it to go!
Hide Signatures
(in reply to Flight Risk)
       Post #: 320
RE: GAS/GLOW HOW TO.... - 2/22/2011 6:19 AM
fujiman
Score: 103
Status: offline
hi richard, the needle may have been stuck. sometimes it takes a while for the carb. to prime up and purge out the air. that's why some chain saws and other yard equip. engs./fuel systems use those primer bulbs on the carb. or in the inlet fuel line. hope that helps. let me know how the adapter i made you, worked out for you too.
Hide Signatures
       Post #: 321
RE: GAS/GLOW HOW TO.... - 2/22/2011 6:33 AM
av8tor1977
Score: 665
Status: offline
Yeah, dry carbs can be a pain sometimes. When I am setting up an engine, I almost always pull the carb apart to check it, even if it is new. Besides checking to be sure the needle isn't stuck, upon reassembly, I flood each section of the carb with WD-40. Then the carb always draws fuel immediately. It is only 5 screws and a few minutes time to do this, and it can save an hour of frustration if you end up having problems.
AV8TOR
Hide Signatures
       Post #: 322
RE: GAS/GLOW HOW TO.... - 2/22/2011 6:45 AM
fujiman
Score: 103
Status: offline
a ''LITTLE'' prime down the throat of carb. works also. with eng running it operates the pump faster than just hand proping.
Hide Signatures
       Post #: 323
RE: GAS/GLOW HOW TO.... - 2/22/2011 2:09 PM
Beechbum
Score: 100
Status: offline
Fujiman, I really like the plug adapter. It's a nice piece of work.
Yeah to all the above. I think the problem was in the diaphragm. After I got it out and wet it up with a little fuel things began to move.
I'm like a kid at Christmas, can't wait to fire it up.
Hide Signatures
       Post #: 324
RE: GAS/GLOW HOW TO.... - 2/22/2011 5:25 PM
fujiman
Score: 103
Status: offline
thanks a bunch beechbum!!!!!!! you guys keep pitch'n this gas to glow thang i just mite have to turn one of these adapters and give'r a go. HHHHHHMMMMMMM!!!!!!!! no mag., no expensive ign. system, no fus'n with timing, lighter eng. weight, a tad more power!!!!!!! i'm sold, out to the lathe and i be cutt'n me own. let's see 1 part glow fuel (10/10%), 2 parts pre'mo gasoline, a touch of Heet and acetone just for luck, my, my, even the fuel should be cheaper, even with $5.00 + a gal. gas!!!!!!!
Hide Signatures
       Post #: 325
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: GAS/GLOW HOW TO....
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
