Taurus Flyer
Joined: 1/9/2004 From: Almelo, NETHERLANDS Status: online
Hello Chuck, I have some troubles with this part of your post: >>> I have JR NEC-211 wall chargers and they have a output rated at 5.8v @ 50ma...So I assume this will be alright for my "normal" 6.0v charger..Correct?? Even for the NiMh batteries?? >>> The output voltage must have overvoltage to charge the battery, I think your charger is for 4 cells, 4 x 1,45 V = 5,8 Volt. Overvoltge is 1,45 - 1,11 = 0,34 Volt/cell empty pack , 1,45 - 1,3 = 0,15 Volt/cell full pack. When you try to charge a 6 Volt battery you must check the current on moment of start charging but especially after about 14 hours, because maybe the chargecurrent is zero because of the voltage of the battery pack. Overvoltage 1,16 - 1.11 = 0.06 Volt/cell??? empty pack, 1,16 - 1,3 = ##### Volt/cell When this is not clear, ask again. Cees
< Message edited by Taurus Flyer -- 10/11/2008 5:36:03 PM >
