Top Flite AT6 ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> Top Flite AT6 ARF
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Top Flite AT6 ARF - 11/10/2008 4:54 PM  1 votes
maddieone
Score: 110
Last Login: 12/21/2012
Status: offline
Hey Team,
I am considering purchasing the Top Flite AT6 ARF and I have also been researching the World Models AT6. Does anyone have any information or has been associated with the TF AT6. I kinow that this is the weenie way out but I would appreciate any info that I can get.
MADDIEONE
Hide Signatures
       Post #: 1
RE: Top Flite AT6 ARF - 11/10/2008 5:12 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
I am currently building a TF AT-6 for an RCU Magazine review. I haven't flown it yet, but it's ready to go (Just waiting on the weather)
The quality is outstanding. Although I did find two flaws - Both easily corrected.
1) The set-screws in the wheel collars did not fit. I don't know if they were the wrong size, or if the holes were not properly tapped, but I just re-tapped the holes and used some 6-32 set-screws that I had on hand.
2) There was a pretty severe angle between the throttle arm and the servo. This caused the servo arm to twist as it moved. You can solve this by either replacing the throttle pushrod with a flexible cable, or what I did was to make a servo mount that moved the servo to a more in-line position.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to maddieone)
       Post #: 2
RE: Top Flite AT6 ARF - 11/10/2008 6:10 PM
maddieone
Score: 110
Status: offline
Thanks MINNFLYER, please keep us up to date on your progress. What engine do you plan on using? If I get the TF ARF I was hoping to use an existing Super Tigre S 61 that runs really great and that would keep the project cost down.
Thanks Again,
MADDIEONE
Hide Signatures
(in reply to MinnFlyer)
       Post #: 3
RE: Top Flite AT6 ARF - 11/10/2008 6:14 PM
MinnFlyer
Score: 390
Status: offline
I am using an OS 91 Surpass II. I have heard from someone with this combo that says it's an excellent power match.
Hide Signatures
       Post #: 4
RE: Top Flite AT6 ARF - 11/10/2008 6:23 PM
maddieone
Score: 110
Status: offline
Sounds good to me.
I have a couple of planes with the 91's and the engines have always been extremely reliable and have not caused any grief.
So much for project costs.
Hide Signatures
       Post #: 5
RE: Top Flite AT6 ARF - 11/10/2008 10:26 PM
Howard
Score: 120
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: MinnFlyer
MinnFlyer,
The gear on this plane looks "unusual" and perhaps less than sturdy. Let me underscore 'looks' because I have no other information to suggest there is a problem and I don't want to start rumors based on my visual perceptions - sometimes these threads take on a life of their own. Would you be kind enough to comment and also check the wire dimensions (thickness) of the gear. I have the WM AT-6 but have not started it and just fell in love with the TF colors when they started advertising. The WM AT-6 is beautiful but might rub real scale fans. Thanks
Howard
If you want to be politically correct, try lying.
Hide Signatures
       Post #: 6
RE: Top Flite AT6 ARF - 11/10/2008 11:29 PM
jbarnes
Score: 100
Status: online
Does the TF AT6 have the hatch built into it like the P51. You just simply cut the sheeting and you have nice hatch for electric setup? I have the TF P51 on electric and it flies fantastically. Considering the AT6.
Longmont Aircraft Modelers Association
Longmont, CO visit our site at www.lamarcclub.com
Hide Signatures
(in reply to Howard)
       Post #: 7
RE: Top Flite AT6 ARF - 11/10/2008 11:43 PM
MinnFlyer
Score: 390
Status: offline
I have not measured the gear wires, but a 3/16" collar would not fit on it., my guess is 4mm, but I'll try to remember to check that tonight. It seems plenty strong though.
As for a hatch, I have not seen one, but then, I haven't been looking for one either. I reviewed the TF P-51 and never even realized that IT had one!
