These really are hard to start!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> ZDZ & RCS Support >> These really are hard to start!
Page: [1] 2   next >   >>
Login
These really are hard to start! - 10/25/2008 7:25 AM
Lins
Score: 100
Last Login: 6/10/2013
Status: offline
Wow, these really are hard to start! My ZDZ Super 80 takes FOREVER to start. The first time it started pretty good, but was very rich and slowly killed the engine while idling before I leaned it out. Once I adjusted the low needle, it seems a lot harder to start. I've tried enrichening and leaning it, but it seems to be luck that gets it started. I advanced the timing a little tonight, but I won't run it until tomorrow. I tried the 5-5-1, and even tried more than 5's. Any ideas what adjustments to make to try starting it a little easier? Once it starts it runs awesome!
_____________________________
Cub Brother #10
Waco Brother #221
Hide Signatures
       Post #: 1
RE: These really are hard to start! - 10/25/2008 6:32 PM
Zeeb
Score: 111
Last Login: 6/17/2013
Status: offline
Since it's the weekend, I'll offer a couple of thoughts for you to consider.
ZDZ's need to be "wet" to start (when cold) or you're wasting your time and the most common issue I see with them is that you must have the choke closing all the way whether you use a servo or manual setup, make sure it's closing. Once you verify that, the 5-5-1 thing is a good place to start and you'll figure out what works for your engine as you get to know it better. I run mine dry at the end of each flying day, so it takes a bit more for the first start but the key for me is listening for the "snotty nose" sound from the engine when you flip it over with the throttle cracked and the choke closed. Once I hear that, it's choke off, ignition on and mine will usually go the next flip. If it's still a bit warm, no choke just turn on the ignition and mine usually go first flip. If it's been sitting for an hour or something, I give 'em one choke flip and they usually go the next flip. I always turn off the ignition when choking because if it fires with the choke closed, it'll be flooded and you're in for more flipping.
You mentioned it getting hard to start after setting needles; it is possible to set them just a tad lean when they are warm and then it's tough to get 'em going again when cold. Now we're not talking about a lot of difference in the low speed needle setting here either, once you're close, the width of a screwdriver blade may make the difference. So when you get close, be gentle on the final needle adjustments. If it's new as it seems, being a bit rich on the bottom will make for easier starting and it's definitely better than being too lean.
I wouldn't monkey with the timing as in my experience, if it's set correctly there's no advantage to changing that. If you advance it, it may run hotter and make it more difficult to start without any performance gain and if you retard it, you'll lose power although it might be a bit easier to start. Just leave it alone, 6.5 mm is used on a lot of the ZDZ's, but I can't remember if that Super uses 7 mm?
One last thought; if you have the Bing carb there were some issues with those and I think RCS is recommending and now selling the Super 80 with a Walbro carb.
Zeeb
Hide Signatures
(in reply to Lins)
       Post #: 2
RE: These really are hard to start! - 10/25/2008 7:40 PM
Lins
Score: 100
Status: offline
Thanks Zeeb. I tried last night with choke on, full throttle 5 flips or so, then left the choke on, high idle, ignition on until it popped. Then just a couple flips and it started, but it had some residual heat in it. I'll mess around this weekend with it if my shoulder doesn't get too sore. I find if I richen the low end any, it runs way too rich at idle and won't stay running.
Cub Brother #10
Waco Brother #221
Hide Signatures
(in reply to Zeeb)
       Post #: 3
RE: These really are hard to start! - 11/2/2008 6:17 AM
mrbigg
Score: 155
Status: offline
Choke closed, ignition on, until it pops. Usually under ten. Open choke, two or three flips until it starts.
Smooth, like Keith Stone.
Hide Signatures
(in reply to Lins)
       Post #: 4
RE: These really are hard to start! - 4/12/2009 7:41 AM
Wanabflyin
Score: 100
Last Login: 12/26/2009
Status: offline
What if it never pops, it just floods?
Hide Signatures
(in reply to mrbigg)
       Post #: 5
RE: These really are hard to start! - 4/12/2009 2:49 PM
mrbigg
Score: 155
Status: offline
Something with the spark is bad. Bad plug, ignition, depleted battery, etc. Pull the plug, put it back in the cap and lay it against the cylinder. Rotate the prop and see if you have spark. I usually wear glove so I don't get zapped. Let us know what you get or don't get.
