RE: U-Can-Do 3d 46?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: U-Can-Do 3d 46?
Page: <<   < prev  240 241 [242] 243 244 245 246 247 248 249   next >   >>
Login
RE: U-Can-Do 3d 46? - 6/9/2007 5:15 AM
dr_d_2k
Score: 100
Last Login: 4/9/2011
Status: offline
Got to Do it today after a month of 'no fly'. Feel much better now.
I changed to an APC 13x4w down from a 14x4w and the OS 70 Surpass II seems much happier. Climb out seemed the same, definitely not a rocket but OK. Throttle response is much better in hovers with the smaller prop. I haven't tached it yet. Maybe tomorrow.
Hide Signatures
(in reply to AKFireMedic)
       Post #: 6026
RE: U-Can-Do 3d 46? - 6/9/2007 5:16 AM
zoott
Score: 100
Last Login: 4/4/2008
Status: offline
Where is a good place to get the cf rods online?
Hide Signatures
(in reply to dr_d_2k)
       Post #: 6027
RE: U-Can-Do 3d 46? - 6/9/2007 7:40 AM
Barry Cazier
Score: 100
Last Login: 10/15/2012
Status: offline
Best place to get carbon fiber pushrod kits is from Central Hobbies.
Barry
Hide Signatures
(in reply to zoott)
       Post #: 6028
RE: U-Can-Do 3d 46? - 6/9/2007 8:30 AM
rtn9105
Score: 100
Last Login: 5/20/2013
Status: offline
I'm got my CF pushrods from Abell manufacturing; the metal ends go over the carbon rods to prevent them from splitting.
http://www.abellrc.com/abellrchome.html
Here are the ones from Central Hobbies
http://centralhobbies.com/control_linkage/pushrod.html
These are the Dubro adjustable control horns that I'm using.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEMF9&P=ML
Picture of the central hobbies rods on page 231 post #5751
Picture of some home built CF rods with 4-40 all thread ends on page 226 post #5643
Picture of the landing gear block mod on page 225 post #5620 and page 222 post #5547
Hide Signatures
(in reply to Barry Cazier)
       Post #: 6029
RE: U-Can-Do 3d 46? - 6/9/2007 5:39 PM
rclement
Score: 100
Last Login: 4/3/2012
Status: offline
Wow! Those rod ends from Abellrc look great. I like em'. I have been just making my own out of CF rods from the LHS and Tower. They probably don't look as good as some but work good and are cheaper to make. Here's some from Tower hobbies. CF rod The first pic is the ones from Abellrc.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by rclement -- 6/9/2007 5:41 PM >
_____________________________
The hardest part of this hobby?......waiting for the UPS truck.
Hide Signatures
(in reply to rtn9105)
       Post #: 6030
RE: U-Can-Do 3d 46? - 6/9/2007 6:09 PM
rtn9105
Score: 100
Status: offline
The Abell ends are pretty nice but spendy. I had picked a set up and then didn't end up doing the plane I bought them for so that's why I put them on my DO. I think your right, your home built rods work just as good and save a bunch of $. I'm planning to try to build a set myself for one of my profile planes using the method of aluminum tubing to keep the CF from splitting. What do you use to glue the all thread into the CF tube?
< Message edited by rtn9105 -- 6/9/2007 6:11 PM >
Hide Signatures
(in reply to rclement)
       Post #: 6031
RE: U-Can-Do 3d 46? - 6/9/2007 11:02 PM
rclement
Score: 100
Status: offline
quote:
ORIGINAL: rtn9105
I use JB Weld. I assemble them and turn the oven on the low setting. (170) Then I bake them about 15 mins and it dries the JB Weld.
Hide Signatures
       Post #: 6032
RE: U-Can-Do 3d 46? - 6/9/2007 11:52 PM
rtn9105
Score: 100
Status: offline
JBWeld is what is used to assemble the Abell rods also and I like the idea of putting them in the oven to dry the JBWeld but I don't think there's anyway to do it with the Abell rods. The air that gets trapped inside the rod after you put the JBWeld and ends on always tries to push the ends back apart so you have to use some tape to hold everything together while the glue dries so I don't think you could put them in the oven. But I'll give it a try on the homemade set I build.
