RE: COMP ARF 110    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: COMP ARF 110
Page: <<   < prev  35 36 [37] 38 39 40 41 42 43 44   next >   >>
Login
RE: COMP ARF 110 - 9/30/2010 5:45 AM
luckyb001
Score: 100
Last Login: 5/11/2013
Status: offline
What size spinner are you guys using. Mike
_____________________________
"No hanger Queens"
Hide Signatures
(in reply to JeffH)
       Post #: 901
RE: COMP ARF 110 - 10/29/2010 12:44 AM
snobird
Score: 100
Last Login: 5/19/2013
Status: offline
Hi Samparfitt, were do you get those nite little servo connectors, the little plastic colored ones
Hide Signatures
(in reply to samparfitt)
       Post #: 902
RE: COMP ARF 110 - 10/29/2010 2:34 AM
samparfitt
Score: 125
Status: offline
Got my spinner from soloprop.
Sullivan aluminum connectors:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYCH4&P=7
< Message edited by samparfitt -- 11/16/2010 3:37 AM >
G. Samuel Parfitt
Hide Signatures
(in reply to snobird)
       Post #: 903
RE: COMP ARF 110 - 10/29/2010 4:51 PM
didiwatt
Score: 100
Last Login: 5/18/2013
Status: offline
luckyb001
Vogelsang has a one piece aluminum hub for the Moki and Tru-turn makes a two piece. The problem with these in conjunction with a wood prop is that it is very difficult to tighten them evenly so as not to wobble. Seems the wood always compresses easier on one side than the other. They work better on a composite.
Paul
Light travels faster than sound. This is why some people appear bright until you hear them speak!!!
Hide Signatures
       Post #: 904
RE: COMP ARF 110 - 10/29/2010 4:57 PM
snobird
Score: 100
Status: offline
Hi Samparfitt, what I was looking at was the plastic connectors that you used to connect the servo leads, servo to an extension lead
ive attached some pic.s of my Corsair transport cradle.. I bolt the cradle to the trailer floor, with the corsair ready to go, roll in onto the cradle with the tail held high. when I lower the tail the corsair will set on the cradle with the wheels off the floor, strap it down and away you go..
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 905
RE: COMP ARF 110 - 10/29/2010 5:24 PM
samparfitt
Score: 125
Status: offline
post some pictures of how you secure the fuse.
safety clips:
towers:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXWK7&P=7
the ones I have, they are from e-power that I picked up at one of the flyins that I went to:
http://www.rcmicroflite.com/Universal-Servo-Safety-Clips-Set-of-10-_p_113.html
G. Samuel Parfitt
Hide Signatures
       Post #: 906
RE: COMP ARF 110 - 10/30/2010 4:50 PM
snobird
Score: 100
Status: offline
What I do is put a towel over the plane and strap it down just behind the cowl down to the legs on the cradel. on the aft behind the canopy strap it down to the cradle legs again.. works very well
Hide Signatures
       Post #: 907
RE: COMP ARF 110 - 11/4/2010 4:27 AM
Illusion258
Score: 100
Last Login: 2/19/2011
Status: offline
Any one have on of these they want to trade a jet for !?
Hide Signatures
(in reply to luckyb001)
       Post #: 908
RE: COMP ARF 110 - 11/5/2010 3:47 PM
snobird
Score: 100
Status: offline
pm me what jets do you have to trade ?
Hide Signatures
(in reply to Illusion258)
       Post #: 909
RE: COMP ARF 110 - 11/16/2010 1:54 AM
JPate147
Score: 116
Status: online
To all:
I flew my Comp-ARF Corsair for the third time yesterday (and still have not exceeded 1/2 throttle) and again, experienced flutter on the ailerons. I initially used Hitec 5645's on the ailerons, but after the second flight I replaced them with JR 8711's. I had hoped this would solve the problem but it did not.
Power is a Moki 250 on a 3 bladed 28 X 18.
Is anyone else having this problem? The first two flights the ailerons were fluttering, but the third flight (with the new servos) I saw the entire right wing flutter. I immediately reduced power and landed without problem, but I don't know how to fix it.
My kit was the ARF model (no folding wing) so the controls and hinges were factory installed. The plane flies beautifully, no problems whatsoever, and only took 2 clicks of down trim.
If anyone has any experience with this problem, I would love to hear how you fixed it. The only thing left that I know to do is to cut hatches in the wing bottom, move the servos and add control horns to the bottom of the ailerons. I would rather not do this (for cosmetic reasons), but I am at the bottom of the idea barrel.
Thanks in advance,
Jerry
Click for fullsize
Hide Signatures
       Post #: 910
RE: COMP ARF 110 - 11/16/2010 2:17 AM
uncljoe
Score: 160
Status: offline
From what I understand Brian O'Meara had the wing flutter and lost the aircraft . Is your a folding wing version ? I am constructing one ,and am on the middle of either replacing the "All thread or installing hollow CF tubes or brass & epoxy over the All thread.
Semper Fi
Joe
Look towards the Horizon......your death awaits you there
Hide Signatures
(in reply to JPate147)
       Post #: 911
RE: COMP ARF 110 - 11/16/2010 2:54 AM
Thunderbolt47
Score: 111
Status: online
post a pic of your servo linkage setup.
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
(in reply to uncljoe)
       Post #: 912
RE: COMP ARF 110 - 11/16/2010 3:59 AM
tp777fo
Score: 103
Status: offline
good idea...sounds like a geometry problem
Tom Perry
In Dog beers, I only had one!
