COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 3:47 AM
samparfitt
Score: 125
Last Login: 5/23/2013
Status: offline
Arrival:
I'm starting an assembly thread on the new F4U Corsair that came today.
I'm not sure when I'll get started since I'm presently assembling Robart's 92" P-47.
Each morning, I just look at something and think that I'll work on 'that' today so 'who knows' what I'll be working on, tomorrow!.
pic 1-4:
The two very large boxes came from Fedex.
I couldn't wait for the deliver man to bring both in so I went out to help!
The boxes say to inspect the boxes and not take them if damaged.
They had a few holes so he was kind enough to help my open them and make sure all was OK: which it was.
First box:
pic 5/6:
Always a treat pulling the top of the box off!
The fuse, cowl, manual, folding wing mechanism, two bags of hardware, canopy/frame and a few other objects.
pic 7:
Tail wheel doors.
pic 8-10:
Inside the fuse.
pic 11-12:
cowl and LE wing vents.
(lots more pictures coming)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
G. Samuel Parfitt
Hide Signatures
       Post #: 1
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 4:04 AM
samparfitt
Score: 125
Status: offline
Box 1 (cont)
pic 1/2:
The folding wing mechanism, two CF sleeves for outer wing folding mechanism and two silver objects which I presently don't know what they are for!
pic 3:
Canopy frame.
pic 4/5/6:
fuse detail.
pic 7:
Two hardware bags and the manual.
First bag:
pic 8:
Hinges and hardware.
pic 9:
formers, etc.
pic 10:
four hardware bags separated by areas.
Second bag:
pic 11:
wood components plus the two small, silver FG parts that cover where the wing folds (as per the prototype...cool).
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
G. Samuel Parfitt
Hide Signatures
(in reply to samparfitt)
       Post #: 2
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 4:21 AM
samparfitt
Score: 125
Status: offline
second box.
pic 1/2:
first open.
pic 3:
Outer wings are about 36" long.
pic 4:
Gear doors will have to be cut out.
pic 5-8:
Center wing.
The CF sleeve for the folding wing appears to also serve for the fixed wing since it has a cylinder hole in it.
pic 9:
Vertical stab/rudder.
pic 10:
Horizontal stab/elevators.
The areas of the CF composites that are suppose to be cloth have the texture of cloth and indent as cloth wood: cool.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
G. Samuel Parfitt
Hide Signatures
       Post #: 3
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 4:31 AM
t_burley
Score: 117
Last Login: 5/24/2013
Status: offline
very nice stuff Sam!
Todd
Meister, Aero Acc., Sierra, Glennis, Get Stencils, Shinden, Warbird Colors, Fliteskin, VicRC, Holman, Bates custom
Hide Signatures
       Post #: 4
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 4:50 AM
samparfitt
Score: 125
Status: offline
stuff:
pic 1:
On Monday, I went to home depot and got my paint.
I'm going with the Marine's three color scheme.
The premium Behr exterior is no longer in quart cans so I bought a gallon and put it into four quart cans so it won't dry out when I have half of it left in the can (this plane will probably use two quarts, anyway!).
pic 2/3/4:
Looks like the only cockpit option is with D-balsa 1/4 scale Don Smith kit:
The Smith kit is 1/4 scale versus comparf's 1/4.5 but that should be close enough!
http://www.dbalsa.com/
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by samparfitt -- 10/30/2008 4:53 AM >
G. Samuel Parfitt
Hide Signatures
       Post #: 5
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 4:56 AM
samparfitt
Score: 125
Status: offline
Here's my TF 86" version color scheme that I'll be using.
(she has gear doors but not on in this picture)
As with the Robart 92" P-47, I plan on making functional cowl flaps and sliding canopy.
Click for fullsize
Click for fullsize
< Message edited by samparfitt -- 10/30/2008 5:09 AM >
G. Samuel Parfitt
Hide Signatures
       Post #: 6
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 6:23 AM
samparfitt
Score: 125
Status: offline
more stuff.
pic 1:
The outer wings have plenty of CF lining the inside.
pic 2:
The ailerons are pre-slotted and there are holes in the inside formers and at the end of the aileron in which it appears that a provided rod is inserted to insure the hinges do not come out.
pic 3:
Looking through the LE of the center wing air vent, you can see the CF main spar: that should be plenty strong for the main gear!
pic 4:
about 1/2" thick high grade ply going into the rib for the gear mounts.
pic 5:
CF pins for the center wing front mounting pins.
pic 6:
An excellent, smooth finish.
