RE: HET F-18 Twin 70mm EDF
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: HET F-18 Twin 70mm EDF
Page: <<   < prev  1 2 3 4 [5]
Login
RE: HET F-18 Twin 70mm EDF - 3/24/2009 12:37 AM
Greg Covey
Score: 104
Last Login: 11/21/2009
Status: offline
Bill,
Yes, you can use the micro CNC retract set on the F-18. It is sold most places that sell the jet.
The only EDF jets I have seen that come close to a turbine noise are the high-end ones using a BVM Viofan, E-Turbax, or Byron conversion with a Scorpion motor.
As for servos for all those functions, you'll need plenty of them. 2 rudders, 2 ailerons, 2 elevators, 3 retracts (4 if steerable).
Now you can start to see why I made the design choices for my twin 70mm F-18.
Good luck!
< Message edited by Greg Covey -- 3/24/2009 12:38 AM >
_____________________________
Visit my Web Hangar at www.gregcovey.com/rc.htm
Hide Signatures
(in reply to bandit13)
       Post #: 101
RE: HET F-18 Twin 70mm EDF - 3/24/2009 6:24 AM
bandit13
Score: 100
Last Login: 11/22/2009
Status: offline
Greg,
Thanks for the information. I want fly the jet with everything, reason is so I can keep sharp when I fly a turbine jet with 12 servos. The field I use is to small for turbines and I can't always get away on the weekends to the bigger field. Your thread has been a excellent insight into the HET jets, keep it going.
Bill
Hide Signatures
(in reply to Greg Covey)
       Post #: 102
RE: HET F-18 Twin 70mm EDF - 3/25/2009 2:34 AM
JR16
Score: 100
Last Login: 11/10/2009
Status: offline
I got my f-18 last week and i was looking at it i dont think there is any real way to get the main retracts in because the intake tubes are in the way. so i decited to build mine with the fixed gear because i like touch and go's lol
Hide Signatures
       Post #: 103
RE: HET F-18 Twin 70mm EDF - 4/7/2009 3:55 PM
bandit13
Score: 100
Status: offline
Hey Greg,
If I had a Blue Angel scheme HET F-18 could I sand off the blue and yellow and primer it and then paint it grey.
Hide Signatures
       Post #: 104
RE: HET F-18 Twin 70mm EDF - 4/7/2009 10:54 PM
Greg Covey
Score: 104
Status: offline
Hi,
Re-painting is not one of my fortes. I would try painting the bottom hatch first without sanding and see how you like it. It may save you the work of sanding and priming the existing finish. Otherwise, your technique should work fine.
The wings and elevator sections will need to be recovered, not painted, with whatever color you choose.
Although it snowed here today, Spring is just around the corner!
Good luck!
Hide Signatures
       Post #: 105
RE: HET F-18 Twin 70mm EDF - 4/7/2009 11:00 PM
bandit13
Score: 100
Status: offline
Greg, I know the feeling of weather, spring is when we get the most snow. I have lived here 16 years and this year has been a very milded winter SO FAR. As far as the JET I will just buy a Gray version.
Hide Signatures
       Post #: 106
RE: HET F-18 Twin 70mm EDF - 6/14/2009 12:29 AM
ingas
Score: 100
Last Login: 6/15/2009
Status: offline
Hello.
           I purchased a mig-29 HET twin. Iam abit confused to how to wire -up the two - HET 2W-20 motor with the-Tsunami TS 72 ESC-. I have two fullymax 25c-3700mah 14.8 4s batteries. do i use a battery for both motors or a battery for each of the motors. this is my first electric plane i'am building. and what is the BEC used for. any help will be appriciated. thank you
Hide Signatures
(in reply to NJAIRSTRIKE)
       Post #: 107
RE: HET F-18 Twin 70mm EDF - 6/16/2009 12:43 AM
Greg Covey
Score: 104
Status: offline
Hi,
I would use one battery pack for each ESC and then connect the control lines from each ESC to a Y-harness going to the throttle channel on your receiver. If your TS 72 ESC has a built in BEC, then you must disable one of them by disconnecting the center red wire going to the Y-harness. In other words, you want to only use one of the ESC's BECs to power the receiver an servos.
If the ESC does not have a BEC, then use either a Rx. battery or an external BEC like the Castle Creations CC BEC.
Good luck!
For those wondering if I have flown my F-18 yet...my first two attempts to bungee launch it, and one hand-launch, were not successful but resulted in only minor damage. We now feel that we need 3x the plane weight as the pull force to make the plane start flying about half way through the bungee launch length. This formula has worked on other planes and we finally measured my existing pull at only 16lbs or about 2x the plane weight.
