RE: COMP ARF 110    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: COMP ARF 110
Page: <<   < prev  44 45 46 47 48 49 50 51 52 [53]
Login
RE: COMP ARF 110 - 11/17/2012 11:34 AM
samparfitt
Score: 125
Last Login: 5/23/2013
Status: offline
Manfred,
The pull-pull would definitely solve the lateral movement problem while in the UP position.
_____________________________
G. Samuel Parfitt
Hide Signatures
(in reply to MANFRED)
       Post #: 1301
RE: COMP ARF 110 - 11/17/2012 12:08 PM
ram3500-RCU
Score: 145
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: MANFRED
Ahh Ok, I wonder if using the pull pull system would slack the lines enough when retracted to not allow any movement of the wheel.
It does. I put the servo up under the cockpit not where the factory has it behind the cockpit. This way it is easily accessed. It is virtually impossible to service otherwise. No issues with control or the gear doors and it saves some nose weight as I always use a heavy metal gear servo for the tail wheel.
Cheers,
Gary P. / use Steel Powder for ballast not lead. PM me for more information.
Hide Signatures
       Post #: 1302
RE: COMP ARF 110 - 11/17/2012 6:32 PM
bentwings
Score: 100
Status: offline
I used a pull-pull system on my Z Corsair. Much smaller airplane but still 36 pounds.
I made a pulley out of a series of servor wheels. The cable wrapped around this then to the tail wheel assembly. The pulley system was mounted on a set of rails that allowed me to adjust it to take up the slack in the cables beyond the link adjusters. I drove the pulley with a solid link to a servo. This system allowed tight cables when the TW was down and slack when retracted. It also kept the load off the servo as it only drove a push pull solid link. There is no loosining of the cables as the pulley turns.
I've used this system on all of my big warbirds (tail draggers) and it works quite well. I even use it on pull pull rudder and elevator as there is no differential due to the arm position and it reduces the servo side loads.
I don't have a good picture. Maybe I can model something on Solid Works.
bentwings
Hide Signatures
(in reply to ram3500-RCU)
       Post #: 1303
RE: COMP ARF 110 - 12/8/2012 3:34 PM
MRadu
Score: 100
Status: offline
Gary,
I'd like to add your gun lights to my Corsair. Would you send me a set for a price or a list of parts and links to buy what I need?
RC Models are never finished, you simply stop working on them.
The strength is knowing when.
Hide Signatures
(in reply to bentwings)
       Post #: 1304
RE: COMP ARF 110 - 12/30/2012 11:02 PM
DDayWarbird
Score: 100
Last Login: 1/1/2013
Status: offline
Elevator / Horizontal Stabilizer
Hello, I got my green Corsair off the shelf after 1 ½ years, to start working on her. Started with the elevator.
Question. How do you mount the carbon fiber rod into the hole of the elevator.
The rod easily fits in, and could be glued, or screws could be used from the underside. Which is correct and the right thing to do ???
The glue would be permanent and you would not be about to get the hinge rod out if there were a need to do so. Or did you builders use screws. The instructions just are not that clear. I reviewed Sam’s thread but he used a carbon fiber tube. Thus I am at a loss. Thanks Dr. Bill
If you elaborate a whole lot with specific instructions I would appreciate it. And pictures.
Here are some pictures so that you will identify what I am speaking of.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by DDayWarbird -- 12/31/2012 1:27 AM >
Hide Signatures
(in reply to MRadu)
       Post #: 1305
RE: COMP ARF 110 - 12/31/2012 1:38 AM
samparfitt
Score: 125
Status: offline
Dday,
Check post # 289 for detailed instructions.
Basically, I had to solder a brass loop on the removable brass tubing to be able to remove it and allow the elevators to be removed. This is also why I had to use new hollow CF tubing so the brass loop would fit inside the CF tubing: a screw was used to secure the CF to the elevator.
An easier option would be to drill a hole on the outside of the stab to insert the brass rod to hold the elevator to the stab. You could then use the kit enclosed solid CF rod on the opposite end of the elevator.
G. Samuel Parfitt
Hide Signatures
(in reply to DDayWarbird)
       Post #: 1306
RE: COMP ARF 110 - 4/26/2013 1:39 PM
tp777fo
Score: 103
Status: offline
Tom Perry
In Dog beers, I only had one!
Hide Signatures
(in reply to samparfitt)
       Post #: 1307
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
