New 60-90 Extra 260
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> New 60-90 Extra 260
Page: [1] 2 3 4 5 6   next >   >>
Login
New 60-90 Extra 260 - 10/7/2008 3:30 PM
Mark Dennis
Score: 100
Last Login: 11/8/2009
Status: offline
Aeroworks is proud to add too their line of QUICK BUILD Series Aircraft
Designed with the customer in mind to provide the highest quality, light weight construction and fastest build time possible.
Aeroworks has Raised the Bar. The QB Series is top quality in both design and performance that has set a new standard for ARF aircraft
Aeroworks is proud to introduce the .60-.90 Extra 260 QB (Quick Build), this airplane is sure to impress with its outstanding power to weight ratio, unbeatable durability and ease of assembly. Aeroworks .60-.90 Extra 260 is sure to be the highest quality airplane you will ever build or fly. The .60-.90 Extra 260 was designed with the aspiring sport or 3D pilot in mind and features a light wing loading and large control surfaces for extreme maneuverability, yet easy handling is just a rate switch away.
The Extra 260 QB has been designed to accommodate both glow and electric power systems. All mounting hardware including engine mount has been included for your choice of glow engine. Pre-formed air inlet scoops and pre-cut air exit slots provided for electric power conversions.
SPECIFICATIONS
Wing span 60 inches.
Wing Area 690 sq. in.
Fuselage length 55" (Rudder to front of spinner)
Weight 6 to 6.5 lbs
Engine .60 - .90 Glow
Electric Power
Radio 6 Channels minimum
FEATURING
Glow or Electric Ready
Strong Light Weight Construction
Complete and Detailed Instruction Manual
Painted and Pre mounted 7075 Aluminum Landing gear
Pre mounted Tail Wheel Assembly
Complete US Standard Hardware Package Included
Two piece removable wings
Carbon FiberWing Tube
Professionally covered in ULTRACOTEā„¢
Additional UTRACOTEā„¢ supplied for small patches and repairs
Pre-Hinged from factory
One Servo per Wing panel
One Servo per Elevator Half
Large control surfaces double beveled for maximum throw
Pre Mounted Fiberglass Cowl and Wheel Pants
Pre Mounted and Tinted Canopy / Hatch assembly
Pre installed and fuel proofed engine box
Laser marked engine mounting templates
Custom Deflection Rudder Gage
Custom Throw Meter
Custom Vinyl Decal Set
8 to 10 Hours assembly Time
Expeceted dilevery date November 2008, pre order today at Aero-works.net
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Mark Dennis -- 10/7/2008 3:46 PM >
_____________________________
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
Hide Signatures
       Post #: 1
RE: New 60-90 Extra 260 - 10/7/2008 4:50 PM
smarks
Score: 100
Last Login: 10/30/2009
Status: offline
Now I know why I never hear from you Mark. Aeroworks continues to rock the market!
Special Thanks To:
www.Smart-Fly.com
Hide Signatures
(in reply to Mark Dennis)
       Post #: 2
RE: New 60-90 Extra 260 - 10/7/2008 6:37 PM
tulz161
Score: 100
Status: offline
Do you guys plan on have a video of both electric and gas powered?
Also I see in the manual you guys installed a saito 82. How did it perform?
< Message edited by tulz161 -- 10/12/2008 12:13 AM >
Money isn''t everything... but everything makes me want it.
Hide Signatures
(in reply to smarks)
       Post #: 3
RE: New 60-90 Extra 260 - 10/8/2008 8:31 PM
kbailey45
Score: 110
Last Login: 11/7/2009
Status: offline
Curious on the Saito .82 here as well.
Hide Signatures
(in reply to tulz161)
       Post #: 4
RE: New 60-90 Extra 260 - 10/12/2008 2:09 AM
tulz161
Score: 100
Status: offline
I'm thinking Saitos new FG20. And thoughts?
Hide Signatures
(in reply to kbailey45)
       Post #: 5
RE: New 60-90 Extra 260 - 11/26/2008 1:40 AM
Mark Dennis
Score: 100
Status: offline
quote:
ORIGINAL: kbailey45
The .82 is one of the motors we installed in the manual, it works very well on the 60/90 Extra 260 and provides great sport performance.