Hide Signatures
(in reply to Thunderbolt47)
       Post #: 913
RE: COMP ARF 110 - 11/16/2010 5:13 AM
rcwarbirdbuilder
Score: 110
Status: offline
That could be a problem on a expensive airplane, I had been on Vogelsang site looking at the Corsair and maybe a 250 radial to go with it, I am going to keep a eye the this thread about the flutter before I make my mind up on this one.
Help! Call the doctor I can''''''t stop building these things.
Hide Signatures
       Post #: 914
RE: COMP ARF 110 - 11/16/2010 5:47 AM
uncljoe
Score: 160
Status: offline
quote:
ORIGINAL: rcwarbirdbuilder
Smart move.
joe
Hide Signatures
(in reply to rcwarbirdbuilder)
       Post #: 915
RE: COMP ARF 110 - 11/16/2010 5:51 AM
JPate147
Score: 116
Status: online
Uncle Joe,
I used the hard, fully threaded pushrods that come with the kit, but I used a hollow CF tube over the threaded rod, and the ball links are tight against the rod.
Hide Signatures
       Post #: 916
RE: COMP ARF 110 - 11/16/2010 6:02 AM
onewing
Score: 100
Last Login: 3/27/2013
Status: offline
On your aileron servo arm, is the pushrod connected to the hole far away from the center or close to the center? I am building this bird right now. As the "control horn" on the ailerons are very short, you should connect your push rod to the hole close to the center of the servo arm.
Hide Signatures
       Post #: 917
RE: COMP ARF 110 - 11/16/2010 6:13 AM
Thunderbolt47
Score: 111
Status: online
from the pic of the plane landing; I don't see any external control horns on the ailerons. Does that mean it has a "short" control horn? A short horn on the ailerons is bad. The servo arm should always be shorter than the surface control horn. Don't really know how you've set the servo up, but just guessing I would say that could be your problem. That's what it sounds like.
Hope this helps
Hide Signatures
(in reply to onewing)
       Post #: 918
RE: COMP ARF 110 - 11/16/2010 8:05 AM
JPate147
Score: 116
Status: online
Thanks for the ideas guys, I really appreciate it.
I have the JR metal arm on the servos, and the pushrods are connected the second hole 'out' from the servo. I can move it in one more hole and hope that does it. I am leery of flying it again without some confidence in the fix.
The aileron horn is buried in the leading edge of the aileron, and the geometry is not good. It came from the factory that way so I trusted their judgement.
Thanks again for the help,
Jerry
Hide Signatures
       Post #: 919
RE: COMP ARF 110 - 11/16/2010 3:57 PM
docgboy
Score: 100
Status: offline
I experienced the same thing and could not resolve it until I added balances to the aileron. There are some pics on here showing what I did. I can fly full throttle with no hint of flutter.
Scott
Hide Signatures
       Post #: 920
RE: COMP ARF 110 - 11/16/2010 4:46 PM
didiwatt
Score: 100
Status: offline
Jerry:
I have the exact set-up as yours. Non-folding wing. JR8611 Horizon metal arm with ball link in the 2nd hole out. I also covered the 2mm allthread with a c/f rod and used the factory location on the airleron. I have not had a hint of flutter and have a couple dozen flights so I do not know what to say.
If I were to build another one of these birds, I would install arms on the airlerons for sure.
I assume your airleron servo is installed into the rib like mine? I am trying to elimate the possibility of the wing skin flexing if your servo is mounted to the skin.
May I ask how much lead it took in the nose to balance your bird (with the gear up)?
Paul
Hide Signatures
(in reply to docgboy)
       Post #: 921
RE: COMP ARF 110 - 11/16/2010 6:04 PM
JPate147
Score: 116
Status: online
Paul,
It took 19 oz's directly behind the firewall. I built a two tiered shelf that holds 4 batteries (2ea on RX, 1ea for motor/pump, and one for nav lights) 64oz fuel tank, and all electronics that goes right behind the firewall. Everything is in front of the CG.
Hide Signatures
(in reply to didiwatt)
       Post #: 922
RE: COMP ARF 110 - 11/17/2010 3:37 AM
didiwatt
Score: 100
Status: offline
Jerry:
Sorry to repeat myself, but is your airleron servo installed in the plywood rib?
I noticed when Sam was setting up his aileron servo, his folding wing version did not have a plywood rib where our tube version does so he was forced to mount it on the wing skin. In so doing, you almost have to build a box around the servo to tighten up the wing skins so they do not flex in flight and create flutter etc. This is common to most Comp-Arf planes.
Just checking to see if this might be your problem.
Paul
Hide Signatures
       Post #: 923
RE: COMP ARF 110 - 11/17/2010 6:28 AM
luckyb001
Score: 100
Status: offline
I have decided to move the aileron servo and control arm to the outside to eliminate any chance of flutter on my Corsair. I also moved the rudder servo to the vertical fin and put a control arm on the rudder. It may not look as good as the hidden lincage but it should eliminate any flutter. Also True Turn has a 2" spinner and the hardware to mount it to the Moki available. My plane is painted and I plan to clear it tomorrow so I will put some photos up when it's done. This thread has been helpful while building and I would like to thank you guys for all the effort it took to post all those photos. mike
"No hanger Queens"
Hide Signatures
       Post #: 924
RE: COMP ARF 110 - 11/17/2010 6:40 AM
uncljoe
Score: 160
Status: offline
I also would like to thank all who have posted it been a great help in construction of the U Bird.Here are a few photo's of my U bird.
Semper fi
Joe
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 925
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
