n7tb
OR, USA Status: offline
I was one of the very lucky ones to get an Alpha-4 during the order period in December. I have had it for about a month and can say that it is worth every cent I paid for it. I have used other chargers for less than half the price, but they don't come close to the features of the Alpha 4. I normally charge three aircraft batteries and my Transmitter battery at the same time. I have the options to charge each one on a separate charging options if I want. It is nice to have all my planes ready to go at all times. It is so easy to use it is unbelievable and has so many different battery charging/discharging/trickle options that I probably will never use all of them. It won't do Lithium Ion batteries, but I would never use them in RC applications anyway. It will do NiMH on several of its programmed cycles, but, I have also never seen the need for those types of batteries when high capacity NiCads are available and last so long anyway. I like the feature of being able to charge my lead-acid gel that I use in my field box with it too. I don't use it as a field charger, but it can do that as well. On most of the charging options the most I have to put in is the number of cells and the capacity rating and the charger takes care of the rest. In some cycles, I don't even have to do any of that. I know these are hard to get so please don't reply to this thread discussing that topic, or the business practices of Litco. That has been debated many times on this forum! I just wanted to give you all some feedback on a great charger. Terry
