Transmission gear jammed.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Transmission gear jammed. Page: [1] 2   next >   >>
Login
Transmission gear jammed. - 10/10/2008 4:25:03 AM
sokar
Status: offline
My transmission gear is not budging after a tank of Idling. There are no obstructions. I am using a pull start, and it is impossible to pull. It is jammed. Does anyone know whats going on?
       Post #: 1
RE: Transmission gear jammed. - 10/10/2008 4:34:25 AM
NitroVenom
Status: offline
Its not the transmission, your motor is just flooded most likely. Take out the glow plug and turn the truck upside down. Then just give it a few pulls. That will clear the fuel out.
_____________________________
When In Doubt, Throttle Out
(in reply to sokar)
       Post #: 2
RE: Transmission gear jammed. - 10/10/2008 4:45:56 AM
sokar
Status: offline
Thats causing the pull start thing to be completely jammed? I'll try it.
EDIT: Nope, even with the car turned up side down and the plug removed, that handle won't budge.
< Message edited by sokar -- 10/10/2008 4:48:33 AM >
(in reply to NitroVenom)
       Post #: 3
RE: Transmission gear jammed. - 10/10/2008 4:50:30 AM
NitroVenom
Status: offline
Yea, when the motor gets flooded, it locks up everything in the motor. Which is why you cant turn over the motor anymore.
(in reply to sokar)
       Post #: 4
RE: Transmission gear jammed. - 10/10/2008 4:53:03 AM
NitroVenom
Status: offline
Did any fuel leak out when you turned it upside down?
Try loosening the bolts that hold the backplate on. If that doesn't work then you gotta take off the pull start and see whats up.
       Post #: 5
RE: Transmission gear jammed. - 10/10/2008 5:04:51 AM
sokar
Status: offline
No fuel leaked when it was up side down. If loosening the backplate doesn't work what do you recommend?
Also, will it be unflooded in the morning if I let it sit overnight?
< Message edited by sokar -- 10/10/2008 5:20:12 AM >
       Post #: 6
RE: Transmission gear jammed. - 10/10/2008 5:53:52 AM
TMaxxDriver
Status: offline
Usually when unclogging a flood, some fuel will spit out of the head (with the plug out), and that indicates that you have cleared the flood... BUT since you say that NO fuel came out, maybe its not flooded....?
Try taking the backplate off, and checking the coil for the Pull Start, and make sure nothing is binding it...
TMaxx 2.5r, Jato 3.3, Revo BB coming soon!
Drive it like you stole it! AIM-FastDriver2469- IM Me!
(in reply to sokar)
       Post #: 7
RE: Transmission gear jammed. - 10/10/2008 1:36:17 PM
aftershock108
Status: offline
it could be the one way bearing in the pull start went bad and is locking up on you
can you turn the flywheel by hand?
it could be the one way bearing or it got to hot while letting it idle and locked up the engine
(in reply to TMaxxDriver)
       Post #: 8
RE: Transmission gear jammed. - 10/10/2008 2:27:24 PM
sokar
Status: offline
quote:
ORIGINAL: aftershock108
No, I cannot turn the flywheel by hand. If the one way bearing did get too hot, what do you recommend? I let it sit for a night and I'm gonna go back to try it in a couple of minutes.
EDIT: It didn't work. After a night of sitting its still jammed up. This is a brand new engine that was working fine. I just ran a tank through it at idle to break it in, and all of a sudden it did this. What could be causing this?
< Message edited by sokar -- 10/10/2008 2:52:12 PM >
(in reply to aftershock108)
       Post #: 9
RE: Transmission gear jammed. - 10/10/2008 5:24:29 PM
matts6887
Status: offline
Well, like the others have mentioned; its probably because u have either flooded the engine somehow, in turn causing the starter handle to lock up like that; OR, something is probably messed up with the springs inside the pull start....
"If U havent broken anything....U arent driving it hard enough"
(in reply to sokar)
       Post #: 10
RE: Transmission gear jammed. - 10/10/2008 6:00:16 PM
T.L.A.R. eng
Status: offline
Is this a new engine you are trying to break in? Possibly it stuck at top dead center in the pinch area. Try warming the cylinder with a hair dryer and see if it will turn.
(in reply to matts6887)
       Post #: 11
RE: Transmission gear jammed. - 10/10/2008 6:26:01 PM
NitroVenom
Status: offline
quote:
ORIGINAL: T.L.A.R. eng
+1 Just heat the motor for a few minutes and that should loosen it up a bit.
(in reply to T.L.A.R. eng)
       Post #: 12
RE: Transmission gear jammed. - 10/10/2008 8:55:52 PM
aftershock108
Status: offline
ya try heating it up and see if that works sometimes the pinch is really tight on new motors useually the big blocks are the ones you have to do this with
if that doesnt work your going to have to start pulling it apart start with the pull start take it off and the one way bearing and then see if you can turn the flywheel buy hand if it still doesnt turn then the motor has to be locked up
if thats the case if you havent had it to long traxxas might replace it for free, or you can do there engine replacement plan and for like $90 you can get a 2.5R or a 3.3 for like $120
       Post #: 13
RE: Transmission gear jammed. - 10/11/2008 12:28:09 AM
sokar
Status: offline
Let me add that theres some gooey oily stuff dripping out of the exhaust.
Let me also add that the engine was quite warm when it got stuck. It idled through a full tank of gas, but when I gassed it up and truied to start it the pull start wouldn't budge.
< Message edited by sokar -- 10/11/2008 12:32:54 AM >
       Post #: 14
RE: Transmission gear jammed. - 10/11/2008 1:45:10 AM
sokar
Status: offline
I think the transmission gears are in fact jammed. I may have put it together wrong when constructing my engine.
(in reply to sokar)
       Post #: 15
RE: Transmission gear jammed. - 10/11/2008 2:47:55 AM
sokar
Status: offline
Grrrrr!
< Message edited by sokar -- 10/11/2008 3:30:00 AM >
(in reply to sokar)
