RE: U-Can-Do 3d 46?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: U-Can-Do 3d 46?
Page: <<   < prev  241 242 [243] 244 245 246 247 248 249 250   next >   >>
Login
RE: U-Can-Do 3d 46? - 8/21/2007 2:25 AM
AKFireMedic
Score: 100
Last Login: 11/24/2010
Status: offline
I'm having a hard time with the engine mounting. With my .82 and the stock engine mounts, I have to move it all the way to the very tips if the engine mounts to get the 5" recommended clearence from the firewall to the back of the spinner back plate. I'm thinking I'll just move the engine back 1/4" so that I can have a bit more meat at the end of the engine mounts where the screws come through. I know this will shift my CG back a little and I'll have to mount the cowl back a bit more but otherwise it shouldn't cause any issues right?
_____________________________
Da** it feels good to be a Pro Bro
Hide Signatures
(in reply to raideron)
       Post #: 6051
RE: U-Can-Do 3d 46? - 8/21/2007 6:20 AM
fiveoboy01
Score: 100
Last Login: 1/1/2009
Status: offline
It shouldn't hurt, you do have some room to play with the cowl mounting, but not a lot due to the taper of the cowl.
Worst case scenario you can't use a spinner. I never ever had one one mine, but with the .91 if I remember correctly, I did get the recommended measurement and had enough room on the mount.
Bill Ryan
AMA #805853
Hide Signatures
(in reply to AKFireMedic)
       Post #: 6052
RE: U-Can-Do 3d 46? - 8/21/2007 7:25 AM
raideron
Score: 100
Last Login: 6/16/2009
Status: offline
AKFireMedic,
There is no problem with the engine tabs mounted at the very end of the engine mount..
Mine is that way and the "Do" has many many many flights with no problems to
the engine mount... With the engine mounted as far forward(S-82) it will also help
with your CG, that tail is really long back there, and if you can help it you do not
want to add weight...
**** Vigilant!!! **** The Word and Action of our times!
:( What... Out of fuel Again :(
Hide Signatures
       Post #: 6053
RE: U-Can-Do 3d 46? - 8/21/2007 7:34 AM
mnrcaerobat
Score: 100
Last Login: 4/27/2013
Status: offline
My U Can is still new in the box. I am getting closer to building mine. I am going electric. I am looking at using the 42-60-600 GP Rimfire and two 11.1 5000 mah packs in series.
Does the tail need flying wires?
Brian
Hide Signatures
       Post #: 6054
RE: U-Can-Do 3d 46? - 8/21/2007 8:49 AM
fiveoboy01
Score: 100
Status: offline
I have flying wires on mine. Sullivan makes a nice kit that you can use. It has kevlar string or steel wire. I used the kevlar.
At the very least you should add tri-stock at the stab/fuse junction above and below the stab.
Bill Ryan
AMA #805853
Hide Signatures
(in reply to mnrcaerobat)
       Post #: 6055
RE: U-Can-Do 3d 46? - 8/21/2007 4:26 PM
rclement
Score: 100
Last Login: 4/3/2012
Status: offline
quote:
ORIGINAL: raideron
AKFireMedic,
Yeah, that's how mine is mounted. (Saito 82) Right at the very end of the engine mount. It works fine that way.
Another thing is, you don't have to use those little blocks that glue onto the firewall, and are used to screw the cowl into. I leave them off and drill and tap into the fuse side just aft of the firewall. There is some tri stock in there that works fine for that.
The hardest part of this hobby?......waiting for the UPS truck.
Hide Signatures
       Post #: 6056
RE: U-Can-Do 3d 46? - 8/21/2007 6:49 PM
raideron
Score: 100
Status: offline
Brian.. Tail wires are not needed.. Just be sure that you trim ONLY the covering
Not the bulsa and you should have no problems.. Now/when I trim the covering
from the stab, I lightly cut down the center of my marks then peel back the
covering just shy of my marks, fold over and using just the blade laying flat I
trim it off.. If my center cut did make it to the bulsa.. no problem cause it'll
be covered with epoxy...
Hide Signatures
       Post #: 6057
RE: U-Can-Do 3d 46? - 8/21/2007 8:05 PM
rclement
Score: 100
Status: offline
Yeah, I'm on my 4th Do and never used tail wires on them.
Hide Signatures
       Post #: 6058
RE: U-Can-Do 3d 46? - 8/22/2007 9:11 AM
AKFireMedic
Score: 100
Status: offline
Thanks guys. I'll just mount it at the end of the mount then. I knew about leaving the cowl blocks off and was planing on that already. With the .82 are you guys having to add much weight anywhere to get the plane to balance?