Hide Signatures
(in reply to ingas)
       Post #: 108
RE: HET F-18 Twin 70mm EDF - 6/17/2009 2:31 AM
Punkin1
Score: 100
Last Login: 11/13/2009
Status: offline
Hello Greg,
Where are all the good looking pictures of that great lookin F/A 18 you said you were going to post of the first flight. I have been waiting for those photos. Talk to you soon.
Ben Cubillos
Hide Signatures
       Post #: 109
RE: HET F-18 Twin 70mm EDF - 7/3/2009 11:10 PM
Greg Covey
Score: 104
Status: offline
I decided to give up on my bungee launch approach and install the landing gear. I used an E-flite S75 servo for the nose steering with a short and stiff control linkage. Although my first opportunity to test fly it off pavement is not until August 1st in Hamberg, NY, I will likely get an earlier chance to see if it will take off a short grass surface. The HET F-18 has plenty of power so I'll see what happens and report back.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Punkin1)
       Post #: 110
RE: HET F-18 Twin 70mm EDF - 7/12/2009 1:48 PM
Greg Covey
Score: 104
Status: offline
I had a chance to try the HET F-18 from grass using the stock wheels. We really thought it was going to take-off but it just missed having enough speed using the stock wheels. I have since swapped the stock wheels for some Dubro (225TL) 2-1/4" Treaded Lightweight Wheels which are slightly bigger and much harder than the soft foam ones supplied with the model. I will test the F-18 next off pavement on August 1st, and if successful, I will try it off grass again with the new wheels.
HET F-18 Stock Wheels Grass Take-off Attempts Video (4.5meg)
Hide Signatures
       Post #: 111
RE: HET F-18 Twin 70mm EDF - 8/15/2009 7:55 PM
Punkin1
Score: 100
Status: offline
Hi, Greg
I saw your take off attempts on grass. Looks like you could not muster enough speed to take off. Were you going to take off ? I wish you a lot of luck on your next attempt.
I'm finally getting back to finish my F 18 jet. My target date is for the next 3 weeks, give or take. I will take a vidio when I fly my F 18 and I will post it.
I hope yours has flown already. Talk to you soon.
Ben Cubillos
Hide Signatures
       Post #: 112
RE: HET F-18 Twin 70mm EDF - 8/18/2009 3:38 AM
Punkin1
Score: 100
Status: offline
Hi, Greg
I saw where you placed the electronic speed contols, up front where the front landing gear is. You said that you were going to make provisions to cool the ESC's. Did it work out for you ? The problem that I have is if I mount the ESC's behind the motor/fan units, will the esc's reduce the effectiveness of the fan units ? What if I just mount them outside of the fan tubes. Will they get hot and quit on me ? Let me know what you think and also if you can offer some suggestions.I hope to hear from you soon.
Ben Cubillos
Hide Signatures
       Post #: 113
RE: HET F-18 Twin 70mm EDF - 8/19/2009 12:49 AM
Greg Covey
Score: 104
Status: offline
Hi Ben,
Although I replaced the soft stock foam wheels with larger Dubro rubber wheels, my enthusiasm to get the F-18 in the air made me try it again off of grass instead of waiting for my first opportunity off pavement. The F-18 got light and ready to fly off grass but veered to the left and a cross wind rolled it over into a cartwheel. Without a rudder, we lost steering authority once the nose wheel got light. The harder Dubro wheels did help to take-off from grass.
The damage wasn't bad and I fixed it all except for a stripped elevator servo. Unfortunately, other projects have taken priority and I will now leave the HET F-18 repair to a winter project.
The ESCs should have some air flow over them so either keep them inside the exhaust tubes or move them up front like I did and add some air entry holes in the nose, and some air exit holes under the fuselage. Otherwise, keep the initial flights short (3 minutes) until you test the whole system out.
Good luck!
Hide Signatures
       Post #: 114
RE: HET F-18 Twin 70mm EDF - 8/19/2009 2:06 AM
Punkin1
Score: 100
Status: offline
Hi, Greg
Thanks for the information. At least I have an Idea on how to do this.
Ben
Hide Signatures
       Post #: 115
RE: HET F-18 Twin 70mm EDF - 8/25/2009 8:28 PM
bandit13
Score: 100
Status: offline
Greg,
Have you every put on a strake(fence) on the lex similiar to the real F-18C. I wanted to do this but don't know where to begin. Since I am using decals that use the strake for an acroynm of the squadron that this would add some realism to the jets.
