RE: New 60-90 Extra 260
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: New 60-90 Extra 260
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: New 60-90 Extra 260 - 4/13/2009 5:41 PM
victorzamora
Score: 118
Last Login: 11/25/2009
Status: offline
I outlined what servos I used on the second page of this thread. There is a thread in the 3D Flying forum that has a lot more info than this thread.
_____________________________
Had I have known that the law of gravity was going to be so expensive, I would''ve voted to veto the darn thing!!
Hide Signatures
(in reply to trpastor)
       Post #: 76
RE: New 60-90 Extra 260 - 4/14/2009 4:37 AM
Mark Dennis
Score: 100
Status: offline
quote:
ORIGINAL: trpastor
Hey Guys
I was thinking about getting this plane. Anyone have video of it yet? Do you think it flys much better than the edge (60 size from aeroworks) or about the same?
What servos should I put in this (rudder, elevator and ailerons)
Thanks!
Tim,
I think you will find that both the 60-90 Edge and Yak fly much smoother than the edge. If you are looking for a small compact airplane that performs like a bigger IMAC machine this is it!
Servo wise, I would use anything with atleast 80oz of torque.
Tim
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
Hide Signatures
       Post #: 77
RE: New 60-90 Extra 260 - 4/14/2009 1:36 PM
RC4X4
Score: 100
Last Login: 11/22/2009
Status: offline
quote:
ORIGINAL: trpastor
Hey Guys
Thanks!
Tim
The Hitec HS965MG's are good and fast. I use one on the elevator. I put HS225mgs on the rest of the surfaces.
Hopen to a video this weeknd of mine to post. My buddie will shoot and edit it to post for me.
Mines electric not a glo setup.
Cory
< Message edited by RC4X4 -- 5/19/2009 3:38 AM >
Hide Signatures
       Post #: 78
RE: New 60-90 Extra 260 - 4/14/2009 2:01 PM
trpastor
Score: 135
Last Login: 11/26/2009
Status: offline
Hey Cory - did you do a dual elevator servo? Or do you have one 225mg on the whole elevator?
Mark - is the 80 oz torque for the elevator and rudder mainly, or are you suggesting this on the ailerons as well, or do you think the 225mg s would be enough for those as is suggested on the forum here? They are 66oz/in @6v
Tim
Hide Signatures
(in reply to RC4X4)
       Post #: 79
RE: New 60-90 Extra 260 - 4/15/2009 2:25 PM
RC4X4
Score: 100
Status: offline
quote:
ORIGINAL: trpastor
Tim
I'm using a single HS965mg on the elevator, HS225mgs on the rudder and ailerons. The 225mgs are running at 6volts and I don't see any problems.
The HS965 is .10 transit at 6volt, so it's quick.
Cory
Here's the 225 in the wings. I used some plywood and made some filler pieces.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 80
RE: New 60-90 Extra 260 - 4/19/2009 8:22 PM
trpastor
Score: 135
Status: offline
Hey guys - I need your help!
I put in the stab, but had a brain fart! I didn't put the elevator in yet.
I got it out in time and cleaned it up, except for where the wood was of course. It soaked in and wouldn't "wipe" off.
SO - should I do some sanding? Or just reapply and try again?
Also - If I go with 2 servos for the elevator - should I cut the elevator in half, so that they control each half indepentently?
Thanks!
Tim
Hide Signatures
(in reply to RC4X4)
       Post #: 81
RE: New 60-90 Extra 260 - 4/19/2009 8:26 PM
trpastor
Score: 135
Status: offline
Also - the JR DS821's say they are 88oz at 6v. I'm guessing these will work for this plane?
Tim
Hide Signatures
       Post #: 82
RE: New 60-90 Extra 260 - 4/22/2009 4:51 AM
trpastor
Score: 135
Status: offline
I guess everyone is out flying. WELL, I got mine in and it looks REALLY nice! I'm impressed with the build quality and looks. Other than having a size reference, you would think this was a 33% plane.
I have a saito 100 I'm putting in, but I'm having an issue, in that it bottoms out, into the back of the mount. Did anyone else run into this installing their 100?
