RE: Seagull Spacewalker II 120 Arf    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Seagull Spacewalker II 120 Arf
Page: <<   < prev  7 8 9 10 11 12 13 14 [15] 16   next >   >>
Login
RE: Seagull Spacewalker II 120 Arf - 8/13/2012 8:58 PM
dan v
Score: 100
Last Login: 12/29/2012
Status: offline
How did you do the muffler, did you use the stock one? Just starting a walker and I have a DLE 20cc for it.
Also thinking about using  the anti-vibe mount. Please send pictures
Thanks Dan
Hide Signatures
(in reply to rowdyjoe)
       Post #: 351
RE: Seagull Spacewalker II 120 Arf - 8/13/2012 9:01 PM
dan v
Score: 100
Status: offline
how did you do the muffler? Thanks please send picts
Hide Signatures
(in reply to skypup50)
       Post #: 352
RE: Seagull Spacewalker II 120 Arf - 8/13/2012 9:31 PM
phakur
Score: 100
Last Login: 5/25/2013
Status: offline
Sorry no pics but used dle 20 with std muffler with a 3 inch extension on exhaust. I also used the Dubro mount it works fine
Larry
Hide Signatures
(in reply to dan v)
       Post #: 353
RE: Seagull Spacewalker II 120 Arf - 8/29/2012 12:18 PM
alan0899
Score: 100
Last Login: 5/12/2013
Status: offline
G'day All,
Can anyone tell me what size spinner comes with the Spacewalker 11 120 Arf.
I'm using a Saito 125 in mine.
But I can't start putting it together until I get my shed built, in about 3 weeks.
Cheers
Al.
_____________________________
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee,
Allan.
Hide Signatures
(in reply to phakur)
       Post #: 354
RE: Seagull Spacewalker II 120 Arf - 8/29/2012 4:01 PM
skypup50
Score: 100
Last Login: 12/13/2012
Status: offline
quote:
ORIGINAL: alan0899
G'day All,
Cheers
Al.
I just received a TruTurn 2.75" ( TT-2752-B-120) to use on my new saito FG-21 fourstroke. It is designed with slots large enough for 120 sized blades. There is a red 2.75" red plastic spinner included in the kit. Making my starter run on my 18 volt electric drill battery did wonders for turning over the engine (test stand) but the plastic is kind of soft with the kit spinner and it got marked up by my starter's rubber insert which is kind of old so I ordered the aluminum spinner. If you go the TruTurn route be sure to order the correct adapter at the same time.
Hide Signatures
(in reply to alan0899)
       Post #: 355
RE: Seagull Spacewalker II 120 Arf - 8/29/2012 11:52 PM
alan0899
Score: 100
Status: offline
Thanks SkyPup
I have a Truturn 3" alloy spinner, I think I will have to get the box out, & compare the 3" with the cowl, & see If it looks OK.
Unfortunately it is packed away in the carport waiting for my shed.
And I will need a different adaptor anyway, as you said, The 3" was originally used on an OS 160FX.
Cheers
Allan.
Hide Signatures
       Post #: 356
RE: Seagull Spacewalker II 120 Arf - 8/30/2012 1:48 AM
skypup50
Score: 100
Status: offline
I think the 3" will look ok.
Hide Signatures
       Post #: 357
RE: Seagull Spacewalker II 120 Arf - 8/30/2012 9:13 AM
alan0899
Score: 100
Status: offline
G'day All,
I ordered an adaptor to fit the Saito 125A, & also a new 2 3/4" 120 size spinner.
What the hell, it's only money.
Allan.
Hide Signatures
       Post #: 358
RE: Seagull Spacewalker II 120 Arf - 8/30/2012 12:21 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: alan0899
G'day All,
I ordered an adaptor to fit the Saito 125A, & also a new 2 3/4'' 120 size spinner.
