RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/4/2008 8:28 PM
werdonmorris
Score: 100
Last Login: 3/3/2010
Status: offline
All Captains
I tried a couple of times to get the following pictures posted, maybe it will take this time.
Butch
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to soundguykaraoke50)
       Post #: 51
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/4/2008 10:05 PM
werdonmorris
Score: 100
Status: offline
Soundguykaraoke50
Thank you very much, the parts came today.
Butch
Hide Signatures
       Post #: 52
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/4/2008 11:47 PM
soundguykaraoke50
Score: 100
Last Login: 7/29/2009
Status: offline
i still have a fuel tank for you,plus another motor,same make bigger bore.this is the 30cc john deer/home-lite.it also has the same cluch system,this is the newer setup.
i like the strakes that you did,looks great.
Hide Signatures
(in reply to werdonmorris)
       Post #: 53
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/5/2008 3:34 AM
werdonmorris
Score: 100
Status: offline
Soundguykaraoke50
Thank you, I was not sure if I wanted to do it like what I saw in the plans. I decided to do it my design, and I like it much better.
Also, I already installed the parts you sent, and with a little adjusting here and there. The flex cable moves real well, with very little friction, and no binding what so ever.
In the morning, I plan to send out a letter of thank you. Can hardly wait to see the other parts, I feel like a kid in a ice cream shoppe.
Butch
Hide Signatures
       Post #: 54
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/5/2008 12:38 PM
soundguykaraoke50
Score: 100
Status: offline
there's no need to go through all that,i am happy to be able to send these to you.love to see when a project comes together.the next major part that i forgot to send is the water-cooling kit for your home-lite.i found this and just forgot to pack it in the last shipment.i will pack this and some other parts that you could maybe use later today and put this in my car,that way if i go by the post office and there's not a line out the door[Christmas shippers] it will go out this weekend.
thanks,
tony
Hide Signatures
       Post #: 55
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/5/2008 3:00 PM
werdonmorris
Score: 100
Status: offline
Soundguykaraoke50
Check you PM, I sent you a couple you should read!!
Butch
Hide Signatures
       Post #: 56
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/6/2008 2:53 PM
werdonmorris
Score: 100
Status: offline
SoundGuyKaraoke50
Be prepared for a very tasty morsel heading your way in the mail, in a day or two-ENJOY
butch, Your Loyal Friend
Hide Signatures
       Post #: 57
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/9/2008 1:39 PM
werdonmorris
Score: 100
Status: offline
Soundguykaraoke50
Did you receive the small box I sent you, it was the same box you used to send me the great parts. but It had my wife's homemade cookies in it for you.
Please let me know.
Butch
Hide Signatures
       Post #: 58
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/9/2008 2:01 PM
werdonmorris
Score: 100
Status: offline
All Captains
Today, I shall work on the second cabin, and layout all the wood, with the plans in my head. This boat was not designed with what I have done so far. It was suppose to look like a typical scarab, but I see to many look a likes. I wanted something different, then any boat ever built. I did not sit down and draw a new set of plans, or draftings. It is all stored in my head, with a a full vision of what it will look like.
This is the cabin that will be able to remove, at a moments notice to start or work on. I was going to use real strong magnets to hold it in place, but I contacted DUZ Fasteners and they sent me a couple of samples to study. They are strong, and yet will be almost hidden from view.
Plus I have a cooling design in my head for the cooling of the exhaust, with water cooling, and a small fan. Also, there will be a small fan forward to draw in air, and one aft to exit all the hot air.
Will send pictures to this post when some what done.
Hide Signatures
       Post #: 59
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/13/2008 6:21 PM
werdonmorris
Score: 100
Status: offline
Rich404-Soundguykaraoke50
I received a gas tank from my friend soundguykaraoke50, and added my little touch to it.
Also, I finished putting the interior walls on the berth cabin, I will be adding a special frame to house the main cabin.
Have been under the weather, my grandson has given me some kind of cold, who knows, love the little guy.
Here is some pictures for you to check out, a lot more later.
Butch
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 60
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/13/2008 6:29 PM
werdonmorris
Score: 100
Status: offline
CONTINUED=
If you have not noticed, I used a old inhaler for the gas neck, and cap. The line input & output was where the new gas fill is, I simply drilled a new correct size hole.
There is a small hole in the cap, this is where a brass tube will go, to filter the fumes out of the hull, and provide proper venting with a one way valve.
The valve will let the fumes out, but keep the water out, and to prevent the gas being sucked out, as air passes over the tube.
