Gas/Oil Mix??
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
CRRC-pro GF26i - RTF
Seller:  SERCE
Details:   $189.99   |  2/25/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Gas/Oil Mix??
Page: [1]
Login
Gas/Oil Mix?? - 10/16/2008 8:06 PM
blue77
Score: 105
Last Login: 9/24/2009
Status: offline
Can someone reccomend a good oil? and gas? and the mixture to use in most every engine....I don't want to keep several gas cans......I'm not looking for max power, just a good clean running mix....Thanks WC
Hide Signatures
       Post #: 1
RE: Gas/Oil Mix?? - 10/16/2008 8:23 PM
Whistling Death
Score: 100
Last Login: 3/22/2010
Status: online
Pop corn and beer in hand, this should be great
_____________________________
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
(in reply to blue77)
       Post #: 2
RE: Gas/Oil Mix?? - 10/16/2008 8:36 PM
krayzc-RCU
Score: 101
Status: offline
lol every1 knows its penzoil at 32 to 1, 40 to 1 or 50 to 1 depending on what your engine manf says ratio wise
smooth as silk!
Hide Signatures
(in reply to Whistling Death)
       Post #: 3
RE: Gas/Oil Mix?? - 10/16/2008 8:40 PM
iliveonlytocrash
Score: 100
Status: offline
I vote for Klotz Modelube mixed at 50:1. Reasonable price, burns clean, lubricates well, and most importantly.......has that racey smell!!!
Available from Tower Hobbies http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS626&P=ML
It didn''t happen because I was flying too low, it happened because the ground was too high!
Hide Signatures
       Post #: 4
RE: Gas/Oil Mix?? - 10/16/2008 10:19 PM
Jezmo
Score: 104
Status: offline
I vote Redline Two Stroke Racing at the engine manufacturers suggested ratio.
Spektrum DX7, DA DLE SuperTigre OS FOX Saito Enya Jett TT: John 3:16
Hide Signatures
(in reply to iliveonlytocrash)
       Post #: 5
RE: Gas/Oil Mix?? - 10/16/2008 11:10 PM
pe reivers
Score: 111
Status: online
If you want to mix a single fuel for all engines to use, you need to meet requirements of the most demanding engine. So 91 PON premium gas, and Mobil 1 2T or equivalent oil. like Motul 800, Redline racing 2T, Belray HR1, Putoline RS949, Castrol 747 etc.
If your most demanding engine is a standard zenoah, regular 89 PON gas and Lawnboy ashless will do. In Europe, most scooter oils are of excellent quality.
Pe, Dealer for MVVS, MTW, Xoar and Mejzlik
Ignorance a blessing? , there is sanctuary in analysis.
Hide Signatures
(in reply to Jezmo)
       Post #: 6
RE: Gas/Oil Mix?? - 10/16/2008 11:26 PM
Tired Old Man
Score: 169
Status: offline
Go with Pe's suggestions. He covered all the bases with the right answers. 40-1 will do with any on the oils mentioned, but reading and following the directions on the oil can is also always a good place to start. Premium gas covers all the engines and won't hurt the ones that don't require it.
Never lie, and never minimize or gloss. Tell it like it is and let the pieces fall where they may. The truth always wins.
Hide Signatures
(in reply to pe reivers)
       Post #: 7
RE: Gas/Oil Mix?? - 10/16/2008 11:36 PM
JoeAirPort
Score: 115
Last Login: 3/21/2010
Status: offline
I heard Amsoil is coming out with a new 1000:1 oil. It's supposed to protect your engine better than those cheap 32:1 oils and you won't get any sludge on your plane.
Joe AP
Hide Signatures
(in reply to Tired Old Man)
       Post #: 8
RE: Gas/Oil Mix?? - 10/17/2008 12:04 AM
pe reivers
Score: 111
Status: online
I have the new zero stroke engine in my plane, that was just develloped to take advantage of the new 1:1000 oil.
No vibrations, no plane staining at all, unlimited verticals right up to heaven.
Hide Signatures
(in reply to JoeAirPort)
       Post #: 9
RE: Gas/Oil Mix?? - 10/17/2008 12:10 AM
JoeAirPort
Score: 115
Status: offline
Yeah probably one long vertical and it will be up in heaven to stay.