Hide Signatures
       Post #: 6033
RE: U-Can-Do 3d 46? - 6/14/2007 6:43 AM
gregziemba
Score: 100
Last Login: 5/7/2013
Status: offline
I was woundering if you guys upgraded to a bigger fuel tank. Im going to be putting a saito 100 so i dont think the stock one will be big enough. I couldnt even get the stock one in with out taking out wood. oh yah what would you guys say for flight time on the stock fuel tank.
Hide Signatures
       Post #: 6034
RE: U-Can-Do 3d 46? - 6/14/2007 8:57 AM
Barry Cazier
Score: 100
Status: offline
I use the stock tank in all my 46s. I use the 82 engine. I can get 13 minute flight times with an ounce or two to spare. You don't want to fly around looking for a place to land. Buzzer goes off at 13 minutes and you land.
I'm not sure the 100 uses any more fuel because you're always only using the bottom end of the power band. I think most are using the stock tank. You'll want to make sure you fully lean down the bottom end on the 100. They come very VERY rich. After a modest break in you can lean it down a lot. That will help greatly with the fuel mileage.
Barry
Hide Signatures
(in reply to gregziemba)
       Post #: 6035
RE: U-Can-Do 3d 46? - 6/14/2007 4:29 PM
rclement
Score: 100
Status: offline
I think Barry has some good points about the fuel usage with the 100. You may find that the 100 doesn't use too much since it has more power and your throttle settings will be lower. I'm planning to change my tank. ( I just broke my fuse and need to transfer everything to the new one) Here's a Sullivan tank that I have found to fit in the fuse. I'm still working with it though and don't have it installed yet. I'll let you know. Sullivan tank The second one is supposed to fit too but I haven't tried it. tank 2
Hide Signatures
       Post #: 6036
RE: U-Can-Do 3d 46? - 6/15/2007 12:34 AM
gjeffers
Score: 100
Last Login: 10/31/2012
Status: offline
quote:
ORIGINAL: gregziemba
Greg, Barry and Rob are both right, i use the stock tank in mine with the 100 and i fly 10 min and still have a half tank left but you have to have the 100 tuned right or it will never last long enough. lean down the low end
Gary- club saito#23
its your thang....do what ya wanna do
Hide Signatures
       Post #: 6037
RE: U-Can-Do 3d 46? - 6/15/2007 2:56 AM
gregziemba
Score: 100
Status: offline
what do you mean will not last long? the flight time or the engine
Hide Signatures
(in reply to gjeffers)
       Post #: 6038
RE: U-Can-Do 3d 46? - 6/15/2007 4:42 AM
gjeffers
Score: 100
Status: offline
well if its too rich the flight time will not last long if its too rich your engine will last forever(but not much fun )
Gary- club saito#23
Hide Signatures
       Post #: 6039
RE: U-Can-Do 3d 46? - 7/10/2007 4:34 PM
rclement
Score: 100
Status: offline
anyone still flying their Do? It's aweful quiet around here.
Hide Signatures
       Post #: 6040
RE: U-Can-Do 3d 46? - 7/10/2007 4:36 PM
gregziemba
Score: 100
Status: offline
i am i love mine!!!
Hide Signatures
       Post #: 6041
RE: U-Can-Do 3d 46? - 7/10/2007 8:15 PM
rclement
Score: 100
Status: offline
I just started using 25% nitro in my Do just yesterday. I've had some (25%) that I got at a real decent price a while back and just now got around to using it. WoW! I like it. It's definately a noticable difference. I'm going to use it all the time now.
Hide Signatures
       Post #: 6042
RE: U-Can-Do 3d 46? - 8/19/2007 12:33 AM
AKFireMedic
Score: 100
Last Login: 11/24/2010
Status: offline
What is everyone ending up with for a CG on this plane? I have read everything from 4.5 to 6.5 inches? Mine will have the Saito .82 up front. I want to go back but just not so far that the tail whips around like a flag in the air! Thanks all.