Hide Signatures
(in reply to rclement)
       Post #: 6059
RE: U-Can-Do 3d 46? - 8/22/2007 4:30 PM
rclement
Score: 100
Status: offline
I haven't ever added any extra weight. I can't remember at the moment where the CG is but it has a pretty wide margin for the CG anyway.
Hide Signatures
       Post #: 6060
RE: U-Can-Do 3d 46? - 8/23/2007 9:37 AM
Barry Cazier
Score: 100
Last Login: 10/15/2012
Status: offline
I've had to cut a hatch in the tail section to mount the battery but haven't added extra weight at all. Mine balances at 5 3/4". Flys great and still easy to land.
Barry
Hide Signatures
       Post #: 6061
RE: U-Can-Do 3d 46? - 8/23/2007 12:44 PM
Toni Arte
Score: 100
Last Login: 3/11/2010
Status: offline
I've got a 5-cell 2100mAh NiMH battery in the space which was intended for the throttle servo in the instructions, and I moved the servo a bit forward. This gives a nice back CG with Saito FA-82a.
I finally got a tachometer yesterday, and as an end result I was able to lean out the engine quite a bit. It now swings the APC 14x4W at 10200rpm, max. was ~10400. Reliable idle at 2100rpm, and it could probably go lower.
The funny thing is that I just got a new motor for my shockflyer (3DFoamy Tiburon), AXI 2208/34, APC 9x3.8 Slow Fly, 3s 700mAh battery. Now this thing really rocks, I wish I had Saito 100 on my U-Can-Do... The U-Can-Do really doesn't pull out from hover that strongly now that I can compare it to a powerful shockflyer.
Hide Signatures
(in reply to Barry Cazier)
       Post #: 6062
RE: U-Can-Do 3d 46? - 8/26/2007 5:31 PM
rclement
Score: 100
Status: offline
Warning - Shredded U Can Do....... While at the field yesterday one of the guys was flying his 46 Do and ripping around in the air, most of the time at full speed, and was diving down pretty fast when his Do just exploded! Never seen anything like it! From what I could tell the tail came off and then the wing ripped off. There were pieces scattered about 100 feet. I told him it looked like the Shuttle disaster. When we went out to pick it up we found that every control surface had blown off. The tail was completely stripped off the plane and the only the left side of the wing was left on and the left aileron had blown off. Never seen such a mess. He asked what could have happened and I told him he was flying it too fast. Anyway, living proof that these planes are not made for speed.
Hide Signatures
(in reply to Toni Arte)
       Post #: 6063
RE: U-Can-Do 3d 46? - 8/26/2007 7:35 PM
Barry Cazier
Score: 100
Status: offline
rclement,
It happens. I think I've seen that warning at least a thousand times yet people continue to fly this plane at speed. Such a shame really. It is such a great slow flying plane. No need to fly it fast. Low, slow, show. That's my motto.
Gary does those great slow/low inverted passes...the infamous inverted flat spin landings...hover with tail touching...rolling circles...landing at walking speed with 5' roll out...tight flipping waterfalls...that's the stuff the "Do" is about.
This is one of the most fun planes I've ever flown. As I've moved on I still love the UCDs, regardless of what else I fly. I keep coming back to them because of what attracted me to them in the first place...fun factor and ease of flight.
Good hearing from you again...
Barry
Hide Signatures
       Post #: 6064
RE: U-Can-Do 3d 46? - 8/26/2007 8:32 PM
rclement
Score: 100
Status: offline
Thanks Barry. You're a good man. My Do is out of commision at the time but only because I've taken the engine out for another plane. I'm going to get it going again soon though. Have you seen the H 9 Frenzy that's coming out? Looks like a Do in some respects and is bigger than a 46 and smaller than a 60.
Hide Signatures
       Post #: 6065
RE: U-Can-Do 3d 46? - 8/26/2007 10:59 PM
AKFireMedic
Score: 100
Status: offline
I finally have my do just about together. I'm hoping to finish the last few things up today and get it maidened this evening. I'll snap a few pics when I get the chance.
Hide Signatures
       Post #: 6066
RE: U-Can-Do 3d 46? - 8/27/2007 5:09 AM
Barry Cazier
Score: 100
Status: offline
quote:
ORIGINAL: rclement
I haven't really looked at the Frenzy. I'll go to their website and take a look. Maybe it'll be worth trying. Do you have one? What engine?
AKFireMedic...
Good luck with your maiden. I hope you have good jaw muscles. You'll be smiling so much it'll make your jaws hurt.