Also, these are in stock and shipping, Rocco and I went through one of these today and we were both very impressed with how this little plane turned out. If you havent told Santa what you want for Christmas this would definatley be on the top of my list!
Team Aeroworks
Hide Signatures
       Post #: 6
RE: New 60-90 Extra 260 - 12/3/2008 2:48 AM
fx777
Score: 100
Last Login: 2/7/2009
Status: offline
Hello Mark, I am interested in the extra 260 50cc, but have a question. You recommend a 180 lb rated servo on all surfaces. Can I be safe in the 160 range for sport flying; I don't am not interested in 3d flying. I am also interested in the 35cc extra 300 and would like to know the best target weight for the engine. I spoke to Chuck yesterday and he suggested I pass engine size question by you. He also cautioned about servos with less than the recommended torque. Thanks in advance. I have an Aeroworks 61 size edge and love the quality and performance, and I am looking to move up.
Hide Signatures
       Post #: 7
RE: New 60-90 Extra 260 - 12/13/2008 2:52 PM
Warbird Wully
Score: 100
Last Login: 11/4/2009
Status: offline
Hi Mark,
I see that these are now in stock so I'm ordering the Extra 260 .60-.90 size QB today and have a YS 110-S laying around to put on it. Will the width of it fit inside the cowl if I invert it? I understand if inverted the bottom will a touch. I plan to fly IMAC and sport flying.
Frank
AMA 803753
IMAA 29476
Hide Signatures
       Post #: 8
RE: New 60-90 Extra 260 - 12/15/2008 12:26 AM
Mark Dennis
Score: 100
Status: offline
quote:
ORIGINAL: Aero-Nut
Hi Mark,
Frank
Frank,
The motor will pass through the bottom of the cowl if mounted fully inverted. The manual shows the engine being mounted at an inverted 45*, this keeps as much of the engine inside of the cowl and will keep the muffler in the center of the plane.
Team Aeroworks
Hide Signatures
(in reply to Warbird Wully)
       Post #: 9
RE: New 60-90 Extra 260 - 12/15/2008 2:38 PM
Warbird Wully
Score: 100
Status: offline
Thanks. Is the engine mount strong enough for the YS 110 or should I upgrade?
AMA 803753
IMAA 29476
Hide Signatures
       Post #: 10
RE: New 60-90 Extra 260 - 12/15/2008 7:08 PM
dmurf
Score: 116
Status: offline
Hi Mark,
It mas mentioned earlier about how saito's new FG 20cc gas engine would work in this plane. That's what I would like to put in.
Thanks Mark
Hide Signatures
       Post #: 11
RE: New 60-90 Extra 260 - 12/16/2008 2:33 AM
Mark Dennis
Score: 100
Status: offline
quote:
ORIGINAL: dmurf
Hi Mark,
Thanks Mark
The FG 20 will be heavy compared to the .60-1.15 glow motors that we recomend. If you are looking to get good 3D performance I would stick with the glow engine, if you want a good sport plane then the FG-20 will work.
Team Aeroworks
Hide Signatures
(in reply to dmurf)
       Post #: 12
RE: New 60-90 Extra 260 - 12/20/2008 5:15 AM
pmgrandnord@hotmail.com
Score: 100
Last Login: 9/14/2009
Status: offline
Hi Mark,
my question is about electric conversion. I already own a AXI 4130/16 motor, opto 77 and a 6cell 5000mah. Do you thing it's a good set up for that plane ? Which prop. should i use ?
Thank you
Pascal
Hide Signatures
       Post #: 13
RE: New 60-90 Extra 260 - 12/21/2008 7:14 PM
lncracing
Score: 100
Last Login: 11/5/2009
Status: offline
Will this plane or the 46-61 Edge hover with a super tigre .61?