Tim
Hide Signatures
       Post #: 83
RE: New 60-90 Extra 260 - 4/23/2009 4:29 AM
FrankFuss
Score: 100
Status: offline
Replace the cap screw holding the engine mount, that is behind the carburetor, with a flat head socket screw countersunk to be flush with the engine mount. This will allow you to move the engine closer to the firewall.
< Message edited by FrankFuss -- 4/23/2009 4:53 AM >
Hide Signatures
       Post #: 84
RE: New 60-90 Extra 260 - 4/23/2009 5:44 AM
trpastor
Score: 135
Status: offline
Good Call! I think I will still have to cut away a little of the mount, but not as much as without doing that. I can also replace the mount bolts with cap bolts as well.
Thanks!
Tim
Hide Signatures
(in reply to FrankFuss)
       Post #: 85
RE: New 60-90 Extra 260 - 5/5/2009 5:19 PM
dbronst3790
Score: 101
Status: offline
Here is video of the maiden of my 260. I'm running an OS .75AX with a 14 x 6 APC prop. This is a great combination for this plane.
Read my build log http://electricdan.wordpress.com/aeroworks-extra-260-build-log/ for more details on the setup.
< Message edited by dbronst3790 -- 5/5/2009 5:26 PM >
Hide Signatures
(in reply to victorzamora)
       Post #: 86
RE: New 60-90 Extra 260 - 5/5/2009 5:31 PM
trpastor
Score: 135
Status: offline
Hey Guys - I just finished building and flying mine. Maiden flight yesterday. Flys VERy well. I'm very please with the build quality and flight charecteristics. I'm not a great pilot but it make my manuevers look smoother than what I'm used to
I'll add some pics soon
Hide Signatures
(in reply to dbronst3790)
       Post #: 87
RE: New 60-90 Extra 260 - 5/5/2009 5:58 PM
dbronst3790
Score: 101
Status: offline
Congrats on the maiden!
Hide Signatures
       Post #: 88
RE: New 60-90 Extra 260 - 5/19/2009 3:41 AM
RC4X4
Score: 100
Status: offline
Hey guys. The 260 has been great. I'm playing with a couple new brushless outrunner motors to see which one I like.
Hopen to get that done soon. Here's a picture next to the big brother, 85cc powered 260.
Cory
Click for fullsize
Click for fullsize
< Message edited by RC4X4 -- 5/19/2009 3:42 AM >
Hide Signatures
       Post #: 89
RE: New 60-90 Extra 260 - 5/19/2009 4:32 AM
dbronst3790
Score: 101
Status: offline
I'd like to try the Yak with EP.   Looking forward to what you find out.
Hide Signatures
(in reply to RC4X4)
       Post #: 90
RE: New 60-90 Extra 260 - 5/23/2009 4:34 PM
leedees
Score: 105
Status: offline
I have my Extra 260 on order with expected delivery next week.   I've been wanting an Aero-Works plane for a long time.
I will use a Tru Turn spinner, can anyone tell me the size of the backplate on the factory included spinner?
Thanks for any help.
Lee
Hide Signatures
       Post #: 91
RE: New 60-90 Extra 260 - 5/23/2009 4:37 PM
trpastor
Score: 135
Status: offline
I believe I'm using a 2 1/4" spinner.  I'm using the tru turn big bird or big prop.  Since you will likely be using a 15x6 or similar
 the normal size won't allow room for the prop
Hide Signatures
(in reply to leedees)
       Post #: 92
RE: New 60-90 Extra 260 - 5/23/2009 10:07 PM
dbronst3790
Score: 101
Status: offline
Yep, it's 2 1/4".  Here's the link to the manual so you can get familiar with the kit.  www.aero-works.net/upload/manual/60extra260.pdf
< Message edited by dbronst3790 -- 5/23/2009 10:11 PM >
Hide Signatures
       Post #: 93
RE: New 60-90 Extra 260 - 6/8/2009 1:24 PM
ro347
Score: 280
Status: offline
Would someone please post the specs of the landing gear???  Looking to see if the carbon Fiber replacement will fit my AW Edge.