Hide Signatures
       Post #: 61
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/13/2008 6:34 PM
soundguykaraoke50
Score: 100
Status: offline
it looks like its all coming together,i admire your atention to the little details that most modle boaters forget to do.keep up the good work,in the long run you will have a real tresure after you complete this project.check out my new project on the gas/speed section.i was digging in the endless boxxes of parts and came up with some interesting stuff for the deep vee that i am starting to build.
your buddy,soundguykaraoke50,aka,tony
Hide Signatures
       Post #: 62
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/15/2008 4:49 PM
soundguykaraoke50
Score: 100
Status: offline
butch, i found a link you could find some very helpfull information about the motor that you are using.good reading if nothing else.
http://testfly.0catch.com/homelite/homelitemain.html
this site will help you do the watercooling on the head.plus there are ways to make these motors more powerful.most of the stuff on the site is going to be very useful to you.
< Message edited by soundguykaraoke50 -- 12/15/2008 4:53 PM >
Hide Signatures
       Post #: 63
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/15/2008 10:21 PM
Rich404
Score: 100
Last Login: 3/11/2010
Status: offline
Hi Butch,
As always, you are doing a fine job on your boat! Your gas tank is looking very realistic and is well thought out.
-Rich.
Hide Signatures
       Post #: 64
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/15/2008 10:30 PM
werdonmorris
Score: 100
Status: offline
all captains
Thank you for your kind words, will be doing more on tue or wed, of this week, been under the weather, but staying strong.
Butch
Hide Signatures
(in reply to Rich404)
       Post #: 65
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/16/2008 2:47 PM
soundguykaraoke50
Score: 100
Status: offline
i hope that you are feeling better.lots of rest is always the best thing you can do.stay warm and don't get stressed out.
hang in there butch,
tony
Hide Signatures
       Post #: 66
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/16/2008 4:51 PM
Rich404
Score: 100
Status: offline
Hi Butch,
An old reliable remedy is Whiskey....Kills the germs and works better than cough syrup.
Feel better buddy!
-Rich.
Hide Signatures
       Post #: 67
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/17/2008 9:42 AM
werdonmorris
Score: 100
Status: offline
Thanks guys, my wife has really took to getting me well, and have been staying in bed. Will try the drink.-butch
Hide Signatures
       Post #: 68
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/17/2008 9:48 PM
soundguykaraoke50
Score: 100
Status: offline
Butch,i hope all is well for you.i wish i had a wife to nurse me back to health,but then i would have to give up some of my babys[boats].lol i think that i am in over my head in the remote control boat department.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 69
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/17/2008 9:54 PM
soundguykaraoke50
Score: 100
Status: offline
and those pictures are what it looked like last year.it has gotten a lot worst than this,but my little doggies dont care as long as they have a place to lay around.just this week i added three more to the fleet.i did sell off a couple of my babys earlyer this year.my buddy says i am out of control,i think that i have a control for every boat i own.i just dont understand him,
< Message edited by soundguykaraoke50 -- 12/17/2008 9:55 PM >
Hide Signatures
       Post #: 70
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/17/2008 10:10 PM
werdonmorris
Score: 100
Status: offline
soundguykaraoke50
Feeling much better today enough to check out a few ideas in my head, but I am not going to rush it.
You have quite a excellent fleet, and vast.
I also noticed you are somewhat into four wheeling, looks like a truck or a jeep.
Hide Signatures
       Post #: 71
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/17/2008 10:21 PM
werdonmorris
Score: 100
Status: offline
Next wed., have to go to the wife's family xmas, and thet do the same thing each year. showing off there new cars, clothes, who's the sexy dresser, and so on.
I sit in the game room, watch tv, or play pool with my son, got to let my wife see her sister's. Otherwise, they just do not come around. They owe, off to work they go, to to play the jones
butch
Hide Signatures
       Post #: 72
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/19/2008 1:03 PM
soundguykaraoke50
Score: 100
Status: offline
Butch.
,how are you feeling lately,i hope your not out there shoveling snow.i hate winter,i am using the time well though,i just bought a quick-draw 35cc motor to go into a 58 catamaran.this should be a 60-65mph sport boat,i bought the motor here in the classifieds,these motors are supposed to put out 8.5+ horse-power.i will shoot some pictures water next week
hope all is well and you wife is doing good,never got the cookies yet,i hope the guys at the post office didn't eat them ,i am sure glad that these holidays are almost over.
if i don't here from you,you and the wife have a happy holidays
tony
Hide Signatures
       Post #: 73
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/19/2008 2:59 PM
soundguykaraoke50
Score: 100
Status: offline
this is the link to the add on this motor i bought,i bought everything but the hull,i told him to trash the hull,looked beatup to me.this will be here tomorow via fedex,i got a great deal on all these parts,plus i have a new 58 bright yellow cat hull to put all these parts in.
http://www.rcuniverse.com/market/item.cfm?itemId=463896
Hide Signatures
       Post #: 74
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 12/20/2008 2:34 PM
werdonmorris
Score: 100
Status: offline
soundguykaraoke50
I took alook at the boat, at the parts are great, and should make yours scream with desire.
Yes, the hull looked shabby, but leave me to and I bet I could make it worth while.
Keep your eyes open, looking for a project to do while conserving the big boat for further experiments.
butch
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.174RCU1
