RE: Seagull Spacewalker II 120 Arf    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Seagull Spacewalker II 120 Arf
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Seagull Spacewalker II 120 Arf - 9/27/2011 5:45 PM
fastflyfish
Score: 100
Last Login: 3/20/2013
Status: offline
Nevermind.
Randy
< Message edited by fastflyfish -- 10/2/2011 9:56 PM >
Hide Signatures
(in reply to rowdyjoe)
       Post #: 176
RE: Seagull Spacewalker II 120 Arf - 11/1/2011 1:41 PM
phakur
Score: 100
Last Login: 5/25/2013
Status: offline
Has anyone used a DLE 20 with this plane? I am concerned about sufficient power as it seems most folks have used at least a 26 cc engine.
Trying to choose between a Pulse 125 which is lighter by a couple of pounds and the Spacewalker 2.
Thanks-
Larry
Hide Signatures
(in reply to fastflyfish)
       Post #: 177
RE: Seagull Spacewalker II 120 Arf - 11/1/2011 7:15 PM
rowdyjoe
Score: 105
Last Login: 5/21/2013
Status: offline
Take a look one page back at the post by "bikerbc". He's currently flying a SP II with a 20cc engine.
The Spacewalker II and Pulse are intended for different purposes. The Pulse is more agile. So, it depends on what you want to do with an airplane. I have a Spacewalker II on my building bench right now that's about 7/8 finished and I've installed a 26cc gas engine on it.
There's a fellow in our club who is currently flying a SP II with a 26cc and he loves it. It appears to have plenty of power.
If you want more power and speed, go with the Pulse. If you want a nice, relaxing, weekend flyer go with the Spacewalker.
RJ
< Message edited by rowdyjoe -- 11/2/2011 8:50 PM >
_____________________________
Rowdyjoe
Saito 783
Hide Signatures
(in reply to phakur)
       Post #: 178
RE: Seagull Spacewalker II 120 Arf - 11/1/2011 7:34 PM
rowdyjoe
Score: 105
Status: offline
Oh yeah. I owe you guys an update on my build progress. I decided to use the standoffs as I found them reasonably priced at TBM. Each end is threaded to accept 5mm bolts and it's quite sturdy. As I stated above, I'm very near completion ...finally. My build was interrupted when I bought a used Wild Hare Giles 202 and began flying it. I've spent most of my time flying that and hardly any time building but, I've managed to work on the SP in the last week. I need to make a final cut in the cowl for the ignition lead to the full sized spark plug, I need to install the tail wheel and elevator flying wires. And that's about it other than neatly arranging the wiring in the electronics bay. I've installed a dual battery regulator by Smart Fly and will use two 2100mah LIPO receiver batteries and a AR7000 receiver w/remote. I'll post pictures when she's done.
Thanks for all the advice and help.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 179
RE: Seagull Spacewalker II 120 Arf - 11/2/2011 9:10 AM
BlackPhantomDragon
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: phakur
Thanks-
Larry
Hi Larry
I am going to put a DLE-20 in my Seagull PT-19 2mrtre span. From what I have read the DLE-20 has as much or more power than a Satio 125 and lighter than most 26cc gas and also more power out put as well. Through in that it can be beam mounted like a normal engine and I can't see (imo) what else you would want. You can then also use a smaller tank and place it anywhere you want. I am putting a 10cc tank in mine.
Hope this helps Greg
[/color]
Hide Signatures
       Post #: 180
RE: Seagull Spacewalker II 120 Arf - 11/3/2011 2:15 AM
SigMan
Score: 110
Last Login: 5/6/2013
Status: offline
i want the SW 120 with a DLE 30 for Christmas. please Santa ! lol !
Club Saito Member #1
AMA# 542304
Hide Signatures
(in reply to BlackPhantomDragon)
       Post #: 181
RE: Seagull Spacewalker II 120 Arf - 11/18/2011 4:37 AM
rowdyjoe
Score: 105
Status: offline
The only thing holding up first flight of my SP II is where to mount the choke servo. I think I've decided to mount it in the fuel tank compartment fixed to the back side of the firewall. I plan to use a high torque mini servo since it will only be on for a a minute or two when starting the engine.
I still need to cut the cowling to make room for the spark plug lead. Everything else is ready and I need to get off my duff and "get 'er done".
RJ
Rowdyjoe
Saito 783
Hide Signatures
(in reply to SigMan)
       Post #: 182
RE: Seagull Spacewalker II 120 Arf - 11/18/2011 1:26 PM
AA5BY
Score: 153
Status: offline
RJ... does your choke have a hole in it? If so, did you opt to solder it closed?
Fine business on being close to finished and wishing you a great maiden flight.
