RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/15/2009 4:28 PM
Rich404
Score: 100
Last Login: 11/21/2009
Status: offline
Hi Butch,
Cool! I can't wait to see it!
Happy building!
-Rich.
Hide Signatures
(in reply to werdonmorris)
       Post #: 101
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/17/2009 3:39 AM
werdonmorris
Score: 100
Last Login: 11/15/2009
Status: offline
Well, I finished testing the homemade tornado today, after much trial and error.
I first started with a six blade assembly, and it restricted the 1/2 pvc elbow, so then I tried a larger pvc straight nipple and no difference.
So then I went to a five blade assembly, and it restricted, but improved performance by a whole 2%.
Then I was watching my son put together a model car, and it went bingo.
I took a five blade offset fan from one of my scrap bins for models, and bent the blades to a 22 degree angle. Then I opened up the elbow by 1/32, just to the center, and glued
the fan in the center.
There was now restriction, and the % jumped to 8%, more low end torque, and better throttle response, with a slight stumble at first.
So then I put on the k&n filter specially made for my boat, and there was no stumble upon a very fast kick in the throttle, and you could hear
the big difference.
Here is some pictures of the homemade tornado, and the k&n filter.
Butch
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Rich404)
       Post #: 102
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/17/2009 3:44 AM
werdonmorris
Score: 100
Status: offline
The filter is the size of a small medicine bottle. I bought from Rite Aid a empty medicine bottle.
The filter will go inside the bottle, with bottom being cut out, and place at the income air vent,
at the front of the first cabin.
Butch
Hide Signatures
       Post #: 103
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/19/2009 5:49 AM
werdonmorris
Score: 100
Status: offline
Rich
I did some further testing, in another direction with the air flow issue. I was at the gun range this weekend, and when I cleaned the barrel.
I remembered they have put in grooves to put spin on the bullet for farther distance, and more precise hitting of target.
Going to try a few tests, with a a plastic mock-up, with a 1/16" wide x 1.5" long that will spiral down the tube, and see what happens.
Hide Signatures
       Post #: 104
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/19/2009 9:06 PM
Rich404
Score: 100
Status: offline
Hi Butch,
Here is a test that may help you.
Perhaps, run a test using your tornado attached to one end of a clear plastic cylinder tube. The tube should be 2-3" long at most. Attach a vacuum to the other end of the clear tube and burn a cigarette or some incense before the tornado. The cigarette or incense can be in a ashtray or similar when you do the test. All you want is the smoke. If the tornado is working as planned, the smoke should spiral in the clear tube before being sucked into the shop vac hose. This will help you get a good picture how air will move through the tornado.
Give it a try.
-Rich.
Hide Signatures
       Post #: 105
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/22/2009 12:50 PM
soundguykaraoke50
Score: 100
Last Login: 7/29/2009
Status: offline
butch,did you check out my new build on the gas speed section of these forums?i wish you lived closer ,cause i think we could share lots of thoughts in the boat building part of our hobbywe are almost finished my monster cat w/35cc quickdraw high torque motor.the motor sells for $1600 by it self,7.25hp in a 58 cat should rock-n-roll here is the link
http://www.rcuniverse.com/forum/m_8385274/tm.htm
< Message edited by soundguykaraoke50 -- 1/22/2009 12:51 PM >
Hide Signatures
       Post #: 106
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/27/2009 12:44 AM
soundguykaraoke50
Score: 100
Status: offline
where did you get the doll house fence?i need this to hide my holes i am needing to cut out.
Hide Signatures
(in reply to soundguykaraoke50)
       Post #: 107
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/27/2009 1:14 AM
werdonmorris
Score: 100
Status: offline
Tony
I have plenty myself, and just give me the general size needed. And I will send you more then you really need asap
Butch
Hide Signatures
       Post #: 108
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/29/2009 12:39 AM
soundguykaraoke50
Score: 100
Status: offline
i could use a 6x9 inch peice for the cat build
Hide Signatures
       Post #: 109
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/31/2009 12:05 AM
werdonmorris
Score: 100
Status: offline
Today I put a full day working on the boat, for my truck was in to get all new brake lines put on.
I took out the straight drive from Octura, and installed the Mercury outdrive that my friend Tony sent me. It did align up much better, and better free spin on the shaft, with o binding.
