ASU Blowing out plugs?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> AMT Netherlands >> ASU Blowing out plugs?
Page: [1]
Login
ASU Blowing out plugs? - 10/27/2008 5:58 AM
tr0cks
Score: 100
Last Login: 12/2/2012
Status: offline
i just purchased a used asu, and got one successful start with it now it seems to melt the glow plug coils. any clues? i blow out 5 glow plugs in a row.
Hide Signatures
       Post #: 1
RE: ASU Blowing out plugs? - 10/27/2008 5:31 PM
Mark Taylor
Score: 105
Last Login: 5/19/2013
Status: offline
Have you put a voltage meter on it to see what it is putting out?
_____________________________
Mark Taylor
Team Horizon / BVM Jets
Hide Signatures
(in reply to tr0cks)
       Post #: 2
RE: ASU Blowing out plugs? - 11/6/2008 8:07 AM
tr0cks
Score: 100
Status: offline
looks like problem solved was using med. glow plugs and not cold rossi 8's
Hide Signatures
       Post #: 3
RE: ASU Blowing out plugs? - 11/29/2008 10:42 PM
Captainbob
Score: 100
Status: offline
For anyone else having problems blowing out glo plugs, on the ASU PC board is a potentiometer that regulates plug current. Simply adjust that pot for the type of plug you are using.
I have been in RC for 45 yrs continuously. My interests are wide ranging, from turbines to electrics. I currently fly among
Hide Signatures
       Post #: 4
RE: ASU Blowing out plugs? - 9/19/2012 11:51 AM
Xairflyer
Score: 105
Status: offline
We have the same problem with a Pegasus can you do this on all ASU's (cant check as model is at a friends)
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to Captainbob)
       Post #: 5
RE: ASU Blowing out plugs? - 9/19/2012 4:05 PM
roo
Score: 100
Status: offline
Surely you are referring to the Ecu. The ASU is the AMT Auxillary Startup Unit. Seamus, I already told Phelim to ring Bennie at AMT about his problem. If I am wrong then I misunderstood Phelim when he rang me recently. The best option here is to send the ECU to Bennie. Problem will be solved pronto.Best Regards. Paul.
roo
Hide Signatures
(in reply to Xairflyer)
       Post #: 6
RE: ASU Blowing out plugs? - 9/19/2012 7:49 PM
Xairflyer
Score: 105
Status: offline
Sorry I misunderstood, I thought from other posts AMT called their ECU an automatic starting unit ASU
So I am assuming then there is'nt a pot on the ECU to adjust the glow plug power like there is on the ASU's.
Think Phelim wants to explore all options first rather than have to strip it out and wait for it to come back, especially now as we are flying nearly every weekend.
www.jmaireland.com
Hide Signatures
(in reply to roo)
       Post #: 7
RE: ASU Blowing out plugs? - 9/28/2012 6:00 AM
Skycat66
Score: 100
Last Login: 1/13/2013
Status: offline
Hi,
No, there isn't a pot in the ECU for adjusting the plug voltage. You can do this by alternating a parameter with the TMC program. This TMC program can be download on the AMT Ntehrlands site www.amtjets.com.
Address 201 is for the plug voltage.
Cheers,
Hide Signatures
       Post #: 8
RE: ASU Blowing out plugs? - 9/28/2012 11:54 AM
Xairflyer
Score: 105
Status: offline
Thanks, we discovered that the pot is only on the ASU's.
I now have a serial lead made and the software downloaded. I has a good idea there had to be a user adjustable way of doing it depending on the battery packs/plugs you wanted to use.
The software has everything you need with all the running parameters and dashboard, will have a play with it tomorrow.
www.jmaireland.com
Hide Signatures
(in reply to Skycat66)
       Post #: 9
RE: ASU Blowing out plugs? - 10/8/2012 9:27 PM
Xairflyer
Score: 105
Status: offline
Just an update for anyone with same problem, we plugged in the data/comms lead to the telemetry port, and ran the software on a laptop and changed the plug setting to 18 (1.8v) with our rossi 8 plugs using 10 cell NIMH, and has had 6 starts since without blowing plug so problem cured!
www.jmaireland.com
Hide Signatures
       Post #: 10
RE: ASU Blowing out plugs? - 10/19/2012 1:52 PM
AMTdude
Score: 100
Last Login: 4/23/2013
Status: offline
captainbob is correct in stating that there is an glow adjustment inside the ASU if you need to adjust, trim pot is in there, blue one i think.
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