If you want to spend more get an rc specialties turboheader muffler and adapter. I just got mine and it will really clean up the engine installation under the cowl. They sound cool too.
http://www.rcspecialties.net/products.php
http://www.youtube.com/watch?v=UwUCal3teOA
Hide Signatures
       Post #: 359
RE: Seagull Spacewalker II 120 Arf - 10/10/2012 12:45 AM
ADFEDELE
Score: 100
Last Login: 3/21/2013
Status: offline
HI have you flown your spacewalker 120 with the del20 and did it fly well or was it underpowered? i'm thinking of using an RCFG20 in mine but I'm not sure if if it will fly well. I also have a dle30 which I think would be too much power. Any suggestions will be appreciated.
thanks
Alex
Hide Signatures
(in reply to bgee)
       Post #: 360
RE: Seagull Spacewalker II 120 Arf - 10/10/2012 12:50 AM
ADFEDELE
Score: 100
Status: offline
So how did your spacewalker fly with the DLE20. I'm thinking of using an RCFG20 that I have waiting for a plane. Any recommendations?
thanks
Hide Signatures
       Post #: 361
RE: Seagull Spacewalker II 120 Arf - 10/10/2012 3:40 AM
phakur
Score: 100
Status: offline
Well. To each his own. This plane is not a rocket ship. More like an easy Sunday flyer. A 20 did just fine
Hide Signatures
(in reply to ADFEDELE)
       Post #: 362
RE: Seagull Spacewalker II 120 Arf - 10/10/2012 10:19 AM
dan v
Score: 100
Status: offline
I'm using a DLE 20 with anti-vibe mount. Put those cheap .062 rods aside and put in some 440 rods if you want real control.
Used 14.5 oz tank mounted near cg and runs for almost 30 min.
Used 6 JR 47BB sport servos with 2000mah nmh battery for both reciever&ign.
Hide Signatures
       Post #: 363
RE: Seagull Spacewalker II 120 Arf - 10/11/2012 3:58 PM
ADFEDELE
Score: 100
Status: offline
I thank you for your response. It sounds like a match. I think I'll enjoy a good sunday flyer.
Hide Signatures
       Post #: 364
RE: Seagull Spacewalker II 120 Arf - 10/11/2012 4:00 PM
ADFEDELE
Score: 100
Status: offline
Dan v thanks for your response too. I agree with the upgrades. Sometime we tend to forget how cheap push roods can be and create more of a problem then it's worth. I'll keep you guys informed as I progress after I receive the plane.
Hide Signatures
(in reply to dan v)
       Post #: 365
RE: Seagull Spacewalker II 120 Arf - 11/25/2012 12:57 AM
oneaew@msn.com
Score: 122
Status: online
i have one the carb and muffller stick out some what with a z 20 gasser
Hide Signatures
(in reply to Iflyglow)
       Post #: 366
RE: Seagull Spacewalker II 120 Arf - 11/26/2012 11:44 AM
bikerbc
Score: 116
Status: offline
I am flying my Walker with the DLE20 and For me it has plenty of power...The DLE20 is a little power house..The only thing I am finding is it dosent idol down rite away...when you chop the throttle it takes a few seconds so you need to set up early for landing..From what I understand this is an ignition unit issue ..If I change Ignition units that problem will go away....Also like all walboros the top half of the throttle dosent do much .. The bottom half has most of the throttle transition .. I am guessing that I could set this up with my radio if I took some time to figure out how to do it....As far as power goes for me it has plenty...Walkers aren't ment too be wildly aerobatic planes , rather than plesant sunday flyers...I would say my DLE was equal too roughly a OS 120AX, It might have a little more power...
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
(in reply to oneaew@msn.com)
       Post #: 367
RE: Seagull Spacewalker II 120 Arf - 11/26/2012 3:23 PM
dan v
Score: 100
Status: offline
WE JUST GOT THE CARB SET ON MY DLE 20cc) THE OTHER DAY>MINE WOULDN"T IDLE DOWN EITHER> I WAS about a 1/4 turn TOO RICH ON THE LOW SIDE> HERE IS WHERE WE HAVE IT SET NOW>>>>LOW SIDE IS JUST UNDER ONE TURN< HIGH SIDE IS JUST OVER ONE TURN>I think I maybe be a little lean on the high side because I'm only turning 8,500 rpm, should be at least at 9, 500
I have the stock ignition and it's just fine. I use a little expo in the throttle setting for a smooth throttle transition, and it's great.