I haven't found any imperfections, so far.
pic 7:
Looks like the same procedure on the elevators as on the ailerons for hinges.
pic 8:
Though the fuse has no formers behind the cockpit, the sides are very rigid and do no flex when pushed on.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by samparfitt -- 10/30/2008 6:25 AM >
G. Samuel Parfitt
Hide Signatures
       Post #: 7
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 8:02 AM
Spectre1
Score: 100
Last Login: 12/2/2012
Status: offline
Subscribed! COMP ARF puts out some really nice stuff, Im still flying my 2.6 extra 330. This ones going to be a jewel.
Hide Signatures
       Post #: 8
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 8:37 AM
77chickenhawk
Score: 105
Status: offline
hello you lucky guy you!!!!......
I was wondering when you ordered this plane. Interested in the time it took for it you arrive? Also are you putting a radial in it?????
What do you think about no formers in the fuse?
Boy you have shelled out the big bucks between these two models wow I envy you ....lol....
The two most wanted planes. unfortunatly no one makes a true 1/5 scale model of both planes.. If someone did I would be working to that direction.. and they would both have the 150 radial in them lol..
< Message edited by 77chickenhawk -- 10/30/2008 8:38 AM >
Just Make It Look Real !!!
Hide Signatures
       Post #: 9
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 1:46 PM
samparfitt
Score: 125
Status: offline
I ordered it at Joe Noll flyin in May.
I saw it fly at Joe Noll so no formers in the fuse must be OK!.
(see below for outer wing).
My house mortgage is paid off, no bills and I don't like to take vacations or eat out: that leaves $$$ for my hobbies!
(I do like to fly though, since I go through 25 gallons a year!)
I'm interested in a gas radial and the solo prop: Please email me if anyone has experience with these at samparfitt@fuse.net.
more stuff:
pic 1:
Interesting: the outer wing is like the fuse, only one rib but a very thick (about 1/2" thick) spar.
Like the fuse, there is no give on the surface when pressure is applied.
Like a crustacean, the exoskeleton is very strong.
This will make it easy to put nav lights on the wing tips!
No plastic covers for nav lights so I'll have to make my own.
pic 2/3:
Nice tight fit between fuse and center wing.
pic 4:
Those gear doors should last: they are made out of CF.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by samparfitt -- 10/30/2008 1:56 PM >
G. Samuel Parfitt
Hide Signatures
(in reply to 77chickenhawk)
       Post #: 10
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 4:25 PM
onewing
Score: 100
Last Login: 3/27/2013
Status: offline
Very nice. Subscribed.
I ordered mine at the end of September. Just heard from my Comp-ARF rep that it shoud arrive in December, earlier than his original estimate. Mine is a plug-in wing.
When do you expect to receive your retracts?
Good luck with the build. I can not wait to have my hands on mine.
Onewing
Hide Signatures
       Post #: 11
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 5:59 PM
77chickenhawk
Score: 105
Status: offline
I have a solo prop on my p-40
Hide Signatures
       Post #: 12
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 7:03 PM
samparfitt
Score: 125
Status: offline
Organization:
Nothing gets glued until I read through the whole manual (probably several times) and sort all hardware to their respective parts.
I don't claim to be an expert on this assembly so point out any errors.
Folding wing:
pic 1:
Folding wing parts.
pic 2:
Twelve M6 bolts and locking nuts to hold one side of the folding mechanism to the inner wing.
pic 3:
Four M5 bolts that will be drilled/tapped into the CF sleeve and into the outer side of the folding wing mechanism in the outer wing.
Two go into each wing and go perpendicular to the top of the folding wing mechanism.
pic 4:
Sixteen M4 bolts and blind nuts and rib supports to hold the TE of outer wing to the inner wing (front rotation pivot points).
pic 5:
Hardware came out of the ARF bag.
