RE: U-Can-Do 3d 46?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ParkZone F-27Q Stryker - RTF
Seller:  nrthwing
Details:   $150.00   |  6/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> RE: U-Can-Do 3d 46?
Page: <<   < prev  239 240 [241] 242 243 244 245 246 247 248   next >   >>
Login
RE: U-Can-Do 3d 46? - 6/1/2007 9:03 PM
choopi
Score: 100
Last Login: 10/18/2012
Status: offline
Post #6001! That's a lot!
Keep it going!
I will need a new U can do, that plane is just too much fun. After flying that plane for 10 months, yesterday I made a mistake to close to the ground, instead of pulling inverted I try to loop back up! Didn't work too good! But fortunately Traci was to get that on video.
If you want, you can enjoy the clip on youtube!
http://www.youtube.com/watch?v=uXS1lLKgK_U
Right now I 'm about done a H9 Extra 260, but I'm planning a new U Can DO, Tower have always good deal!
Enjoy
Eric
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by choopi -- 6/1/2007 9:07 PM >
Hide Signatures
(in reply to Barry Cazier)
       Post #: 6001
RE: U-Can-Do 3d 46? - 6/2/2007 1:20 AM
conradj87
Score: 100
Last Login: 6/6/2013
Status: offline
Hey guys. I just recently returned from training for the national guard. I hadn't flown in about 6 months. So basically I am re-teaching myself how to fly. The only plane i still have is a mini funtana. I have been flying it almost every night for a couple weeks and it is still a blast to fly. I have a .46 AX and a bunch of radio gear. Do you think a U can do would be a decent plane choice? I am still getting used to it, but i have flown the mini funtana a bunch of times with no major accidents. Thanks for any help.
Hide Signatures
(in reply to choopi)
       Post #: 6002
RE: U-Can-Do 3d 46? - 6/2/2007 7:09 AM
rtn9105
Score: 100
Last Login: 5/20/2013
Status: offline
Choopi, sorry to see your UCD in that shape
Jomamma, the UCD is one of the planes that I will always have. I don't fly it every time I go to the field but I would miss it allot if I didn't have one.
< Message edited by rtn9105 -- 6/2/2007 7:11 AM >
Hide Signatures
(in reply to conradj87)
       Post #: 6003
RE: U-Can-Do 3d 46? - 6/4/2007 1:33 AM
gregziemba
Score: 100
Last Login: 6/10/2013
Status: offline
do i need a easy fueler for the fuel lines like they suggested or can i just have 2 line coming from the coweling? and what about the glow plug how did you guy do it did you buy the remote? THanks for the help!
Hide Signatures
(in reply to rtn9105)
       Post #: 6004
RE: U-Can-Do 3d 46? - 6/4/2007 5:17 AM
rclement
Score: 100
Last Login: 4/3/2012
Status: offline
Hi Greg, Here's what I use for fueling. I have 2 clunks and one of them comes through the cowl to a fuel dot. I don't bother with the Dubro fuel valve since I'm not always sure that it isn't leaking air or not.
I usually don't use a remote glow conection on the plane. I just usually cut a hole in the bottom of the cowl and attach the driver that way. But with the Do I just recently built on put on this Dubro one and can say I'm sure glad I did. It attaches securely and is much easier to use than trying to reach under the cowl. Here's the one I use now....... dubro glow connector I put it on the side of the fuse above the right wing and it's very easy to install and use.
< Message edited by rclement -- 6/4/2007 5:18 AM >
_____________________________
The hardest part of this hobby?......waiting for the UPS truck.
Hide Signatures
(in reply to gregziemba)
       Post #: 6005
RE: U-Can-Do 3d 46? - 6/4/2007 6:07 AM
gregziemba
Score: 100
Status: offline
thanks for the help so the pink thing goes i on the glow plug and the black thing is where the glow plug gets inserted into right. and i can use that on four strokes to right.
Hide Signatures
(in reply to rclement)
       Post #: 6006
RE: U-Can-Do 3d 46? - 6/4/2007 7:18 AM
Rocketman_
Score: 110
Last Login: 6/18/2013
Status: offline
This is the setup on my well used UCD 46. It once had a Sullivan fueler but this is more reliable.