Dan
Hide Signatures
(in reply to bikerbc)
       Post #: 368
RE: Seagull Spacewalker II 120 Arf - 11/28/2012 11:21 AM
bikerbc
Score: 116
Status: offline
Thanks Dan I am going to try that , sombody else told me that too but we are into our pre winter rainy weather so it may need to wait till spring...
Hide Signatures
(in reply to dan v)
       Post #: 369
RE: Seagull Spacewalker II 120 Arf - 12/29/2012 3:31 PM
EF
Score: 100
Status: offline
Has anyone fitted a Robart 1/4 scale Cub landing gear to this model?
Looks much more scale than the supplied one and probably the shock absorbing capability is nice to have.
Erez
Hide Signatures
       Post #: 370
RE: Seagull Spacewalker II 120 Arf - 12/29/2012 6:55 PM
dan v
Score: 100
Status: offline
No need to do this, I land on a pretty rough feld with no problem. Re-support landing gear plate
like someelese has done in these posts. use tri stock above plate and re-support front underside of fuse just like in the other post.
Hide Signatures
(in reply to EF)
       Post #: 371
RE: Seagull Spacewalker II 120 Arf - 2/4/2013 3:52 AM
AA5BY
Score: 153
Status: offline
I messed up. I've been on the negative side of the Seagull Spacewalker II 120 and now have to confess it seems it was my own doing. I built the plane more than a year ago and after several outings concluded I didn't like it. My reason was primarily that it wanted to roll constantly. Admittedly, I never got a chance to fly it in anything but strong winds. Then, I couldn't get it out of a flat spin and it went down, tearing up the wings but hardly scratching the fueslage.
A decision was made to give that away. A few months went by and I'd not stripped motor and electronics from it yet, and I decided to order the wings before they might no longer be available as someone might be interested in the complete plane. It has set now for months and a winter project of upgrading the fleet to LiFe batteries and given that the Spacewalker was otherwise flight ready, I decided to upgrade it as well and maybe give it a second look.
After upgrading the batteries, like the other planes before it, it got a CG check to verify the CG hadn't gone bad. The three LiFe batteries (two flight and one ignition) were located in the same spots as the two NiCad and one NiMh that was removed and I didn't expect the CG to have changed much.
On the CG machine, I couldn't grasp that the plane required four additional ounces at the tail to balance. There was all ready 3/4 oz stuck to the tail wheel bracket that confirmed that the plane had been balanced but evidently it must have been wrongly done or the new wings were grossly lighter than the originals. I've never had to add that much tail weight before. The engine is a Zenoah G-26 ei.
I flew the plane today in fairly light air conditions and it flew very nicely... nothing of the ill manners I'd remembered. Previously it wanted continually to roll right or left. It was loath to come out of a spin and wouldn't come out of a flat spin. Today, it had no problems quickly coming out of a spin after neutralizing controls. I'm now convinced that it had been wrongly balanced very nose heavy. How it could have happened, I don't know unless I somehow thought 11 cm was 11mm though it is hard to fathom I'd think that small amount would be the CG point.
What I think happened was that I set 11 mm on my CG machine without mentally observing how close it was to the axle of the machine (CG point) and that placing the plane inverted on the machine of course covered up the relationship of the forward stop (that positions the wing leading edge) and the axle (CG point when plane balanced).
At any rate, I repent of the bad things I've said about the Seagull Spacewalker. When properly balanced it flies well.
Hide Signatures
(in reply to dan v)
       Post #: 372
RE: Seagull Spacewalker II 120 Arf - 2/4/2013 4:17 AM
bikerbc
Score: 116
Status: offline
I am glad you sorted that out...I am on my second walker...I dorked my first one...They fly beautfully
Hide Signatures
(in reply to AA5BY)
       Post #: 373
RE: Seagull Spacewalker II 120 Arf - 2/11/2013 8:01 AM
ripacheco
Score: 100
Last Login: 5/22/2013
Status: offline
Tried looked for the kit on the seagull web site and it is no longer listed
Hide Signatures
       Post #: 374
RE: Seagull Spacewalker II 120 Arf - 2/11/2013 10:46 AM
AA5BY
Score: 153
Status: offline
Horizon shows it to be in stock.
< Message edited by AA5BY -- 2/11/2013 10:59 PM >
Hide Signatures
(in reply to ripacheco)
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