Hide Signatures
(in reply to pmgrandnord@hotmail.com)
       Post #: 14
RE: New 60-90 Extra 260 - 12/21/2008 10:23 PM
Score: 100
Status: offline
the New 60-90 Extra 260
Hide Signatures
(in reply to lncracing)
       Post #: 15
RE: New 60-90 Extra 260 - 12/24/2008 1:43 AM
lncracing
Score: 100
Status: offline
Will this plane or the 41-61 Edge hover with a Super Tigre .61. And what prop would be the recommended for a .61 size power plant
Phil
Hide Signatures
       Post #: 16
RE: New 60-90 Extra 260 - 12/24/2008 3:37 AM
Warbird Wully
Score: 100
Status: offline
quote:
ORIGINAL: Mark Dennis
SPECIFICATIONS
Weight 6 to 6.5 lbs
Electric Power
FEATURING
Custom Throw Meter
Just received mine and there is nothing prehinged, or pre-mounted. Your email says different. I have received planes that were completely prehinged(Glued). Did I get a lemon?
Frank
AMA 803753
IMAA 29476
Hide Signatures
       Post #: 17
RE: New 60-90 Extra 260 - 12/24/2008 6:15 AM
Ferocious Frankie
Score: 100
Status: offline
quote:
ORIGINAL: Aero-Nut
Frank
What!!! Pre-hinged and pre-mouted are major parts of AW's QB series. Definitely sounds like a mistake. Call them and they will take care of you.
Plane: AW 50cc Extra 300
Radio: Futaba 12FG 2.4 GHz
Hide Signatures
       Post #: 18
RE: New 60-90 Extra 260 - 12/24/2008 6:34 AM
Score: 100
Status: offline
Hi Frank
Please, keep us in touch with your issue. How look the quality of the plane ?
thanks
Pascal
Hide Signatures
       Post #: 19
RE: New 60-90 Extra 260 - 12/24/2008 11:33 AM
Ferocious Frankie
Score: 100
Status: offline
quote:
ORIGINAL: pmgrandnord@hotmail.com
Hi Frank
thanks
Pascal
Hi Pascal, the problem is Aero-Nut's and not mine.
Hide Signatures
       Post #: 20
RE: New 60-90 Extra 260 - 12/24/2008 2:23 PM
Warbird Wully
Score: 100
Status: offline
Plane looks great.. Covering is tight, all parts look good. It's just when they say ailerons, elevators are pre-hinged I expect them to be especially when the price is so much more than the Edge.
Frank
AMA 803753
IMAA 29476
Hide Signatures
       Post #: 21
RE: New 60-90 Extra 260 - 12/24/2008 2:26 PM
Warbird Wully
Score: 100
Status: offline
I thought so to. my neighbor got a 35% AW QB Extra and everything was prehinged, fuel take plumbed, etc.
Frank
AMA 803753
IMAA 29476
Hide Signatures
(in reply to Ferocious Frankie)
       Post #: 22
RE: New 60-90 Extra 260 - 12/24/2008 6:26 PM
bigal422
Score: 100
Status: offline
You guys are so spoiled. I read somewhere that the hinges would not be glued and the gear not mounted. I think it was on there web site. I would rather glue my own ca hinges any way.
Hide Signatures
       Post #: 23
RE: New 60-90 Extra 260 - 12/24/2008 6:43 PM
Warbird Wully
Score: 100
Status: offline
Yeah, aren't we all a little spoiled. I travel quite a bit so my time is limited so QB is about the only way for me these days but that's not the point. The point is I would have bought the Edge for $170 vs the Extra @ $275...it's the same wing span as the Edge for crying out load and $105 more....!!! That's a large difference for about the same bird in anybody's book.
Oh well......Everyone have a great Christmas.
AMA 803753
IMAA 29476
Hide Signatures
(in reply to bigal422)
       Post #: 24
RE: New 60-90 Extra 260 - 12/24/2008 7:19 PM
Score: 100
Status: offline
Hi Aero-nut !
If you have a chance to weight your plane before you put your motor on... i will really appreciate !!! I want make a electric conversion and that could help me a lot if i could know the weight "raw". So i could figure my total weight with my motor and batterie.
Thank you and have a MERRY CHRISTMAS !!!!
Pascal
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.720RCU1