Those two bolts and blind nuts must be the pivot point bolts where the two tapered ends of the aluminum hinge are connected.
(These bolts don't fit the ID of the holes so new ones will be ordered)
Flaps:
pic 6:
Flaps, hinges and hardware.
Hinges look like circuit board material and all hinges were in one large bag.
pic 7:
24 'L' shape hinges
6 straight shape hinges.
2 large pieces of material (sliding plates) to move the inner flap.
8 M2 short bolts and locking nuts
2 M2 long bolts and locking nuts.
The straight hinge is bracketed by two of the 'L' hinges and a short M2 bolt is the pivot point.
Where the outer flap moves the inner flap with the large flat piece of material (sliding plates), the hinges on both flaps are connected at the pivot point with a long M2 bolt (I guess this keeps the two flaps properly aligned so the one flap can move the other flap).
Two servos are needed for each side: one in the inner wing and one in the outer wing in pre-cut servo mounts in the ribs.
pic 8:
The hardware came out of the 'wing' bag.
outer wing
pic 9:
outer wing parts for TE wing alignment.
pic 10/11:
Six aileron hinges go into pre-cut slots.
I think this plastic tube is used to align the hinges while the epoxy is drying.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by samparfitt -- 10/30/2008 8:46 PM >
G. Samuel Parfitt
Hide Signatures
       Post #: 13
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 7:27 PM
vasek
Score: 147
Status: offline
Great looking plane!
Subscribing... please lots of pics for the flaps hinging/ operation
Thanx
Remember: Speed is life!
Hide Signatures
       Post #: 14
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 9:08 PM
andywakem
Score: 100
Last Login: 9/15/2012
Status: offline
WOW!!!
Sam That is one fine piece. I think you should bite the bullet and go for the radial. What a nice kit. and well packaged, too.
Andy
Hide Signatures
       Post #: 15
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 10:23 PM
NCIS
Score: 130
Last Login: 6/29/2011
Status: offline
I'm building a Don Smith 1/4 scale 121.5" wingspan F4U-1D Corsair that I am turning into a F4U-7 French Navy Korean War Era Warbird. I have Brian's cockpit and you shouldn't have any problem getting it to fit in your bird. I ended up with a ton of waste anyway. He did an excellant job on making the parts. If I ever get to the point of putting it in I'll post some pictures. He didn't make it until I asked him if he could so he did and after a couple months or more sent me a prototype for free so I could check it out. We talked about it and he made some changes. Then he perfected it and I bought the whole kit. How much did your plane cost?
Gibbs
< Message edited by NCIS -- 10/30/2008 10:24 PM >
Barry - Owner of Canopy Rails For Warbirds
Hide Signatures
(in reply to andywakem)
       Post #: 16
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 11:16 PM
samparfitt
Score: 125
Status: offline
Gibbs,
Prices are available at their web site:
http://www.composite-arf.com.hk/ar/Catalog?cat=44
I got the 792000 version.
Please list the web site for obtaining the cockpit kit.
Organization (cont)
More details will follow when I actually start working on this bird.
Presently, I'm just trying to know where all the parts go and become thoroughly familiar with all instructions and catalogue all parts before doing any actual work.
pic 1:
Correction:
The pivot bolts for the TE rotation should use 8M bolts and locking nuts.
pic 2:
Four (break each in half) aileron/flap control horns (two for ailerons and two for flaps).
pic 3:
Aileron/flap hardware provided in the kit.
pic 4/5/6:
Control horns for the three flaps.
Left (flap next to fuse) flap (inside corner) gets 4/10 drill rod or if not ply inside, then cut open, glue ply and put bolt/blind nut in.
A ball socket is attached to the rod which where the ball socket connects to the flap servo.
The right flap (flap next to aileron) gets one of those control horns mentioned in pic 3.
pic 7:
Receiver tray.
The top center of the center wing will be cut out later for installation of the ply tray.
pic 8:
Outer wing correction:
The short bolts on the right should be used to hold the outer wing to the CF sleeve and outer part of the folding wing mechanism.
The longer bolts would probably go into the hydralic cylinder.
pic 9:
Tail wheel doors also CF.