Hide Signatures
       Post #: 183
RE: Seagull Spacewalker II 120 Arf - 11/18/2011 8:16 PM
rowdyjoe
Score: 105
Status: offline
Yes, the choke flap has a hole in it but, never thought of soldering it closed.  With the cowing off, I've been holding my thumb over the hole while I flip the prop to get the carb wet.  That's a good idea though.  I wonder if JB weld would work OK.  It would save removing the butterfly for soldering.
I have to admit that I'm a little nervous about flying this one.  It looks so great ... I'm afraid I'll ding it up.
RJ
Rowdyjoe
Saito 783
Hide Signatures
(in reply to AA5BY)
       Post #: 184
RE: Seagull Spacewalker II 120 Arf - 11/18/2011 9:10 PM
AA5BY
Score: 153
Status: offline
RJ... I soldered one a week ago without having to take the choke off as the butterfly section stood proud enough to use a wire brush in a dremel and clean it up both sides and solder it. Was very easy though it required pulling the engine from the firewall.
I did it after the frustration of getting the thing running otherwise... either that or mount a tube toward the intake to inject a prime. The advantage of closing the hole is that it provides a backup engine kill as my engine wouldn't kill under choke when the hole existed.
I'd think solder would be far superior to JB weld as the latter might get ingested.
As a side note... yesterday was a really fine day at our local field here in East Texas.... I'm due East of you about 140 miles. Any afternoon like that will be very suitable for a Space Walker as they are reported to be docile fliers. I've a Seagull AT-6 that is a **** cat to fly, though a little more challenging to land than the Space Walker should be. I do have the Space Walker... but its in the box yet.
Hide Signatures
       Post #: 185
RE: Seagull Spacewalker II 120 Arf - 11/18/2011 9:45 PM
rowdyjoe
Score: 105
Status: offline
I haven't had any problem killing the engine with the choke but, I have installed a commercial "kill switch" in-line with the CDI lead and it works very well when programmed to one of the spare funciion switches on my DX7.
I haven't tried starting it without choking it but, the choke servo should eliminate the issue.  If I have trouble getting it primed, I'll try soldering the hole.
You're right about the JB weld.  Hadn't thought of that one either.  That would be a dead-stick waiting to happen considering the vibration we get from the gassers.
BTW ....my engine is a 26cc GR Pro and I'm currently turning a 17X8 RCGF prop (from BP Hobbies on-line).  I'm told it's an SV engine (whatever that its) but, I got it at a good price ....less than $100 new including the after-market CDI I bought for it.  It's running nice a strong and should pull the SP II very well.  I hope it proves to be durable.  So far, it seems to be reliable when running on the ground.  It's not broken in yet though.  I have run less than a gallon of fuel through it and it's ready to fly.  It will have to finish break-in while in the air.
Speaking of props ....I also like the Zinger Pro series.  I have a 22X10 on my 50cc Giles 202 currently and it performs nicely with plenty of speed and pull ...and I can get them for a decent price at my LHS.
I've missed a few good flying days lately due to other commitments.  I tried flying Wed. but, the north winds picked up in the afternoon and became gusty.  Not much of a problem when airborne but, landings get dicey in gusts above 20mph ...even if down the runway.  The terrain off the south end of our paved runway rolls a little and it causes the wind to do strange things.  If you get too low on approach things can get very interesting.  High approach with plenty of speed is the key but, she floats in ground effect and will use a lot of runway to slow down.
Take care and keep us posted on your build.
RJ
(N5GLR)
Rowdyjoe
Saito 783
Hide Signatures
(in reply to AA5BY)
       Post #: 186
RE: Seagull Spacewalker II 120 Arf - 11/19/2011 11:49 PM
rowdyjoe
Score: 105
Status: offline
Went to the field to fly today but, the wind was terrible.  White caps all over the lake was a warning to stay on the ground.  I've flown my 50cc bird with a few white caps showing but, the lake reminded me of the Galveston shoreline today.
Oh well, there's always tomorrow.
We did have a couple of intrepid souls launch their smaller glow powered birds and almost didn't get them back once they flew down wind.  It was a real struggle to get them back to the runway.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 187
RE: Seagull Spacewalker II 120 Arf - 11/28/2011 12:22 AM
rowdyjoe
Score: 105
Status: offline
Well, she's finished ...except for CG adjustments (if needed).  I'll post pictures as soon as I get the wings on her.
We'll find out tomorrow how well she flies on the 26cc gas engine and 17X8 wooden prop.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 188
RE: Seagull Spacewalker II 120 Arf - 11/29/2011 11:44 PM
rowdyjoe
Score: 105
Status: offline
FINALLY !
She's all balanced and ready for flight tomorrow (Wed.  11/30).  Here's the pictures I promised ...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 189
RE: Seagull Spacewalker II 120 Arf - 11/29/2011 11:54 PM
SigMan
Score: 110
Status: offline
NICE !