Hide Signatures
(in reply to Wanabflyin)
       Post #: 6
RE: These really are hard to start! - 4/14/2009 7:33 AM
Wanabflyin
Score: 100
Status: offline
When I pull the plug it has Spark, just keeps flooding out. I did get it started this weekend, Tried the 551 and nothing so I turned it upside down in the stand and on the second flip it poped. I don't want to have to hang my plane upside down to start. Is there any other way to clear a flood?
Hide Signatures
       Post #: 7
RE: These really are hard to start! - 4/14/2009 4:40 PM
mrbigg
Score: 155
Status: offline
How good is the spark? I've had spark on different engines before and they wouldn't start. I replaced the plug and they started right up. A guy at the field couldn't get his G62 to light. It had spark. I told him to replace the plug. He didn't believe me. I ran into town to get a plug. The engine fired right up with the new one. Try that first. It's the cheapest solution.
Hide Signatures
       Post #: 8
RE: These really are hard to start! - 5/25/2009 11:28 PM
Wanabflyin
Score: 100
Status: offline
The spark is really strong.  I tried to start it today, wanted to try to fly a little on the holiday and nothing.  Pulled the plug and it is bone dry it doesn't want to suck fuel nows.  It goes from flooding to nothing...  ZDZ is never getting my money again.  Any help to get this thing started would help alot.  I have tied the 551 and nothing, I have done full chock and full throttle till it pops and it never pops.  the Ing battery is full charged, new spark plug.  100:1 AMS oil with perium fuel.
Thanks for any help
Hide Signatures
       Post #: 9
RE: These really are hard to start! - 5/26/2009 4:13 PM
mrbigg
Score: 155
Status: offline
quote:
ORIGINAL: Wanabflyin
Thanks for any help
Your using the wrong oil for one thing mix. ZDZ engines require nothing leaner than a 40:1 mix to help seal/protect the rotary valve. I wonder if that's the reason it's not drawing fuel properly.
Hide Signatures
       Post #: 10
RE: These really are hard to start! - 5/27/2009 4:11 AM
Wanabflyin
Score: 100
Status: offline
hmm I may have to try that.  Every one told me to use the AMS oil after break in.  I will get some new fuel this week and some good oil and try it out.
Hide Signatures
       Post #: 11
RE: These really are hard to start! - 5/27/2009 6:27 AM
Vinnie6
Score: 100
Last Login: 4/16/2013
Status: offline
Can't you mix Amsoil Dominator 40:1?  That is my plan when I finally finish my bird.
V6
Hide Signatures
       Post #: 12
RE: These really are hard to start! - 5/27/2009 8:17 AM
Wanabflyin
Score: 100
Status: offline
I have Ams oil Saber and not sure if I can mix it at 40:1.  the bottle says 100:1 but I don't see why not.  any experts have any advice for this?
Hide Signatures
(in reply to Vinnie6)
       Post #: 13
RE: These really are hard to start! - 5/27/2009 8:23 AM
Lins
Score: 100
Status: offline
If the bottle says you can mix 40:1 yes, otherwise 100:1 oil is usually meant to be mixed at 100:1, and not to change the ratio.  same with all oils basically, unless they specify otherwise.
Cub Brother #10
Waco Brother #221
Hide Signatures
       Post #: 14
RE: These really are hard to start! - 5/27/2009 3:34 PM
Vinnie6
Score: 100
Status: offline
I believe Lins is right.  Sabre is meant for 100:1.  I would not mix Sabre at 40:1.  Dominator, on the other hand, is meant for 50:1 premix or for injection systems, like snowmobiles.  Since the difference between 50:1 and 40:1 is only 1/2 oz. per gallon, I can't see why Dominator can't be mixed at 40:1.  Just my opinion, though.
V6
Hide Signatures
(in reply to Lins)
       Post #: 15
RE: These really are hard to start! - 5/27/2009 3:55 PM
ScottK
Score: 100
Last Login: 6/18/2013
Status: offline
Sabre is commonly mixed from 100:1 to 65:1, with a sweet spot crowd using 85:1
Dominator is commonly mixed from 50:1 to 25:1, with 40:1 being very popular.
The Dedicarne...Every Day: Fly, Build, or Buy!
