RE: Official XXX-NT Thread!!!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
XXX-NT Sport RTR
  • 4 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: Official XXX-NT Thread!!!
    Page: <<   < prev  66 67 [68] 69 70 71 72 73 74 75   next >   >>
    Login
    RE: Official XXX-NT Th... - 10/16/2007 9:40:24 AM
    theking300
    Status: offline
    i ment to say that you may have to cut the shaft a little or try shimming ...
    (in reply to theking300)
           Post #: 1676
    RE: Official XXX-NT Th... - 10/16/2007 2:17:01 PM
    av8torjim
    Status: offline
    quote:
    ORIGINAL: theking300
    DON'T cut the shaft. Shim it. Your LHS should have shims that fit the shaft. There was a recent article in RC Driver or RC Car Action that showed how to do it. It's not hard.
           Post #: 1677
    RE: Official XXX-NT Th... - 10/16/2007 3:15:48 PM
    Dawman
    Status: offline
    If you never have cut a crankshaft befor , don`t do it . For 1mm , just shim it and will be good .
    _____________________________
    Watch out for John Carey , Johnny Carey is his username on RC Tech . He is a deadbeat scammer .
    (in reply to av8torjim)
           Post #: 1678
    RE: Official XXX-NT Th... - 10/16/2007 7:12:52 PM
    losixxx-nt
    Status: offline
    quote:
    ORIGINAL: av8torjim
    i second that. just shim it
    xxx-nt, fr15 and mip stinger exaust,- nxt picco .12
    nitro 4-tec 2.5 soon to have 05 fantom .18 ,-traxxas 4-tec
           Post #: 1679
    RE: Official XXX-NT Th... - 10/16/2007 11:49:08 PM
    BobRooney
    Status: offline
    I'm attempting to put my diff together and I forgot to get the clear diff grease but I do have the associated black grease...is this going to be a problem cause the LHS isn't very close?
    (in reply to losixxx-nt)
           Post #: 1680
    RE: Official XXX-NT Th... - 10/17/2007 12:08:49 AM
    HIGHBANKSRC
    Status: offline
    Thanks a bunch everyone! I will try the shim and let you know how it went.
    BTW - There is a shim in front of the engine bearing. It was the first thing that went on and that is how the AD2 manual instructions show how to do it.
    This brings up another question - Since there is already a shim infront of the engine bearing do I replace it with a bigger shim? OR do I leave the 1st shim and get another next to it? OR do I add a second shim in front of the clutch spacer?
    Thanks!
    Steve
    HighbanksRC
    (in reply to BobRooney)
           Post #: 1681
    RE: Official XXX-NT Th... - 10/17/2007 12:16:17 AM
    Dawman
    Status: offline
    It will be fine . Whenever I don`t have any I use whatever I have sitting around .
           Post #: 1682
    RE: Official XXX-NT Th... - 10/17/2007 1:36:55 AM
    losixxx-nt
    Status: offline
    edit :woops double post
    < Message edited by losixxx-nt -- 10/17/2007 1:38:23 AM >
           Post #: 1683
    RE: Official XXX-NT Th... - 10/17/2007 1:37:57 AM
    losixxx-nt
    Status: offline
    quote:
    ORIGINAL: BobRooney
    thats fine
           Post #: 1684
    RE: Official XXX-NT Th... - 10/19/2007 1:29:10 AM
    skate
    Status: offline
    do any one make a aluminum clutch for the xxx nt?
           Post #: 1685
    RE: Official XXX-NT T... - 10/19/2007 4:26:42 AM
    Dawman
    Status: offline
    Not sure , but I never looked for one either .
    (in reply to skate)
           Post #: 1686
    RE: Official XXX-NT T... - 10/20/2007 7:12:51 AM
    HIGHBANKSRC
    Status: offline
    Hello again!
    OK here is the update to my clutch spacer problem.
    To refresh - my issue was that I got a new engine and was in process of putting on a new clutch assembly. Everything went on great except that there was about a 1mm space between the clutch spacer and the snap ring. The advice I got was to use what I had laying around, so I did. I had an extra glow plug shim and that fits perfect for this situation. The glow plug shim from a McCoy 59 fits right in between the spacer and the snap ring, and is the correct size to fit on the clutch nut. I would guess that most glow plugs of this size with a shim would work.
    So unless I hear back that this is not a good thing I will consider this a usefull tip.
    Thanks everyone for the help! Steve
    Steve
    HighbanksRC
    (in reply to Dawman)
           Post #: 1687
    RE: Official XXX-NT T... - 10/20/2007 1:44:04 PM
    Dawman
    Status: offline
    That should be fine .
    (in reply to HIGHBANKSRC)
           Post #: 1688
    RE: Official XXX-NT Th... - 10/21/2007 5:11:28 AM
    All The Way
    Status: offline
    quote:
    ORIGINAL: skate
    Yes but I dont rember who. The problem with aluminum is it wears into the spring starts to hang up and destroys the clutch bell.
    If you want a good clutch setup use the MIP shoes with the losi spring, a lot better than stock shoes and they last a long time
    RC Pro Series Northeast 94m
    Sponsors: Eclipse RC, Glenwood RC
    (in reply to skate)
           Post #: 1689
    RE: Official XXX-NT T... - 10/21/2007 10:47:54 PM
    1nitrohead
    Status: offline
    Steve what I use is the center race from old axle bearings takes 2. Fits perfect and doesnt wear like stock alum. junk. If this is done no shim needed.
    (in reply to All The Way)
           Post #: 1690
    RE: Official XXX-NT T... - 10/23/2007 6:33:27 PM