AMA# 542304
Hide Signatures
       Post #: 190
RE: Seagull Spacewalker II 120 Arf - 12/1/2011 1:52 AM
rowdyjoe
Score: 105
Status: offline
We had a beautiful day for first flight of my new SP II but, couldn't get the engine to run reliably.  Don't know what the problem was yet but, I think it's carb adjustment.  Had to choke the devil out it to get it to pop and had success getting it started a couple of times but, it ran very rough and wouldn't accept any throttle changes at all.  We know we had spark (we tested for it) so, it has to be air/fuel mixture (I think).  I'll know more when I get a chance to trouble shoot.
The weather looks good tomorrow but, doubt I'll have it running any better by then.  I'm shooting for a good day next week as I want to run it "on the bench" to make sure she's going to run and stay running when I get to the field.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 191
RE: Seagull Spacewalker II 120 Arf - 12/1/2011 3:01 AM
SigMan
Score: 110
Status: offline
keep us posted Rowdy !
AMA# 542304
Hide Signatures
       Post #: 192
RE: Seagull Spacewalker II 120 Arf - 12/2/2011 8:47 PM
rowdyjoe
Score: 105
Status: offline
Update:
I pulled the cowl and set all carb adjustments to factory settings (1 1/2 turns out each).  Got it to pop and run a little but, ended up re-routing all fuel lines ...which helped a lot.  Must have had something plugged in wrong hole (duh).  It runs now after many adjustments to tune the carb.  However, I'm not happy with it as it took too many turns at the high end to get it to peak.  It idles but, will slowly die if I let it.  I think it needs a new carb or a rebuild (even though it's a new engine).  I think this one set on the shelf too long before being put to use ....or it was junk to start with.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 193
RE: Seagull Spacewalker II 120 Arf - 12/2/2011 10:32 PM
Kostas1
Score: 330
Last Login: 5/24/2013
Status: offline
RJ,
do you have a video of the test-run;
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
       Post #: 194
RE: Seagull Spacewalker II 120 Arf - 12/3/2011 6:06 AM
rowdyjoe
Score: 105
Status: offline
No.  Didn't even think about it.
RJ
Rowdyjoe
Saito 783
Hide Signatures
(in reply to Kostas1)
       Post #: 195
RE: Seagull Spacewalker II 120 Arf - 12/4/2011 9:53 AM
Bund34
Score: 100
Last Login: 2/5/2012
Status: offline
Hi. Spacewalker 1500mm  Wingspan plan drawing, in any format? Thanks for help. email: berc@citromail.hu
< Message edited by Bund34 -- 12/4/2011 12:05 PM >
Hide Signatures
(in reply to codedlanguage)
       Post #: 196
RE: Seagull Spacewalker II 120 Arf - 12/6/2011 6:19 AM
rowdyjoe
Score: 105
Status: offline
On advice from a fella who works on 2 stroke gas engines for a living, I've tightened every bolt, nut, and screw on the carb hoping to eliminate what is suspected to be an air leak.  I haven't had a chance to run the engine to see if it had any affect but, if it didn't, the next step is a rebuild or replacement.  Replacement would be easier and probably cheaper in the long run I think.
RJ
Rowdyjoe
Saito 783
Hide Signatures
(in reply to Bund34)
       Post #: 197
RE: Seagull Spacewalker II 120 Arf - 12/9/2011 9:19 PM
phakur
Score: 100
Status: offline
Guys-Have a couple build questions:
Using a gas engine:
Is there room for a double toggle switch with fuel dot or is the fuse set up for two slide switches only?
Do you think Hitec 645MG servos all around are OK?
Thanks-
Larry
Hide Signatures
       Post #: 198
RE: Seagull Spacewalker II 120 Arf - 12/9/2011 9:30 PM
rowdyjoe
Score: 105
Status: offline
I think there's plenty of room on either side of the fuselage for your fuel dot/switch system.
The 645MGs are a bit short on torque for this size bird.  Take a look at these ....http://www.bphobbies.com/view.asp?id=D3925412&pid=F3403885
More torque, cheaper, and reliable.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 199
RE: Seagull Spacewalker II 120 Arf - 12/9/2011 10:27 PM
rowdyjoe
Score: 105
Status: offline
Engine trouble update:
Finally got around to running the engine yesterday after tightening everything.  After a bit of adjustment it's running well but, it won't drop back to idle after going to full throttle for about 30 secs.  When I pull the throttle back to idle, the rpm will not come down below 3300 rpm.  If I blip the throttle a couple of times the rpm will drop down to around 1800 to 2000.  I can't find anything binding or sticking so, I'm assuming the carb has a problem.
The adjustments aren't right either although, it's running OK.  I've opened the "high" end needle more than 1 full turn (rich) to get it to peak and closed the "low" end needle (lean) almost 1 full turn to eliminate most of the 4 stroking.  The transition is fine.  If it weren't for the idle problem I'd fly it like this but, half throttle landings are not good.
Looks like I'll be installing a new carb.  I don't think a rebuild is the solution.
RJ
Rowdyjoe
Saito 783
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