Hide Signatures
(in reply to jbarnes)
       Post #: 8
RE: Top Flite AT6 ARF - 11/10/2008 11:57 PM
jbarnes
Score: 100
Status: online
To see the hatch access visit this thread, http://www.rcuniverse.com/forum/m_7966717/anchors_7967084/mpage_1/key_/anchor/tm.htm#7967084
< Message edited by jbarnes -- 11/11/2008 12:26 AM >
Hide Signatures
       Post #: 9
RE: Top Flite AT6 ARF - 11/12/2008 2:30 AM
R/C Foolish
Score: 105
Last Login: 5/4/2013
Status: offline
The TF AT-6 flies great with a Saito 100. The gear are not perfect. I replaced the z bend wires for 256 rod with clevis's attached for a more solid connection. I would like to see Robart come up with a replacement gear.
R/C Foolish
Hide Signatures
       Post #: 10
RE: Top Flite AT6 ARF - 11/16/2008 5:00 AM
Free Bird
Score: 105
Status: online
A couple of weeks ago, I had an opportunity to fly the TF AT-6 ARF. It was powered with a O.S. 91. The builder of the model had excessive throws on the ailerons and elevator (he felt the instruction throws weren't enough). Once that was squared away, I flew the Texan and I must say, I was impressed with the way it flew. It was very solid and not twitchy at all. The stock retracts worked well, but they do look funkey. Landings without flaps is a no brainer as it slows nicely. It sure does look nice flying with the gear up! I just might have to get one of these birds, I'd strip it and use a different trim scheme though.
R/C Foolish
Robart used to make a set of retracts for the TF AT-6 kit. They should fit without too much effort.
FB
Hide Signatures
(in reply to R/C Foolish)
       Post #: 11
RE: Top Flite AT6 ARF - 11/23/2008 6:52 AM
bucho
Score: 100
Last Login: 4/21/2013
Status: offline
saito 100 is a good idea or better the surpasss 91 ?
Hide Signatures
(in reply to Free Bird)
       Post #: 12
RE: Top Flite AT6 ARF - 11/23/2008 7:31 AM
CCFPILOT
Score: 100
Last Login: 5/23/2013
Status: offline
The gear wire is 5mm, and soft as cheese, no spring at all. I'm wondering if anyone other than me has tried to remove the gear wire from the retracts after the set screws have been torqued down?? It's nearly impossible because the wire is so soft it gets distorted.
Flys great though, just make soft landings.
Ethan
PS. I remove the set screws before trying to remove the wire struts.
< Message edited by CCFPILOT -- 11/23/2008 6:08 PM >
Hide Signatures
       Post #: 13
RE: Top Flite AT6 ARF - 11/23/2008 8:22 PM
Iflyglow
Score: 122
Last Login: 5/19/2013
Status: offline
Has anyone tried a YS 1.10 yet. What is the tail feather construction like.
Hide Signatures
(in reply to CCFPILOT)
       Post #: 14
RE: Top Flite AT6 ARF - 11/24/2008 9:55 PM
lancedoze
Score: 100
Last Login: 2/7/2009
Status: offline
Just flew mine today. Everything looks good and functions well except the gear. This seems to be the only drawback. OS 91 II with a 14x6 k series MAS is perfect. If anyone has tried the robart gear let us know because we are going to need it.
Hide Signatures
(in reply to Iflyglow)
       Post #: 15
RE: Top Flite AT6 ARF - 11/24/2008 11:36 PM
Lifer
Score: 148
Status: offline
Can anyone tell me the diameter of the firewall. I'm considering a 20cc gas. Thanks!
Hide Signatures
(in reply to lancedoze)
       Post #: 16
RE: Top Flite AT6 ARF - 12/1/2008 5:55 PM
Augie11
Score: 110
Last Login: 2/8/2013
Status: offline
I'm sorry but I have to give you a complicated answer to a simple question. The firewall is supported virtually all the way around with hardwood spars which extend out to what I'll call a 'cowl ring'. The spars limit the firewall diameter to 5 7/8". However the cowl ring, which is approx. 3/4" forward of the firewall, further limit the usable diameter to 5 1/8". This figure is essentially the same as the inner cowling diameter.
Hope that helps.
