RE: Top Flite Cessna 182 Skylane Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Top Flite Cessna 182 Skylane Build
Page: <<   < prev  1 2 3 [4]
Login
RE: Top Flite Cessna 182 Skylane Build - 2/4/2012 11:27 AM
JendaDH
Score: 100
Last Login: 5/6/2013
Status: offline
 Hi,
not wure if glassing the whole plane would be ok with weight. You might end up with larger engine, thus cutting up the cowl to accomodate one. I have one myself, just waiting for better weahter to take it for maiden flight. I also have the robart nose strut, but went with the reccomendations in the kit instructions. Engine is a glow two stroke 15ccm (guess that it is 0.91cu) and fits in the cowl just fine with incowl muffler that I bought with the engine.
Good luck with your build
J.
Hide Signatures
(in reply to FlyerInOKC)
       Post #: 76
RE: Top Flite Cessna 182 Skylane Build - 2/4/2012 6:55 PM
sweatybetty
Score: 100
Last Login: 5/19/2013
Status: offline
hey guys, maybe im missing something, but where in the directions are the instructions as to how the windshield is installed? im not seeing it
thanks, sb
Hide Signatures
(in reply to dansdeals3489)
       Post #: 77
RE: Top Flite Cessna 182 Skylane Build - 2/7/2012 1:11 AM
exsailor62
Score: 100
Last Login: 12/23/2012
Status: offline
Where did all the pictures go?  I have a TF Cessna in the box and was hoping to see some details of this construction but, pitures have been moved or deleted.
_____________________________
Sam says - When the engine quits, the flying may not be over but, the fun is gone.
Hide Signatures
(in reply to sweatybetty)
       Post #: 78
RE: Top Flite Cessna 182 Skylane Build - 2/7/2012 10:38 AM
JendaDH
Score: 100
Status: offline
Hi,
windshield installation is on page 50 where is the section how to install scale cockpit. Bullet 6.
J.
Hide Signatures
       Post #: 79
RE: Top Flite Cessna 182 Skylane Build - 2/7/2012 10:39 AM
JendaDH
Score: 100
Status: offline
Hi,
I can provide you some pictufres of the build if you wish.
J.
quote:
ORIGINAL: exsailor62
Hide Signatures
(in reply to exsailor62)
       Post #: 80
RE: Top Flite Cessna 182 Skylane Build - 2/23/2012 4:27 PM
FlyerInOKC
Score: 116
Last Login: 5/21/2013
Status: offline
Any updates?
My workbench where you always find the weird and unusual! Sig Kadet Brotherhood #89 Ryan STA/STM/SC Brotherhood # 27
Hide Signatures
(in reply to JendaDH)
       Post #: 81
RE: Top Flite Cessna 182 Skylane Build - 2/23/2012 9:10 PM
JendaDH
Score: 100
Status: offline
quote:
ORIGINAL: FlyerInOKC
Any updates?
Busy with work, but want to finish fuselage covering and take her out on first nice spring day :-)
Hide Signatures
       Post #: 82
RE: Top Flite Cessna 182 Skylane Build - 2/23/2012 10:49 PM
FlyerInOKC
Score: 116
Status: offline
quote:
ORIGINAL: JendaDH
Any updates?
We are having an unusually warm winter this year. If you had it covered you could be flying the airplane at my local field, the temperature is 20 degrees Celsius!
Hide Signatures
       Post #: 83
RE: Top Flite Cessna 182 Skylane Build - 2/23/2012 10:51 PM
FlyerInOKC
Score: 116
Status: offline
The downsize we fly in up to a 40 kph wind. I soloed with a 32 kph crosswind.
Hide Signatures
       Post #: 84
RE: Top Flite Cessna 182 Skylane Build - 1/23/2013 1:51 AM
OliverJacob
Score: 110
Last Login: 5/22/2013
Status: offline
I bought an almost finished kit, there are are few things missing and I need to figure out how to build them.
I have the manual but no plans, and I shouldn't really need to buy them, the pane is almost finished.
So what I am looking for is
1. the wing struts. I don't have them and don't know where exactly they connect on the wings. The are blocks in the fuselage. Do you just use wood       screws?
2. the windows are not installed yet, On the rear window there seems to be some frame missing. Does anybody have a detailed picture? Do you glue the wind shield in? You'd have no access to the servos then.
3. where do you install your radio on/off switch?