Click for fullsize
NORTHEAST R/C MODEL CLUB
http://www.nrcmc.org/
Hide Signatures
       Post #: 6007
RE: U-Can-Do 3d 46? - 6/4/2007 7:55 AM
rclement
Score: 100
Status: offline
quote:
ORIGINAL: gregziemba
Yep! The pink end is heat shrink and a stout wire. You just squeeze the wired parts together and put it on the plug end. It's seems to be a very positive connection. Yeah, the black part is where you plug the glow ignitor into. The wires are long so I just cut off what I didn't need. Works great.
Hide Signatures
       Post #: 6008
RE: U-Can-Do 3d 46? - 6/4/2007 7:57 AM
rclement
Score: 100
Status: offline
quote:
ORIGINAL: Rocketman_
Rocketman, I like your set up!! Looks like good ideas.
Hide Signatures
(in reply to Rocketman_)
       Post #: 6009
RE: U-Can-Do 3d 46? - 6/4/2007 12:07 PM
rtn9105
Score: 100
Status: offline
Rocketman, I really like that setup. Where did you get the bulkhead fittings?
Hide Signatures
       Post #: 6010
RE: U-Can-Do 3d 46? - 6/4/2007 4:15 PM
Rocketman_
Score: 110
Status: offline
I buy those Fourmost bulkhead fittings at my local hobby shop but Tower also stocks them http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXG851&P=SM#tech .
They come two in a package, a yellow and a blue one (See picture, I've already used the blue one).
By the way, I back them up on the inner side of the cowl with a small thin (1 /32) piece of plywood. That may not be necessary but I didn't want to worry about the flexibility of the cowl.
Click for fullsize
Hide Signatures
       Post #: 6011
RE: U-Can-Do 3d 46? - 6/4/2007 6:11 PM
gregziemba
Score: 100
Status: offline
where does the feul come out when its done feuling up?
Hide Signatures
       Post #: 6012
RE: U-Can-Do 3d 46? - 6/4/2007 6:17 PM
Rocketman_
Score: 110
Status: offline
It comes out of the tank pressure line at the muffler.
Hide Signatures
       Post #: 6013
RE: U-Can-Do 3d 46? - 6/4/2007 6:30 PM
gregziemba
Score: 100
Status: offline
so one fuel line connects to one of the part and the other piece and the feul line thats out side of the coweling is were you fuel up and when your done the gas come out of the muffler right.
Hide Signatures
       Post #: 6014
RE: U-Can-Do 3d 46? - 6/4/2007 10:12 PM
Rocketman_
Score: 110
Status: offline
Yes it will come out of the muffler if you fail to disconnect the line from the muffler. It is intended that you disconnect the pressure line from the nipple on the muffler while you are filling the tank.
If your muffler is tucked away and is not easily accessible then you will have to provide another method of catching the overflow from the tank.
Hide Signatures
       Post #: 6015
RE: U-Can-Do 3d 46? - 6/7/2007 5:20 PM
gregziemba
Score: 100
Status: offline
Can i buy any remote glow plug starter because im going to use a fourstroke engine?THANKS for the help
Hide Signatures
       Post #: 6016
RE: U-Can-Do 3d 46? - 6/7/2007 8:04 PM
rclement
Score: 100
Status: offline
I've used a couple of different types and the previous ones that I used the connector on the glow plug would come off due to vibration. The Dubro one I'm currently using seems to holding on good.
Hide Signatures
       Post #: 6017
RE: U-Can-Do 3d 46? - 6/7/2007 10:24 PM
gregziemba
Score: 100
Status: offline
I can use that on fourstroke right.
Hide Signatures
       Post #: 6018
RE: U-Can-Do 3d 46? - 6/8/2007 4:07 AM
gregziemba
Score: 100
Status: offline
Im going to use a satio 100 what engine mount do you guys use? Thanks for the help
Hide Signatures
(in reply to maverick)
       Post #: 6019
RE: U-Can-Do 3d 46? - 6/8/2007 3:05 PM
zoott
Score: 100
Last Login: 4/4/2008
Status: offline
Hi all
I'm just starting to build my first do .... Can you reccomend what upgrades in hardware would be a good idea or any other build tips. Will you also reccomend where to buy the upgraded control horns , rods etc.
