RE: Aero Works P-51?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: Aero Works P-51?
Page: <<   < prev  33 34 35 36 37 [38] 39 40 41 42   next >   >>
Login
RE: Aero Works P-51? - 1/13/2012 5:30 PM
Zeeb
Score: 111
Last Login: 5/22/2013
Status: offline
James,
Were you using the tiny rubber O-rings that only seem to last a couple of times on installing the cowl? I'm currently looking for a source for those O-rings as I don't have any that tiny and past experience indicates they may help prevent the problem
Russ,
I think it was you I had the discussion with about the Sierra roll pins? No directions with the gear and I find this package of four roll pins in one of the oleo struts. Had to call Darryl to ask him what they were for.... I know I had an exchange with someone about that but I don't recall it being James????? But thank you for the thought.
Also where is your ignition module mounted, on the bottom of the engine box like AW shows or did you move it inside the fuselage? I've seen several reports here of dead sticks which turned out to be the module overheating about five minutes or so into a flight and then it shuts down. So some have moved the module inside and that's why mine is inside. The other possible problem is that something has changed in the fuel system, blockage, air leak or the like which has cause the engine to go lean and get hot and they'll shut down.
_____________________________
Zeeb
Hide Signatures
(in reply to rslstft)
       Post #: 926
RE: Aero Works P-51? - 1/13/2012 8:11 PM
rslstft
Score: 100
Last Login: 5/23/2013
Status: offline
Zeeb,
Thanks for the suggestions, I DID move the ignition inside and that's when I quite having dead sticks for quite a while. Just all of a sudden without doing any changes, the problem started again. I change the entire fuel system, tank, clunk, lines, filter, everything and still does it. My next thing is either try a new ignition box or rebuilding the carb, but I doubt it's the carb as it runs fine for anywhere from 4 - 7 minutes then just suddenly dies. Usually when the engine overheats, you can hear it sag a little, lose power, then it dies. Mine, just gives a cough, then about 5-10 seconds later dies, almost like it's running out of fuel.
On another note, I got a good look at the B model at the AMA show and talked to Rocco quite a bit. It's really a nice looking model and I'm sure the fans of B models will like it. (Me - I'm a D model type!)
Russ
Hide Signatures
(in reply to Zeeb)
       Post #: 927
RE: Aero Works P-51? - 1/13/2012 8:19 PM
JamesPool
Score: 100
Last Login: 5/14/2013
Status: offline
Normal0falsefalsefalse ontGrowAutofit />MicrosoftInternetExplorer4
I didn’t reinstall the eyelets.  I simply put some heavy plastic tape on the outside of the each hole and then filled the hole with regular epoxy. I also added some glass chop in the center of the enlarged hole and then laid 3 layers of glass on the top of each repair.
As it relates to the o-rings – I gave up on those. I’m using rubber back #6 washers (#4 would work too).  They aren’t as noticeable as you might think.
Hide Signatures
       Post #: 928
RE: Aero Works P-51? - 1/13/2012 9:04 PM
Zeeb
Score: 111
Status: offline
quote:
ORIGINAL: rslstft
Zeeb,
Sounds like it's pointing more toward the module but there are a couple of other things to try. I've got a little 50cc aerobat that was doing something similar. The local engine guru suggested I try changing the battery which I did and it didn't help. So he suggested plugging the battery directly into the ignition to by pass the switch. I pooh poohed that idea thinking a switch would either work or not and I chased a bunch of other stuff including the fuel system and carb overhaul. It was still doing it so in desperation I connected the battery directly to the module and presto! problem solved, it was the switch going bad.
Other "shot in the dark" possibilities before you go buying and ignition module; DA's are notorious for this type of behavior if the Power Pole connectors feeding the module have not been replaced. Weight and vibration I guess causes them to develop an intermittant short near the connectors. Other issue although not as common is the same thing in the ignition timing pickup wire at the two little servo connectors, wires start going south and it's hidden by the nifty red jacket on that wire.
I don't suppose it'll do it on the ground? I was thinking maybe you could try warming up the module with a heat gun and see if it does it? Bit extreme on that one and I've never done it but the idea popped into my head. Last, what has DA got to say about it?
On the new B model, I'm not a fan but IIRC you can buy it without landing gear? Wonder why????