Hide Signatures
(in reply to Lifer)
       Post #: 17
RE: Top Flite AT6 ARF - 12/4/2008 4:32 AM
Lifer
Score: 148
Status: offline
Augie,
Thanks for the reply. What I have in mind is the 20 cc gas from rcgf engines. It's difficult to tell without holding the plane and engine in hand............
Hide Signatures
(in reply to Augie11)
       Post #: 18
RE: Top Flite AT6 ARF - 12/4/2008 4:57 PM
maddieone
Score: 110
Status: offline
Lifer,
Due to the size of the AT6 I do not think that gas is the way to go. I have looked at some of the smaller gas engines and with the carbs and mufflers sticking out the way they do you are not going to have much cowling left by the time you get the engine mounted. I am also concerned by the weight of the engine and since they all have EI you have the additional weight of the batteries. Given that I do not know what a 'rcgf' engine looks like I would stay with what has proven to be a great combo for this plane, that is a nice 91 four stroke. You other guys care to comment?
Maddieone
Hide Signatures
(in reply to Lifer)
       Post #: 19
RE: Top Flite AT6 ARF - 12/4/2008 5:28 PM
Lifer
Score: 148
Status: offline
Maddieone,
I'm afaraid that you are correct. What I want to do and what is reasonable sometimes don't agree. Again, thanks for a candid opinion.
Lifer
Hide Signatures
       Post #: 20
RE: Top Flite AT6 ARF - 12/4/2008 7:15 PM
maddieone
Score: 110
Status: offline
You are quite welcome, always glad to help.
Maddieone
P.S.
To you and the rest of the guys, I have read a couple of reviews where the reviewer used a product called Epo-Grip to join the wing halves together. Well being of a curious nature I started looking around for something that was eaiser to obtain and perhaps cheaper. I found that Sig makes a product called Epoxolite that is normally used for fillets. So on a chance I bought some and did a couple of tests where I glued flat pieces of wood together and a faux D tube with joiner. After drying the flat pieces broke under duress but the glue joint held. I could not pull the joiner out of the tube. Work time is fifteen minutes but if you have done your pre fitting that would be sufficient. Also if some of the material oozes out, you just wet you finger and it rubs off. Be sure do do that prior to it setting up. The product is viscous and spreads like peanut butter so it doesn't slop all over when putting the pieces together.
Hope this helps.
Hide Signatures
(in reply to Lifer)
       Post #: 21
RE: Top Flite AT6 ARF - 12/4/2008 8:03 PM
Free Bird
Score: 105
Status: online
Hope this helps.
Epoxolite really isn't for joints like joining wing panels together. It's thick nature doesn't allow it to soak into the wood like a slow-cure epoxy. Epoxolite is for making fillets and such.
FB
Hide Signatures
       Post #: 22
RE: Top Flite AT6 ARF - 12/4/2008 9:46 PM
Clay Walters
Score: 107
Status: offline
Looks a little big: http://www.zrcgf.com/store/Details.cfm?ProdID=26&category=0
If it ain''''t yours; don''''t touch it!
Hide Signatures
       Post #: 23
RE: Top Flite AT6 ARF - 12/5/2008 2:57 PM
maddieone
Score: 110
Status: offline
Well, given that the material that was used by the two reviewers is of the same consistency as the Epoxolite I have to disagree. Also, the material used for the center ribs, the D tube and the joiner are normally made out of some type of plywood and or hardwoods which do not lend themselves to soaking. One should score the surfaces prior to using any type of epoxy to help ensure a good bond. It comes down to user preference and both types of adhesives will work.
Maddieone
Hide Signatures
       Post #: 24
RE: Top Flite AT6 ARF - 12/5/2008 7:46 PM
Balsawings
Score: 100
Status: offline
Epo-grip is the brand name. They have many different viscositys of epoxy. You have your normal 5 minute and 25 minute but also pre-mixed with silica or milled fiber as well as a gell. It's good stuff, sold and manufactured by a friend right here in Miami.
I also would not recommend using any brand epoxy product with a thickening agent to join wings because of the lack of penetration.
Bob Cox
SPA 374
Miami, FL
No one will remember that beautiful aerobatic sequence you just flew if you blow the landing.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