I have a saito 82 for this bird.
thanks
Hide Signatures
       Post #: 6020
RE: U-Can-Do 3d 46? - 6/8/2007 4:28 PM
rclement
Score: 100
Status: offline
Yep. That's what I'm using. It's a first for me on the Do and I like it. Very handy.
Hide Signatures
       Post #: 6021
RE: U-Can-Do 3d 46? - 6/8/2007 4:44 PM
patnjimtucker
Score: 100
Last Login: 7/10/2007
Status: offline
Hi Zoott. A small thing that I do when I am assembling any ARF. I find that installing the control horns on the elevator(s), ailerons, and rudder kinda difficult when they are installed in their respective places. Sometimes very difficult to get all 3 screws lined up. So what I do now is to install the control horns on the parts before I hinge them to the plane, and I use a small drill press that I have to make sure all the holes through the surfaces are straight and true.
I go over the Do with a sealing iron on the top and bottom of the wing to take any wrinkles in the skin out. This seems to take a little of the vibration out of the plane and it them makes a little less noise.
The 2 servos in the tail, and the 2 on the wing. Once they are installed I run a small bead of clear silicone around the perimeter of each servo. Helps to keep dirt and oil from penetrating into the interior of the plane, and keeps oil away from the wood frame. Oil will eventually soften the wood and make the screws holding the servos less secure.
I do not use the stock tail wheel. Allways use a Sullivan, which mounts on to the plane rather than the rudder. So if you get a hard landing (and you will) the plane takes the shock rather than the rudder and rudder hinges.
Hide Signatures
(in reply to zoott)
       Post #: 6022
RE: U-Can-Do 3d 46? - 6/9/2007 12:19 AM
rtn9105
Score: 100
Status: offline
gregziemba, I have the Saito 100 on my DO and I used the mount that came with the plane. One of the socket head bolts that hold the mount to the firewall needs to be changed to a phillips head bolt so the carb doesn't hit the bolt head.
zoott, you can to look through this thread to get all the info you need about how to do all the mods to the plane. Unless you can land this plane softer than most every other person who's ever flown it and do that every single time you put it in the air, you HAVE to reinforce the landing gear mount or you'll tear it out sooner or later. There are some real good pictures of how to do this very easy mod earlier in the thread. You'll want to beef up the push rods, the 2-56 rods flex way to much and you will get flutter if you use them. I've used 4-40 rods and carbon fiber rods and they both worked very well. I've broke the CA hinges on all the control surfaces so I'd suggest upgrading to something better than the CA hinges (I use Robart hinge points but that's just my preference). As for the tail wheel, it's your choice. I'm on my second DO, on my first one I used the stock tail wheel system and I did break the rudder CA hinges but after I put Robarts in the rudder I had no more damage. On my second DO I thought the same as patnjimtucker and used a Sullivan tail wheel which works great but instead of breaking the rudder hinges I've broke the tail wheel mount right off the plane, the bad part is that the mount broke off along with about an inch of wood off the bottom of the fuse so it's a toss up but if I had it to do over I think I'd use the stock system and stronger hinges.
Hide Signatures
(in reply to patnjimtucker)
       Post #: 6023
RE: U-Can-Do 3d 46? - 6/9/2007 1:19 AM
zoott
Score: 100
Status: offline
Thanks for the tips. I dont mean to be lazy I just dont have the time to page thru this one. I will try some searches though. Where is a good place to get the horns and cf rods?
Hide Signatures
       Post #: 6024
RE: U-Can-Do 3d 46? - 6/9/2007 3:01 AM
AKFireMedic
Score: 100
Last Login: 11/24/2010
Status: offline
Zoot, I'll be using the stock horns and using CF tube to sleeve the stock 2-56 rods. Others have done this with good success.
Da** it feels good to be a Pro Bro
Hide Signatures
(in reply to zoott)
       Post #: 6025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.828RCU1