Barry
Hide Signatures
       Post #: 6067
RE: U-Can-Do 3d 46? - 8/27/2007 6:48 AM
rclement
Score: 100
Status: offline
quote:
ORIGINAL: Barry Cazier
quote:
ORIGINAL: rclement
Barry
No, They're not out yet. They should be available next month. I would probably put a Saito 125 on it though.
Hide Signatures
       Post #: 6068
RE: U-Can-Do 3d 46? - 8/29/2007 12:54 PM
AKFireMedic
Score: 100
Status: offline
Well, I finally maidened the do today after more than a year of having all of the parts for it. I would like to say it was flawless but it wasn't quite. The do came home in one piece after two separate attempts today to get her flying well and 3 total flights. The first time it was a bit too windy and I believe the plane was a bit tail heavy as well even though it was set at about 5.75". I had a scary few laps and was almost out of control a few times before getting her on the ground again. The second time the wind was clam and the cg set forward quite a bit but we were having radio hit issues at the field! My buddies Mayhem was also getting hit on a different channel than me so I don't believe that my plane has a problem. Our field is in an industrial area and there is no telling what type of interference is present. A few people have had problems in the past but never like this. So, in retrospect I think the first flights in the wind were seeming worse than they really were since the plane was glitching then as well I just wasn't able to tell at the time. OK, now for the questions:
I have a JR receiver, hitec analog servos, and a 5 cell, 2000mah hydrimax flight battery. With the plane turned on the servos seem to jitter just a bit. Almost hunt for center it seems? I have heard that it is possible for the 6v battery to do that? Anyone have any ideas? Maybe a small regulator?
I am running an Expert brand servo reversing Y for the elevator servos. It seems to need to be adjusted to equalize the elevator halves without an reason? It isn't much..but enough to make the plane spin a bit as it climbs vertical. Any ideas on this one?
The last question I have is I was wondering if anyone has ever had radio interference problems while accelerating with their 4 stroke, or more specifically their Saito. The plane was having other radio hit type problems but it seemed to almost make the tail servos glitch when throttling up to make another landing attempt. I have no metal to metal parts as far as I know except the gears in the rudder servo and the parts in the Saito.
I'm going to give it another shot tomorrow after flying one of my other planes that I know works just fine at the field to see if the radio problems are at the site or with the two planes we had there today. Here are a couple of pics in the mean time. Thanks for the help!
Hide Signatures
       Post #: 6069
RE: U-Can-Do 3d 46? - 8/29/2007 2:23 PM
AKFireMedic
Score: 100
Status: offline
I almost forgot to ask: Is most everyone running the suggested high and low rates on their planes? And if so, what percentage of expo is everyone running. I know the expo is a personal preference type thing but I was just curious. Thanks again
Hide Signatures
       Post #: 6070
RE: U-Can-Do 3d 46? - 8/30/2007 12:24 PM
AKFireMedic
Score: 100
Status: offline
I flew again today and although the radio hit/ glitching didn't seem as bad it was still present. I'm going to try to fly at a different field on Friday and see if that eliminates the issue. I'll keep everyone updated.
Hide Signatures
       Post #: 6071
RE: U-Can-Do 3d 46? - 9/1/2007 9:45 AM
Bladejunkie
Score: 105
Last Login: 5/26/2013
Status: offline
Hey All I am just about done with my UCD 46 and I'm thinking of putting a Saito FA-65 in it.Any thoughts?I have a FA-82 but I don't want to pull it out of another plane the 65 has never even been out of the box.
Thanks Jim Club Saito #509
Hide Signatures
       Post #: 6072
RE: U-Can-Do 3d 46? - 9/1/2007 10:31 AM
Barry Cazier
Score: 100
Status: offline
Bladejunkie...
The Saito 65 won't be anywhere near enough engine. The 82 is very good...but just barely. Many are going with a Saito 100 for example. The UCD needs a good engine to make it come alive...
Barry
Hide Signatures
(in reply to Bladejunkie)
       Post #: 6073
RE: U-Can-Do 3d 46? - 9/1/2007 12:57 PM
AKFireMedic
Score: 100
Status: offline
I still have a bad radio glitch, hit issue that I can't seem to cure. I re-routed my antenna inside an antenna tube to see if that helps. For whatever reason I can't duplicate the issue on the ground, only once the plane is in the air...and my shorts are wet from wondering if I'll get her down in one piece again! Very frustrating...
Hide Signatures
       Post #: 6074
RE: U-Can-Do 3d 46? - 9/1/2007 2:51 PM
Barry Cazier
Score: 100
Status: offline
Try running your antenna along the the underside of the left wing. Just tape it temporarily to the underside. See if that helps. I've heard of one or two that had glitch problems that this cured.
Good luck.
Barry
Hide Signatures
       Post #: 6075
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.391RCU1