Thank you
Hide Signatures
       Post #: 94
RE: New 60-90 Extra 260 - 6/24/2009 10:53 PM
wjcalhoun
Score: 100
Last Login: 11/23/2009
Status: offline
Hi guys
Mine is built with an OS 1.20AX swinging a 16x8 APC; turns about 8400. Hitech HS 5625MGs all around. 4c 3600mAh subC pack; 2.4GHz Futaba receiver. GC right on the nose with the battery pack mounted aft of the rudder servo; no extra weights. AUW (dry) about 7.5#. 50% expo on High rates; 40% expo and 60% throws on low rates. Maidened the other day and it flew beautifully. Very strong, maybe unlimited vertical (did not test that on the maiden). Very fast (360*/sec) roll rate on low rates. I didn't push it on high rates. Landed as easily as my 4*60. Several other flights with no problems. I did notice that the right wingtip seems to stall and fall out with more than moderate up elevator, leading to a snap more often that I would like.
Overall, really a superb aircraft.
Today, flew a few aileron rolls, stall turns, 1/2 cubans, etc, with no problems. Followed that with a few snap rolls, and then the plane became quite unstable. ANY elevator caused it to snap roll, even a very small amount to correct a shallow dive would make it snap again, which -> progressive loss of my 120' altitude -> ground contact. I found the battery pack wedged aft of the second former - obviously it had broken (my aft) mounting tray, probably during a snap, and moved the CG way aft leading to its demise. I know from RF G4.5 that the plane is pretty sensitive to the location of the CG. Moving it as little as 2 inches aft made the plane unflyable in the sim. Lesson learned - build a stronger battery tray! Pack weighs 10 oz, so a 6g maneuver would have put 4# of force on the tray.
Thats my initial take on it anyway. Does anyone have other ideas, suggestions? Or a diferent thought about causes? I like the plan enough that I'll probably buy and build another. Any thoughts on constructing a strong battery rack?
Hide Signatures
(in reply to ro347)
       Post #: 95
RE: New 60-90 Extra 260 - 6/25/2009 12:57 AM
victorzamora
Score: 118
Status: offline
I hate to hear about your crash. I didn't make a battery tray, I just mounted 2 elevator servos and put the Rx battery infront of the wingtube and immediately next to my Rx.
Hide Signatures
(in reply to wjcalhoun)
       Post #: 96
RE: New 60-90 Extra 260 - 6/25/2009 1:49 PM
RC4X4
Score: 100
Status: offline
Servo Update.
These look like they would a great servo for this plane.
I am gonna switch mine out from the HS225mg's .
Tower Hobbies TS-160 Std Digital HT HS 2BB MG Servo
Cory
Hide Signatures
       Post #: 97
RE: New 60-90 Extra 260 - 6/25/2009 2:18 PM
victorzamora
Score: 118
Status: offline
If I were you, I'd go with Hyperion DS20-FMD's. They're cheaper, and I think they run better. They have about the same spec's really...they're just smoother (and $5 cheaper). Also, if you want to go a little more expensive....Hyperion DS-20x SMD's are the way to go. .11s and 130oz-in of torque AND they're coreless! Absolutely awesome. allerc.com carries them. It's what I'm running on ailerons and rudder. I've got HS-225MG's on each elevator half.
Hide Signatures
(in reply to RC4X4)
       Post #: 98
RE: New 60-90 Extra 260 - 6/25/2009 3:20 PM
RC4X4
Score: 100
Status: offline
quote:
ORIGINAL: victorzamora
I'll check those out. I kinda wondered about those servos awhile back.
Did you cut the joiner for the elevator half's? I may have to do that also.
Cory
Hide Signatures
       Post #: 99
RE: New 60-90 Extra 260 - 6/26/2009 1:03 AM
victorzamora
Score: 118
Status: offline
Yup...I just took a hack-saw to the elevator joiner piece and made it follow the same line as the elevator. It looks good, I think. I had always wanted a plane where both elevator halves could be misaligned....and now they are! It's just a lot easier to set-up, I think. The Extra even has another servo slot in the tail...which I used.
Hide Signatures
(in reply to RC4X4)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.828RCU1