Bill
Hide Signatures
       Post #: 116
RE: HET F-18 Twin 70mm EDF - 10/11/2009 3:43 AM
rctech2k7
Score: 100
Status: offline
Hi! Greg,
I have the same jet except that the color is gray. I found the same problems with the jet and did some modification already. I started with this jet using 5Ah 5-cell 25C lipo battery and I have good thrust which is around 70% of its weight using the original factory recommended setup. I like this jet and it flies great even on low and high speed except on some few problems. The landing gear is flexible and it caused a lot of bouncing for most landing. Another thing is landing on high alpha is very difficult because of a very small elevator control. I suggest if the company can produce it with the full horizontal stabilizer and pre-built retractable landing gear provision would be better. Now, my jet has modified stabilizer and complete retractable landing gear using 1/8” piano wire, so I can land smoother with high angle of attack. The only problem I got was the weight of the plane so I ended up upgrading the battery from 5S to 6S and make the rudders operational.
Here’s the full detail of the plane:
Aircraft Name: HET F/A-18 Twin EDF Jet
Description: Scale F/A-18 Twin EDF Radio Controlled Model Jet
Airframe Maker: High-End Technology
Built: October 2008 Maiden Flight: Oct 22, 2008 Status: Active, 233rd landings as of Oct 6, 2009
Length: 56" Wingspan: 39.3" Flying Weight: 8.7-lbs (3.95-kg)
Power System: 2 x 70mmØ EDF w/ Typhoon 2W-25 & HET 75A ESC on FlightPower EON28 22.2V 28C 6S LiPo 5100mAh total capacity (upgraded Apr 11, 2009)
Thrust: 6.4-lb @ 3.08-kW 50,000-rpm. Wing loading: 3.85-lb/ft²
Setup mode for flight control surfaces: Ailvators and flaperons
Updates: Retractable landing gear, full horizontal stabilizer and operational rudders
Flight Video: My YouTube Model Aviation Video
Aircraft photos:
Original high wing setup: (poor crosswind capability)
Corrected wing (after I cut and glued it back, this one can handle hard crosswind on takeoff and landings)
With modified horizontal stabilizer
Good luck and I hope you can bring it back in the air...!
John
< Message edited by rctech2k7 -- 10/11/2009 4:11 AM >
Hide Signatures
       Post #: 117
RE: HET F-18 Twin 70mm EDF - 10/12/2009 5:03 PM
Greg Covey
Score: 104
Status: offline
Bill,
I have not added a strake before. Perhaps if you post your question in the Turbine Jets forum you will get an answer. There are plenty of members with great building experience in that forum.
John,
Thanks for posting your grey F-18 setup. I like the look and will check out the video from home as YouTube is blocked here at work.
I am certain my F-18 would have flown off pavement but the grass take-offs require just a bit more power. I still plan to fix my elevator servo this winter but just didn't have the time during the flying season with so many other planes to focus on. I am already planning my winter building projects to keep me occupied in the long cold months up North.
Regards.
Hide Signatures
(in reply to rctech2k7)
       Post #: 118
RE: HET F-18 Twin 70mm EDF - 11/10/2009 2:11 AM
JR16
Score: 100
Status: offline
rctech2k7,
do you have any other photos of your modifications? it looks like you added anhidral(sp) to the wing? how did you accomplish this? i was wondering if you checked the incidence of the wing because my left wing is visibly lower infront compared to the right. do you have any photos of your retract setup? i fly from very short grass that is short enough to get a stock f18 foamy with a single 64mm fan off the ground. so, im not too worried about that but, am wondering if the retracts would hold up to the grass? what retracts are you using? with your stablizer mod did you make a whole new stabs or did you just fit the two piece ones together? lol im sorry for all the questions but, im kinda nervous with this plane as its my first real ducted fan jet, i have had a few foamy ones most notably the f-18 from bananna hobby which i upgraded the fan, motor and, lipo so its pretty quick. I have been flying mostly gas planes with the ocassional park zone model so when it comes time to setup the electirics im gunna be picking quite a few brains lol.
thanks
John
Hide Signatures
       Post #: 119
RE: HET F-18 Twin 70mm EDF - 11/10/2009 2:26 AM
JR16
Score: 100
Status: offline
opps just ignore this post, sorry
Hide Signatures
(in reply to JR16)
       Post #: 120
RE: HET F-18 Twin 70mm EDF - 11/13/2009 12:05 AM
rctech2k7
Score: 100
Status: offline
Hi! John
I just took some photos of my modifications and here’s what I got. The plane doesn’t look good but for reference hope it will help. I couldn’t get a chance to repaint the plane since from the last time she looses the nose gear screw and went to the grass on takeoff attempt. It leaves a visible crack on the nose.
I’m using Robart 520W1 Tri Gear 90 Deg Rail Mount retract. I made a new pair of stabilizer from piece of plywood but I suggest if you haven’t install it and planning to make full stab better to glue the original one together using epoxy as full stabilizer because plywood is too heavy. Also, check your throw and put stopper on servo. Fly her first with the original landing gear setup since it’s easier to install. How’s the setup of your jet right now? Let me know if you have any question.
Regards,
John
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to JR16)
       Post #: 121
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.656RCU1
