Dawman
Joined: 9/19/2004 From: Marseilles, IL, USA Status: offline
quote:
ORIGINAL: ThunderbirdJunkie quote:
ORIGINAL: Dawman quote:
ORIGINAL: oreo123 but does the os 8 glow plug work with the with the mach.15 chris? It will work , just not as good as a plug designed for small blocks . the OS #8 IS designed for small blocks. It's designed for OS small blocks. you should use a LONG plug (McCoy, Fox, etc) in a non-OS engine. *EDIT* Sorry, Dawman, I only saw this post, not the one before it saying what I said Listen to Dawman. no problem , but the #8 was designed for O.S. engines for 1/8 but will work in O.S. small blocks .
_____________________________
Caster Team Member `09 AB Mechanical - for all your heating and A/C needs