Going to modify the lower portion of the drive to install the 275 prop.
I spray a good ceramic coating inside the hull, and coating everything real good. Will do it again in the morning, and when it dries real good. Will re-install the engine, to measure the 1/4 flex cable to length,
and cut to proper size.
Will be painting the Merc Drive to my standards, and will match the out look that I have in mind for the paint scheme for the boat.
Pictures will be Saturday, for I am tired today.
Anyways I got truck back, and glad it is fixed. It's not like I be without, for a second truck resides in my driveway.
Have a great Night all my friends-Butch
Hide Signatures
       Post #: 110
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/31/2009 12:54 AM
soundguykaraoke50
Score: 100
Status: offline
go eazy on cutting the drive,you dont want to make weak spots on the small outdrive.it was built for the 67 nitro motor.i would use the bigest prop and increase the pitch as much as you can to reduce the rpm to about 8000.thats about redline for the motor you have.if you want to use the carb off that fuji motor.to help with the powerband.
Hide Signatures
       Post #: 111
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 1/31/2009 1:25 AM
werdonmorris
Score: 100
Status: offline
Tony, it sounds good to me, I will leave it alone.
Question, is it better to use the two blade prop, or the three blade prop for torque?
Hide Signatures
       Post #: 112
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/1/2009 11:57 PM
werdonmorris
Score: 100
Status: offline
soundguykaraoke50
Well, here is the merc drive after I sanded out all the flaws,and corrected some bends and dings.
I sanded it down to bare metal, metal prep applied, a two coat sealer primer, three coats of charcoal metallic, and three coats of ceramic marine clear.
I sanded the paint off in certain spots, to give it that bit of detail.
Then I took the three blade prop from you, wet sanded it, check the balance, then polished it to a mirror finish.
When the boat is done, it will look good on her, and more to detailed scale, many thanks.
Butch.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 113
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/2/2009 12:46 AM
soundguykaraoke50
Score: 100
Status: offline
that looks great.you know that that unit is very rare.i saw one on ebay a year ago the was outrageous priced.but it sold.175 dollars.parts are imposable to get for that unit.amps has been gone for some time now.that unit is over 25 years old.with hardly any use on her,one season ,about 6 runs.was for a nitro boat i used a echo weed-eater motor that was about 3/4 hp with her.back in the days the niro 90 guys were using this drive for scale boats.be easy with her and she will give you many years of pleasure.
Hide Signatures
       Post #: 114
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/6/2009 10:56 PM
rcgreenhornet
Score: 100
Last Login: 9/20/2009
Status: offline
you should of saved your 52$ not much power m/5 m/6 thats horse power for about a 5 to 6 foot gas boat zenoa
Hide Signatures
       Post #: 115
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/7/2009 12:45 PM
werdonmorris
Score: 100
Status: offline
rcgreenhornet
I am using a 25cc john deere homelite engine, which is vey stout compared to the 30cc engine, which produces less hp then the 25cc. And they are extremely easy to start, and long life and durability.
The boat is detailed with some parts on it I made, like the self cooling radiator system, that is enclosed with the cooling fluid source. I am not looking to set any speed records, just want to kill time, while my son and I are waiting for the fish to bite. And if they start to bite, let them. For if it means my son and I are enjoying the boat and spending quality time together, with our scratch build boat, so be it.
I would love to have a zenoa, or a quick draw engine, but this boat is a detail boat. Horse power for this boat is is un-
heard of.
soundguykaraoke50 advice is the way I shall go, and rich404. For they have been there from the beginning, and have been a golden inspiration.
Butch
Hide Signatures
(in reply to rcgreenhornet)
       Post #: 116
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/7/2009 1:07 PM
soundguykaraoke50
Score: 100
Status: offline
quote:
ORIGINAL: rcgreenhornet
the motor that is being used for this project is more than stout enough to power this scale model.this is about a 1/6 scale build.if it runs at 25mph that is 150 scale mph.show me a real boat that is used for pleasure that runs at 150mph!!!!!
the motor has a clutch and is a brand new motor ,a zen is$200+100 for the clutch plus shipping and for what?he will never need that much power.i could go on but i think you need to read the entire thread to understand what Mr.Butch is building.