I agree with T.O.M., PE pretty much answered it. That's why I started my comedy act.....I know it's pretty weak.
Joe AP
Hide Signatures
       Post #: 10
RE: Gas/Oil Mix?? - 10/17/2008 12:35 AM
Tired Old Man
Score: 169
Status: offline
Zero stroke? = Electric??
Hide Signatures
       Post #: 11
RE: Gas/Oil Mix?? - 10/17/2008 12:44 AM
stuka
Score: 100
Status: offline
Amsoil oil run at 100 to 1 or 50 to 1. I have run it for many years both ways without any problems.
Hide Signatures
       Post #: 12
RE: Gas/Oil Mix?? - 10/17/2008 1:46 PM
Walt and Sage
Score: 100
Status: online
Amsoil "DOMINATOR" 50 to 1 after break in in ALL my planes,
chain saws and gas generators ..
A Man''s Character is his Destiny.........
........AMA 38255 "PRO BRO 2344"
Hide Signatures
(in reply to stuka)
       Post #: 13
RE: Gas/Oil Mix?? - 10/17/2008 3:27 PM
arobatx
Score: 125
Status: offline
Damn....popcorn is gone, so I either have to make more, or go ahead and post....
I opted to go with a very good quality, very inexpensive, and readily available oil, and mix it on what I would consider to be the well educated side of things... Pennzoil 2 stroke for Air Cooled Engines, 40:1.... My Zenoahs and misc lawn equipment have no problem running the higher octane that my ZDZ's and 3W's enjoy. They all get the same drink.
There are a handful of other oils I would trust equally, and have been mentioned here. This is the one I've chosen, and haven't had a reason to look back.
Chad
Hide Signatures
(in reply to Walt and Sage)
       Post #: 14
RE: Gas/Oil Mix?? - 10/26/2008 3:59 PM
OkieTrucker
Score: 100
Last Login: 9/15/2009
Status: offline
quote:
ORIGINAL: Whistling Death
That was a good one!! LOLOLOLOLOL
"A veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The ''United States of America'', for an amount of ''up to and including my life.''" (Author unkn
Hide Signatures
       Post #: 15
RE: Gas/Oil Mix?? - 10/28/2008 3:45 AM
n2rc
Score: 100
Last Login: 12/17/2009
Status: offline
quote:
ORIGINAL: JoeAirPort
Amsoil where i live is such a pain in the butt to get.. Seems when i call a so called dealer in my area its someone running a dealer in their garage.. It not available in any retail store here....
Hide Signatures
       Post #: 16
RE: Gas/Oil Mix?? - 10/28/2008 11:35 AM
PAPE
Score: 100
Last Login: 12/8/2009
Status: offline
you all forgot about the 150:1 fuji super oil......
Every single plane I flown has crashed. None were my fault.
Hide Signatures
(in reply to n2rc)
       Post #: 17
RE: Gas/Oil Mix?? - 10/28/2008 2:11 PM
altavillan
Score: 100
Last Login: 10/4/2009
Status: offline
It will not be long at all before 2 cycle oil will have to be environment friendly here in Ca. You can read that as banned in Ca. Because what mfrg will risk lawsuits from environment nazi's. And as Ca. goes the rest soon follow.
So we better hope some mfgr's can come up with some type of lube for our engines that allows us to continue our hobby. More than likely it will be a Synthetic with a mix ratio of 100 to 1 or more.
The laws have already been passed. In 2010 the law becomes effective. All outdoor power equipment from the smallest yard care power tools to massive Construction equipment will need to have engines certified to have the latest polution control devices. Should be interesting to say the least how we manage to go through this new set of government requirements.
I didn''t put the bullet in the fire and you quit talking about my mother! "Cosby, Shop Class, 1968 or so"
Hide Signatures
(in reply to PAPE)
       Post #: 18
RE: Gas/Oil Mix?? - 10/28/2008 3:17 PM
tkg
Score: 149
Status: online
IF you have an engine that requires Preminum then follow Pe's advice. If you engines will run on reg then mix up some Penz @ 40:1. With what passes for gas these days just mix 1 gal at a time and keep the freshest gas you can.
TKG
To much power is just about right.
Hide Signatures
(in reply to altavillan)
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.016RCU1