Zeeb
Hide Signatures
       Post #: 929
RE: Aero Works P-51? - 1/13/2012 9:24 PM
rslstft
Score: 100
Status: offline
Ha! I did notice the plane is offered without gear! Hmmmm.
Funny you mention about the connection with the engine. I talked to the guys from DA at the AMA show and they asked it I had a ignition kill wired in (I do) and suggested I bypass it to see if that's the problem. Also mentioned about the battery and switch. Plus, I do still have to stock Anderson Powerpoles on the wires, so may change those to Deans. They said their ignition is very tolerant of heat and usually won't overheat under normal circumstances. I haven't had time to delve into it yet and give these a try.
Russ
Hide Signatures
(in reply to Zeeb)
       Post #: 930
RE: Aero Works P-51? - 1/13/2012 10:15 PM
Zeeb
Score: 111
Status: offline
Well sounds like they pointed you at similar things to what I mentioned. I will say that there does seem to be a few more issues with DA ignitions than maybe some other makes but DA usually makes it good if that turns out to be the issue, it's just pin pointing the thing that can be difficult. As far as heat not really affecting them, well all electronics can have issues and if it had been behind the muffler causing it to quit for some time before you moved it, it may have started the process?
On the PowerPoles, even DA suggested to me that I replace them so I changed 'em out on my 120 and the 60, but that is not an "official" position from DA... lol
I'm not sure changing out to Deans would solve the problem as it seems to be a case of the extra weight of the connectors and model vibration. It starts breaking the wires inside the insulation so it's difficult to detect and I'm thinking a Deans would be a similar issue? I just use HD servo connectors to feed the power to my gasser ignition modules just like most of the manufacturers use. Not sure why DA has those PowerPoles but was led to believe that it has something to do with the Austrailian module supplier not wishing to modify the unit.
Yeah my little aerobat that I had the issue with has a fiber optic kill switch, all my gassers do but if you just go directly from the battery to the module you bypass both components and my problem was with the off/on switch not the kill switch.
Zeeb
Hide Signatures
       Post #: 931
RE: Aero Works P-51? - 1/13/2012 10:27 PM
rslstft
Score: 100
Status: offline
Thanks for the help, Zeeb. As soon as I get some time, I give these suggestions a try and report back.
Russ
Hide Signatures
(in reply to Zeeb)
       Post #: 932
RE: Aero Works P-51? - 1/17/2012 1:43 AM
Zeeb
Score: 111
Status: offline
CG range????
Hey Guys,
This is the first model I've assembled where the manufacturer gives you an exact location for the CG rather than a range. I normally start with a CG slightly ahead of the center of that range for a slightly nose heavy model to do the Maiden flights and initial trimming, and then adjust the CG back to fit my tastes.
So are you guys using the manual's 2 3/4" back from the leading edge at the wing tip only, or is there a range one might use?
I haven't actually checked mine yet as I have to get a friend to come over and help, I'm just trying to cover my bases....
Thanks!
Zeeb
Hide Signatures
       Post #: 933
RE: Aero Works P-51? - 1/17/2012 4:54 PM
JamesPool
Score: 100
Status: offline
Zeeb:
I can't tell you the range, but I did everything per the manual and my CG came out to where it was supposed to be.  If anything I’m nose heavy and the plane flies perfectly.
James
Hide Signatures
(in reply to Zeeb)
       Post #: 934
RE: Aero Works P-51? - 1/17/2012 5:08 PM
Sekhet
Score: 100
Status: offline
Hello All,
I’ve finally decided to jump in with both feet and get the P-51! My plans are to detail it out with a sliding canopy, functional bomb/tank drops and scale exhaust. I think I have worked out the details for the canopy and drop tanks but I need some advice on the scale exhaust.
I found that Keleo Creations now has an exhaust for the AW P-51 and looks like a pretty easy modification to do.
But I do have some questions;
Has anyone had any experience with Keleo Creations’ exhaust systems and are they a good product?
Other than cutting the cowl for the engine cylinder, how much more should I open up the cowl for proper engine cooling? (I’m planning on using a DA 50)
Thanks in advance for any help anyone can offer!
http://www.keleo-creations.com/index.php?main_page=product_info&cPath=92_93&products_id=243
Best Regards,
Cris B.