Hide Signatures
       Post #: 16
RE: These really are hard to start! - 5/28/2009 7:30 PM
dragoonpvw
Score: 100
Last Login: 6/9/2013
Status: offline
I run my zdz 40 and zdz 50 on Dominator at 50 to 1. I also now use it in every engine I own, Zenoahs up to my 3w 150 inline with great results.
good luck
 Paul
In this world, Elwood, you must be oh so smart or oh so pleasant
Well, for years I was smart. I recommend pleasant
Hide Signatures
(in reply to ScottK)
       Post #: 17
RE: These really are hard to start! - 6/3/2009 8:49 AM
Wanabflyin
Score: 100
Status: offline
well I did get it started and ran well.  I am going to use this plane as my 3d trainer and when it dies a great death I will sell the engine and up grade to a da
Hide Signatures
(in reply to dragoonpvw)
       Post #: 18
RE: These really are hard to start! - 7/1/2009 3:49 AM
louu
Score: 100
Last Login: 5/25/2012
Status: offline
hi everybody, i have a zdz 50 and it runs really bad around hover mode, if i lean it out to make it run good it wont start. it has a walbro carb. a friend of mine said he heard something about a diffrent carb but cant remember what it was about. any body know what i can do to make it run better. here is a link to a video of it so you can hear it run, just fast foward to 5:00 minuets imm lou its in the red and white qq yak (dont break my balls ive only been flyin about 1 year lol)
http://www.youtube.com/watch?v=XfT-aIAd-Do
3d is just a controlled crash
Hide Signatures
       Post #: 19
RE: These really are hard to start! - 7/2/2009 9:24 PM
Lins
Score: 100
Status: offline
Where do you have your carb vented to? Have you tried extending the vent back into the fuselage behind the 'cockpit'?
Cub Brother #10
Waco Brother #221
Hide Signatures
(in reply to louu)
       Post #: 20
RE: These really are hard to start! - 7/3/2009 12:01 AM
louu
Score: 100
Status: offline
quote:
ORIGINAL: Lins
are you talking about the little hole in the pump cover??? its just in the cowl, i dont think i have anything on it.
Hide Signatures
(in reply to Lins)
       Post #: 21
RE: These really are hard to start! - 7/3/2009 1:51 AM
Lins
Score: 100
Status: offline
Yup, that's what I'm referring to. Some people route an extension deep into the fuselage, but apparently that is more if you encounter surging. Never know, though.
Cub Brother #10
Waco Brother #221
Hide Signatures
(in reply to louu)
       Post #: 22
RE: These really are hard to start! - 7/3/2009 2:27 AM
Oilsands
Score: 100
Last Login: 4/4/2012
Status: offline
First thing, when starting for the first time of the day have the choke on and wot and ign off. Flip till you see fuel drawn up the fuel line into the carb, then flip it 5 times. Then choke off, wot and ign off, flip 5 more times. The ign on, idle or 1-2 clicks above and ign on, should start right away (1 or 2 flips).
I would also turn the L needle out 1 1/2 turns out as a starting point, tweak it a bit till you get smooth transition of the throttle from idle to wot. You can tweak the needles a bit more once the engine gets broken in.
I used to use Amsoil Domminator 50:1 oil. I started off with 40:1 mix then switched to 50:1 mix, after about a dozen flights the motor (ZDZ 80 rv) started to lose power. Looking inside the spark plug hole, I noticed cylinder wall coating started to come off (this was an engine with many flights on it), sent in for repair. Was told it was more than likey a failure due to 50:1 mix, told to never run a mix thinner than 40:1 mix (36:1 for breakin). I recently switched oil to Yamaha 2 stroke oil on all my rc engines, I noticed a slight increase in rpm and more noticable was the drop in cyl temps. It was a very expensive repair bill, I will never run any thinner mix than 40:1 in any engine (especially in the ZDZ engines). I have two DL100's and the ZDZ 80 rv, I like both these engines.
Anthony
Hide Signatures
(in reply to Lins)
       Post #: 23
RE: These really are hard to start! - 7/3/2009 4:44 PM
louu
Score: 100
Status: offline
thanks lins ill give it a try
Hide Signatures
(in reply to Oilsands)
       Post #: 24
RE: These really are hard to start! - 7/4/2009 3:30 AM
Lins
Score: 100
Status: offline
I haven't had mine flying yet, waiting on batteries so I can't really help you too much. All I can say is check with RCS, I hear they have awesome service!
Cub Brother #10
Waco Brother #221
Hide Signatures
(in reply to louu)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> ZDZ & RCS Support >> These really are hard to start!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.453RCU1