Also, the entire inside of the fuse looks like it has a beige mylar lining.
pic 10/11:
Tail wheel ply parts.
Dry fitted.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by samparfitt -- 10/30/2008 11:33 PM >
G. Samuel Parfitt
Hide Signatures
(in reply to NCIS)
       Post #: 17
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/30/2008 11:21 PM
samparfitt
Score: 125
Status: offline
organization (cont)
pic 1:
Elevator servo tray.
pic 2:
Main gear/tail wheel door hinges, rods and plastic tubing.
pic 3:
Fire wall mount ply.
pic 4:
Folding wing CF thread/fiberglass for re-inforcing outer wing folding wing mechanism sleeve.
pic 5:
Outer wing, inner rib covers that will be trimmed down.
pic 6:
Most of the 'stuff' all labeled and packaged by group.
I had my daughter save me all those clear bags with zippers that come with new curtains when she decorated her new (1919) house:
Nice for storing 'stuff'.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by samparfitt -- 10/30/2008 11:26 PM >
G. Samuel Parfitt
Hide Signatures
       Post #: 18
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/31/2008 1:28 AM
samparfitt
Score: 125
Status: offline
one thing that is obviously missing is the pump, bladder and tubing/connections for the folding wing!
I emailed my US rep yesterday and awaiting on when he will reply and send the rest of the parts.
Click for fullsize
G. Samuel Parfitt
Hide Signatures
       Post #: 19
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/31/2008 2:41 AM
didiwatt
Score: 100
Status: offline
Hmmmm where you looking for these?????????? Now I know why they were so expensive. Darrell outdid himself.
Didi
Click for fullsize
Light travels faster than sound. This is why some people appear bright until you hear them speak!!!
Hide Signatures
       Post #: 20
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/31/2008 4:57 AM
CamoCrazy
Score: 100
Last Login: 1/30/2013
Status: offline
That is sick man!!!! Where did you get it from?
Jerry
Hide Signatures
(in reply to didiwatt)
       Post #: 21
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/31/2008 7:54 AM
Flakbait
Score: 105
Status: offline
Subscribed,
Sam, You sir, are a wildman!!!!
Looks like an adventure, I'm sure Comp Arf will do right by you regarding your AWOL parts.
Hide Signatures
(in reply to CamoCrazy)
       Post #: 22
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/31/2008 3:38 PM
samparfitt
Score: 125
Status: offline
Full size F4U videos:
A nice video of a Corsair landing.
Professionally done with outside views as well as inside views of pilot and cockpit while the pilot describes his landing procedure.
http://www.youtube.com/user/big4jimmy
pre-flight and take off:
http://www.youtube.com/watch?v=rwrdhpGFsVg
start up with wings folded and take off:
http://www.youtube.com/watch?v=FQxb-V-rZqA&feature=related
< Message edited by samparfitt -- 10/31/2008 4:21 PM >
G. Samuel Parfitt
Hide Signatures
(in reply to Flakbait)
       Post #: 23
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 10/31/2008 10:01 PM
NCIS
Score: 130
Status: offline
Sam,
Here is the kit. I haven't removed it from the bag yet because I don't want to lose any small parts like knobs, etc. The seat frame it made out of brass tubing for strength. I hope you can make it out in the pick. There are also large parts in the box for the walls and the rear bulkhead. There is about 10 pages of instrutions to give you an idea of how complicated and scale looking it is. Here are some pictures. Plus if your not going to use a radial engine, this engine from William's Brothers is a WASP dummy engine kit and it looks pretty good to me. I'm putting it in front of my 3W 200cc twin.
Barry
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by NCIS -- 10/31/2008 10:06 PM >
Hide Signatures
       Post #: 24
RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY - 11/1/2008 4:40 PM
Ken-h
Score: 100
Last Login: 4/29/2013
Status: offline
Sam,
Looks pretty darn nice. I had one coming as well but I guess it will be a few more weeks before I see it. I am using a Moki radial for power with the Solo prop and hub. I also plan doing the sliding canopy as well, so I am looking forward to seeing how you accomplish it on yours. Anyway, good luck with it.
Ken
Powered by Desert Aircraft!
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.517RCU1