JAY
Da** it feels good to be a Pro Bro
Hide Signatures
(in reply to Toni Arte)
       Post #: 6043
RE: U-Can-Do 3d 46? - 8/19/2007 2:03 AM
Barry Cazier
Score: 100
Status: offline
I fly my 46 at 5 3/4" for the CG. I like it there and it's still very easy to control. My 60 I take all the way to 6". Still easy to fly there and yet makes it 3D better.
Barry
Hide Signatures
       Post #: 6044
RE: U-Can-Do 3d 46? - 8/19/2007 2:32 PM
AKFireMedic
Score: 100
Status: offline
Thanks Barry! I am actually putting this thing together now after having it and all of the parts for the better part of a year! So far so good. I was a bit disappointed to find that one side of my fuse was crushed and I spent the morning peeling the covering back, fixing it, and patching it when I wanted to be assembling the plane! Oh well, it beats sending it back to Great Planes and waiting weeks for a new one to get back to me. I also noticed that the wing hold down and the firewall gussets need some more epoxy to be stuck as good as I would like them to be. I'm hoping to have this thing in the air Monday evening. We'll see.
Hide Signatures
       Post #: 6045
RE: U-Can-Do 3d 46? - 8/19/2007 4:59 PM
rclement
Score: 100
Status: offline
Mine had a crushed leading edge when it came from Tower. I didn't want to wait to get a new one so I just fixed it myself too. You'll have lots of fun with it when you finally get to fly it.
Hide Signatures
       Post #: 6046
RE: U-Can-Do 3d 46? - 8/20/2007 6:24 AM
gjeffers
Score: 100
Status: offline
Hi guys, man have i been busy with the new job and moving (again ) bought a house here so i guess ill be stayiny here for a while
found a guy here in round mtn that wanted to learn to fly so i sold my 46 to him and am taking him out tomorrow to teach him to fly , hope all turns out well, he saw me fly it and had to have it so now ill have to fly one of my other four for awhile. another guy i work with that came up from Az flys also so i now have some fellow pilots to fly with at least
will try to do a better job keeping up with the thread now that things are settling down a bit.
i like my cg between 5.25 and 5.5in....this plane flys well just about anywhere
Gary- club saito#23
Hide Signatures
       Post #: 6047
RE: U-Can-Do 3d 46? - 8/20/2007 9:06 AM
fiveoboy01
Score: 100
Last Login: 1/1/2009
Status: offline
Well, it's been over THREE years since I first picked up my UCD at the LHS.
After over 140 logged flights, a couple dorks and one moderately serious crash, I took the Saito out and let it sit in the corner.
I'm thinking about putting her into action again, and I can't believe how many pages this thread has gone. Good to see the airplane is alive and well in the R/C world
Bill Ryan
AMA #805853
Hide Signatures
       Post #: 6048
RE: U-Can-Do 3d 46? - 8/20/2007 2:37 PM
AKFireMedic
Score: 100
Status: offline
Got a little closer today. The plywood wing hold down plate broke when I put the wing on to check how level the horizontal stab was. I was going to re-enforce it anyway but I got to do it sooner than planned. Every thing else seems OK so far but I am far from impressed with the overall quality of the construction. I am having to put more glue on almost every joint I can find. They look like they were tacked together with a dab of hot glue each and left to rest. I'm confident the plane will fly so well that I'll forget about how much trouble the build has been.
Hide Signatures
(in reply to fiveoboy01)
       Post #: 6049
RE: U-Can-Do 3d 46? - 8/20/2007 6:08 PM
raideron
Score: 100
Last Login: 6/16/2009
Status: offline
Hi again guys.... It's been awhile....
Been busy trying to make ends meet and flying a bit less... The "Do" is still doing great!!
when I do get out to the field...
Any of you "Pros" use wood props on your 82?? was thinking of switching from the APC
13X4W to wood but did not want to buy an assortment of them.. :-) Not sure if it was the
lack of use, but the 82 seemed a bit lag-ish on spool-up on hangers.. She started right up
and ran great for the 5 or so flights...
AKFireMedic... It is unfortunate when you get a model like that, but it will happen...
And Yes she will make you forget your initial problems... She is a fun plane....
**** Vigilant!!! **** The Word and Action of our times!
:( What... Out of fuel Again :(
Hide Signatures
       Post #: 6050
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.500RCU1