Hide Signatures
(in reply to JamesPool)
       Post #: 935
RE: Aero Works P-51? - 1/17/2012 5:18 PM
JamesPool
Score: 100
Status: offline
The scale exhaust looked and “functioned” well on the plane that I saw it on, which was another Mustang with a DLE30 in it. The exhaust "functioned," but severely starved the engine of performance. So much so that my buddy by-passed it and added a traditional exhaust system. Take a look at the Aeroworks version. If it looks like the exhaust isn’t doing anything “unnatural,” it could be worth a try. The version I saw really choked the flow and made it take a very circuitous path to exit.
Hide Signatures
(in reply to Sekhet)
       Post #: 936
RE: Aero Works P-51? - 1/17/2012 6:55 PM
Thunderbolt47
Score: 111
Status: offline
quote:
ORIGINAL: JamesPool
The scale exhaust looked and “functioned” well on the plane that I saw it on, which was another Mustang with a DLE30 in it. The exhaust ''functioned,'' but severely starved the engine of performance. So much so that my buddy by-passed it and added a traditional exhaust system. Take a look at the Aeroworks version. If it looks like the exhaust isn’t doing anything “unnatural,” it could be worth a try. The version I saw really choked the flow and made it take a very circuitous path to exit.
Sencond that! I had one on a ZDZ-50NG in a T/F. It robs about 700 RPMs. Mine didn't stay on long. I would just go with a J-tec compact pitts muffler. It was made for the DA50 to be used in this plane.
Kelly
BTW, I thought the AW 51 came with a sliding canopy already.
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
       Post #: 937
RE: Aero Works P-51? - 1/17/2012 11:11 PM
Zorba1
Score: 100
Last Login: 3/9/2013
Status: offline
I thought those exhausts were tested for performance.
If they starve the engine of rpm's don't you think that Kelvin would of said something.
I got mine for the DLE55. The engine is not mounted on the fuse yet should I be worried?
Cheers
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Thunderbolt47)
       Post #: 938
RE: Aero Works P-51? - 1/17/2012 11:56 PM
frisconick
Score: 100
Last Login: 5/9/2013
Status: offline
I had one on an ESM Mustang with a DLE-30. It looked and sounded great! Performance wasn't up to snuff. Other planes at the field with the same engine and prop with the stock exhaust were getting 700 RPM more than me. I kept the scale stacks on the side of the cowl, but put a JTEC pitts on it. I gained 900 RPM. The plane is a rocket now.
Nick
Corsair Brotherhood #44
Hide Signatures
(in reply to Zorba1)
       Post #: 939
RE: Aero Works P-51? - 1/18/2012 12:59 AM
Thunderbolt47
Score: 111
Status: offline
looks nice, but the more turns and tubing the exhaust has to go thru the slower it goes. The faster it gets out the more power an engine can make.
BTW he in the selling business.
Hide Signatures
(in reply to frisconick)
       Post #: 940
RE: Aero Works P-51? - 1/18/2012 1:18 AM
Sekhet
Score: 100
Status: offline
Thanks to everyone who has responded so far.
I had no idea that those exhaust systems robbed that much power from the engine! I think I’ll just go ahead and stick with the J-Tec pitts unless someone can show me evidence to the contrary.
@ Thunderbolt47: Yes the AW P-51 does come with a sliding canopy. What I plan to do is set it up so it can be opened and closed from my transmitter. I have also given some considerable thought to making the rear radiator vent flap operational but haven’t decided if I should link to the throttle or to run it as a separate channel by itself. I’m still doing the research on it.
Best Regards,
Cris B.
Hide Signatures
       Post #: 941
RE: Aero Works P-51? - 1/18/2012 3:26 AM
Zorba1
Score: 100
Status: offline
I got mine hooked up to the throttle for now just to see how she works.Later maybe I'll change it
Cheers
http://www.youtube.com/watch?v=zxau0i0porg&feature=player_embedded
Hide Signatures
       Post #: 942
RE: Aero Works P-51? - 1/18/2012 3:27 PM
Sekhet
Score: 100
Status: offline
Hey Zorba,
I checked out your video and I really like your covering and rivet detail!
It looks like you did a first class job adding the operational cooling exhaust ramp.
Well done!