I plan on using a Magnum 91 FS engine. Would that have enough power for scale flying and some mild tricks?
Hide Signatures
       Post #: 85
RE: Top Flite Cessna 182 Skylane Build - 1/23/2013 4:19 AM
FlyerInOKC
Score: 116
Status: offline
quote:
ORIGINAL: OliverJacob
1. The strut connects to to the wing at a 1/2" X 1/2" X 1" basswood block located on the in-board side of the double wing ribs a the end of the ailerons. The block is centered between the leading edge and main spar. They mount with # 4 sheet metal screws.
2. The rear window runs up under the trailing edge of the wing and is glued to the top of the cabin sides and the top of the fuselage in the back. There is no more framing. The windshield is glued in place. Once the turtleback is installed over the tank there is no access to the tank or the servos.
3. The switch may be mounted in the rear edge of the tank floor. You will see two holes that can accommodate the switch.
4. I am using a Super Tigre .75 2 cycle but I believe the Magnum .91 FC will work fine.
Buy the plans they can't be that much and they will help if you ever need to make a repair. Top Flite can quote you they are very accommodating folks.
Hide Signatures
(in reply to OliverJacob)
       Post #: 86
RE: Top Flite Cessna 182 Skylane Build - 1/23/2013 6:40 PM
JendaDH
Score: 100
Status: offline
Hi, if you need some specific sections of plans, I can do a picture of that part for you.
I have the on/off switch mounted to the side of the fuselage so it is easily accesible without the need to remove the wing. I plan to make scale doors to hide the switch completly.
J.
Hide Signatures
       Post #: 87
RE: Top Flite Cessna 182 Skylane Build - 1/23/2013 9:39 PM
OliverJacob
Score: 110
Status: offline
Thanks guys,
the wing struts are the main problem, but I am on the right track now :-)
The switch location is something I need to figure out now. I thought about a little door in the cowling, with access to the needle, filler and I'd mount the switch there, too. I'd need some sort of hinges and use magnets to hold it closed. Just an idea. Scale doors in the fuselage would be great, too
Hide Signatures
       Post #: 88
RE: Top Flite Cessna 182 Skylane Build - 1/23/2013 10:31 PM
FlyerInOKC
Score: 116
Status: offline
Thanks guys,
I would have reservations about putting the switch under the cowling. The risk of heat damage would be too great. It's not worth risking a crash.
Hide Signatures
       Post #: 89
RE: Top Flite Cessna 182 Skylane Build - 1/24/2013 7:37 AM
JendaDH
Score: 100
Status: offline
Also, you want to have access to the needle all the time to be able to easily tweak the settings. Not to mention that the engine gets quite hot and vent holes are handy.
I have .91 sice two stroke (15ccm) with incowl muffler and had to cut slightly larger opening for the exhaust pipe bends. Probably not the niciest setup, but I get two so called scale exhaust pipes sticking out of the cowling :-)
Here is what it looks like withnout the cowl.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 90
RE: Top Flite Cessna 182 Skylane Build - 1/27/2013 5:28 PM
JendaDH
Score: 100
Status: offline
 Hi,
here is the picture from the plan just in case you didn't move from spot. The measurements are done by the ruler by hand, nothing precise.
Hope this helps a little. The block in the fuselage can be easily located. If you are struggling also with this, I have a picture of that block location too.
Good luck with the build,
J.
Click for fullsize
Hide Signatures
       Post #: 91
RE: Top Flite Cessna 182 Skylane Build - 1/27/2013 7:34 PM
OliverJacob
Score: 110
Status: offline
Thank you,
I did find the blocks in the wing and I was always wondering how the flaps were hinged, so thanks for the drawing.
I have been on and off building the Cessna, have 4 other planes and a helicopter to get done before the season starts...
So now I am about to install the tank and make some brackets for it to stay in place. I never mounted a tank sideways, I will find out how it works.
And I am working on the cockpit interior. I do not have the stickers for the instruments, can't find them. I was hoping to find a picture, download and print them, but haven't had any success yet.
Hide Signatures
       Post #: 92
RE: Top Flite Cessna 182 Skylane Build - 1/27/2013 8:43 PM
JendaDH
Score: 100
Status: offline
Can't help you with the decal set as mine is already in place. Good luck with your models and happy season :-)
J.
Hide Signatures
       Post #: 93
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.156RCU1