Hide Signatures
       Post #: 117
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/21/2009 1:19 AM
werdonmorris
Score: 100
Status: offline
Hey fellow captains:
I have discovered a very easy way to shave, or should I say, cut off the excess fins off a engine head, or some call it a jug.
The purchase of a metal cutting hole maker, just like you use for making the holes in doors, for the locks and knobs.
I chucked it in my small drill press, and use a drill press vise, to hold it steady.
For each fin, you have to retract the cutting blade, to remove the spent aluminum fin, and so on.
The fourth fin, has to be removed, by hack saw and grinder. I used my corded dremel, for the cordless cannot do a very good job of it.
I then drilled and tapped the hold down holes. Cleaned the entire head with trans fluid, and re-lubed all surface's with 30wt syn oil.
used a large radiator clamp to compress the piston rings, and slid the piston into the head.
Installed the new cooling head, SPECIAL THANKS TO TONY, and it was done in a total of a hour.
Below is some of the pictures, I took
Butch
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 118
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/21/2009 2:01 AM
werdonmorris
Score: 100
Status: offline
Special thanks to Tony, for the great parts, and also to Rich404 for his valued advice on this issue, and WhiteWolf as well.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 119
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/21/2009 2:03 AM
werdonmorris
Score: 100
Status: offline
The picture of the baby, is my grandson Gabriel, and his father. The little fart machine, I love very much, and he loves to watch his grandpa, work on the boat.
Butch
Hide Signatures
       Post #: 120
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/21/2009 12:50 PM
soundguykaraoke50
Score: 100
Status: offline
Looking good Butch.i realize that i have a box of parts here to ship out to you,money has been tight here for the last couple weeks,Christmas caught up with me,as always i went way overboard for the rugrats my daughter has,plus my oldest grand/daughter wants to race this year,so i am killing two birds with one stone.i have been toying around with introducing a new ready to race,stock class boat in a mono form.so here it goes,on this site but on the gas speed section is my introduction of ,
Gas Propulsion Systems SG1 race mono.i have been real busy in the build room.the new boat only weighs in at 13.8 pounds dry,with a 5.2 horsepower @16000 rpm motor,this is the latest and greatest motor out there,we are shooting for,low 60s out of the box speeds,no nonsense all out race boat,47 inches long and she has a servo mounted trim on the fly feature,three channel fm radio with a complete ready to go price just under $1400 list price.we are still in the r&d of this boat,but if all goes well i should be very busy with building boats all spring long.
sorry i got side tracked,i didn't want to but dodo does happen,lol,
you project is coming along real nice,are you going to have her done by the time the water thaws out?that will be like 6-10 weeks for you.i am including a couple of shots of what i am building.my grand daughter wants to race so she can go at it in this rocket ship.come on Butch finish this boat up so you can start on your next build.lol.
tony
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 121
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/23/2009 11:47 PM
werdonmorris
Score: 100
Status: offline
Tony
I will be start doing some of the much needed finishing on the hull, and set forward with the upper helm.
Hide Signatures
       Post #: 122
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/25/2009 4:14 AM
werdonmorris
Score: 100
Status: offline
ADMINISTRATION:
I went to add to my build site, and found # 6 & # 7 gone, totally missing?
Did I do something wrong, Please send answer!
Butch
Hide Signatures
       Post #: 123
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/25/2009 6:55 AM
werdonmorris
Score: 100
Status: offline
RCU MOD"s
I have not got a answer yet to what had happened to the valued data that was valuable to other members, and myself.
There is a considerable amount of time spent on fact finding, only without warning to have it wiped from the build site.
There is much to be had from the threads that is posted in all the forums, but it is not a great effort to give just cause without some kind of warning.
A greater good can come out of these threads, and keep members up to date with images, and there efforts. We deserve a reason why it has been
thrown out the door!
Butch
Hide Signatures
       Post #: 124
RE: BUTCH'S BUILD LOG FOR DUMAS DEEP V60 - 2/25/2009 10:54 AM
soundguykaraoke50
Score: 100
Status: offline
i have seen this done if there was a posts that broke the rules,but since i havent seen any of that in this thread ,i dont know why the modderatores removed a bunch of posts????
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.518RCU1