Best Regards,
Cris B.
Hide Signatures
       Post #: 943
RE: Aero Works P-51? - 1/22/2012 4:15 PM
miker49
Score: 100
Status: offline
i have finally glued the wing together.everything lines up ,locating dowels and wing bolts.went to start the air scoop and the rear of the scoop is 1/8" wider on both sides.won't let the flaps come down .i plan on contacting aeroworks on mon to see if anyone else has had this problem.anyone here run into this?
Hide Signatures
       Post #: 944
RE: Aero Works P-51? - 1/22/2012 5:56 PM
Zeeb
Score: 111
Status: offline
quote:
ORIGINAL: miker49
i have finally glued the wing together.everything lines up ,locating dowels and wing bolts.went to start the air scoop and the rear of the scoop is 1/8'' wider on both sides.won't let the flaps come down .i plan on contacting aeroworks on mon to see if anyone else has had this problem.anyone here run into this?
Not seen that issue reported, one of the guys did have an issue with the air scoop fitting but it was an angle problem on an ARC version.
How wide is the scoop at the back corners? Mine is 7 3/4" straight across and the rear corners line up exactly with the corners formed by the trailing edge and the cutout for the flaps.
Check you locator pins on the front. Mine seemed to be short so I called AW and they said that sometimes in shipping the pins get knocked back into the wing. On one side all it took was a tiny bit of pressure and the pin slid back into the wing. On the other side, just a bit more pressure and in fact I was going to call it good and then it too broke loose. They should stick out the front of the wing about 1/2".
Zeeb
Hide Signatures
(in reply to miker49)
       Post #: 945
RE: Aero Works P-51? - 1/22/2012 6:12 PM
JamesPool
Score: 100
Status: offline
Yes.  I had the same probblem.  I just removed the material from the scoop.
Fun stuff,
James
Hide Signatures
       Post #: 946
RE: Aero Works P-51? - 1/22/2012 8:47 PM
miker49
Score: 100
Status: offline
mine to measures 73/4".the two outside points lay over the inside edge of the flap.my first idea was to take some off each edge.thought i would see what others have had here
Hide Signatures
       Post #: 947
RE: Aero Works P-51? - 1/22/2012 9:08 PM
Zorba1
Score: 100
Status: offline
I had a similar problem with the scoop and the flaps. see post #883 and #885.
I trimmed the flap a bit and I had to fill under the scoop so it will line up with the rest of the fuse.
Mine was an ARC version.
Cheers
Hide Signatures
       Post #: 948
RE: Aero Works P-51? - 1/24/2012 3:49 AM
Zeeb
Score: 111
Status: offline
Okay guys, can we stand another question/problem with the tailwheel gear doors?????
I monkeyed around with it when I changed out the airlines and did the leak check, I knew it was tight as has been mentioned but figured I'd adopt one of the fixes already engineered by several folks here.
I put the wing on it the other night for the first time and the landing gear ops check was less than I'd hoped for since I was setup with a bit more speed than I wanted to account for no tailwheel hookup at that time. Got the Robart adjustable valve for the inner gear doors too tight but the worst part is the tailwheel gear doors. Takes about 80psi in the system to get 'em open and when I retracted them the one door stays open.
It's REALLY stiff like one of the three hinges is binding, you can open the thing by hand and stop it wherever you want, even at a 45 degree angle with the little elastic snubbers hooked up even. Makes it that much harder for the gear to force the doors open.
Talked to Mark at AW today and he want's me to cut some of the snubbers as guys have been doing here and lube the hinges with silicone, but that's only part of the problem.
Any of you guys have a hinge misalignment issue or something with one of those gear doors? I can't see any glue in there but think at least one of the three hinges is out of line and cause the bind. Anybody got any ideas on how to check that without tearing all three hinges out and starting over?
Zeeb
Hide Signatures
       Post #: 949
RE: Aero Works P-51? - 1/24/2012 10:11 AM
Zorba1
Score: 100
Status: offline
Hey Zeeb, been there done that.
I don't know about the ARF version back on my ARC version I took off the pins from the hinges, remove the doors
and hone the holes with a bit bigger drill bit.
Re-install the pins and voila..
Bill
Hide Signatures
(in reply to Zeeb)
       Post #: 950
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
