Need help on possibility an Koyosho concept sr 60    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Kyosho Helicopters >> Need help on possibility an Koyosho concept sr 60 Page: [1]
Login
Need help on possibility an Koyosho concept sr 60 - 10/14/2008 9:54 AM
jcervantes11
Score: 100
Last Login: 2/14/2013
Status: offline
I got this heli, needs alot of work. Here is the quetion, hope I get them answere. I hope it is a koyosho concept sr 60. Please hope anybody have these things.
Oh yea that last pic is my Helipro Black hawk 500 15 size engine and its the pro se edition.
1. What tail blade uses? Whats a great replacement?
2. Whats cheapiest servo can i use on this thing?
3. How about Gyros?
4. Engine, well I have a OS MAX SX60 , with washer and nut. Nut doesn't belong there, washer yes, but the prop grip isnt there whats a good replacement? Do I need it?
5. Essempbly for motor, fan and clutch, I have all that but I think I am missing something, the main shaft of the motor isn't long enought, what do you all think?
6. Muffler and manifold with gaskit, where do i get one with a set for this os max sx 60 engine?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
AMA LICENSE NUMBER: 928146
Hide Signatures
       Post #: 1
RE: Need help on possibility an Koyosho concept sr 60 - 10/14/2008 11:08 PM
Cyberfyn
Score: 100
Last Login: 2/18/2013
Status: offline
It's a great heli if you can get it going again. LOOOOOooooong out of production though, so parts will be hard to find.
Any 60 size tail blades will do. Plastic or Carbon ? It's up to your wallet.
You can use the cheapest servos you can find if you want.... But I'd recommend something with at least 5kg of pull or Digitals as a minimum.
Gyro = Futaba GY401. Sorted.
Engine. You need a heli specific motor (something with a H prefix) Can't help with the one you have I'm afraid.
You can download the manual from this site to help you : http://www.rchelibase.com/concept/
Ian F.
Very funny Scotty, Now please beam down my clothes!
Hide Signatures
(in reply to jcervantes11)
       Post #: 2
RE: Need help on possibility an Koyosho concept sr 60 - 10/15/2008 6:17 AM
jcervantes11
Score: 100
Status: offline
Do you have this heli? What engine have you used?
Hide Signatures
(in reply to Cyberfyn)
       Post #: 3
RE: Need help on possibility an Koyosho concept sr 60 - 10/15/2008 6:15 PM
Cyberfyn
Score: 100
Status: offline
No, I had a couple of Concept 30s a few years ago though. But I flew a friends 60 (just like yours) and fell in love with it. A real peach!
Any 60 size heli engine will do the trick. Zimmerman or Hatori muflers are my choice.
Ian F.
Hide Signatures
       Post #: 4
RE: Need help on possibility an Koyosho concept sr 60 - 11/13/2008 8:25 PM
Pat1954
Score: 100
Last Login: 11/16/2008
Status: offline
I'm flying a 60SR and by judging by the rotor head you also have an SR. I use the OS 70 heli engine in mine. One thing to keep in mind is that the clutch and fan collar are engine specific. You can save yourself some pain if you know what engine was in it before. If the clutch and fan will fit correctly on the OS 60 you have then they are for the OS 60 class engine so you could use the OS 60, 61 or 70 heli engines. I use the Futaba GY401 gyro. my servos are Futaba s5101 except for the tail rotor which is a Futaba s9254, the tail servo needs to be fast. For the muffler you can use almost any aircraft 60 size muffler but I suggest the OS Silencer or something similar. Tail blades are standard 95mm blades and the main blades are 660mm I use custom made 670mm. I can't imagine why your engine shaft is too short unless you have that large prop washer on there, if you do that needs to come off. The only thing between the clutch bearing and the engine block should be a small washer.
Takeoff is optional, landing is mandatory
Hide Signatures
       Post #: 5
RE: Need help on possibility an Koyosho concept sr 60 - 11/14/2008 1:33 AM
jcervantes11
Score: 100
Status: offline
theres no prop washer. When you're fan is on the motor, do you add a nut inside? So my motor don't need prop washer?
Hide Signatures
(in reply to Pat1954)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
