RE: Boomerang Nano!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Boomerang Nano!!!
Page: <<   < prev  49 50 51 52 53 54 55 [56] 57 58   next >   >>
Login
RE: Boomerang Nano!!! - 10/14/2012 3:11 AM
raptor30se
Score: 100
Last Login: 5/18/2013
Status: offline
Anybody have stock gear that they'd be willing to part with. I'd like another set stock rear gear for the Nano. PM me if you have and willing to sell them.
I'm looking for the wood blocks and top cover plate for the wire legs that come with the kit.
Thx
< Message edited by raptor30se -- 11/5/2012 2:44 PM >
Hide Signatures
(in reply to kev-o)
       Post #: 1376
RE: Boomerang Nano!!! - 11/8/2012 6:10 AM
BORLEX
Score: 100
Last Login: 5/19/2013
Status: offline
I have a spare K-80F and a budget for Boomerang Nano, or ... FALCON 120, but unfortunately not a SPRINT. Has anyone managed to convert a Nano for K-80?
I have a hope since people fit with succes P-80 http://www.boomerangjets.com/images/p80.pdf. Maybe some trimming and glassing will do the work...
Hide Signatures
(in reply to raptor30se)
       Post #: 1377
RE: Boomerang Nano!!! - 11/8/2012 11:38 AM
Xairflyer
Score: 105
Status: offline
Agree with Bill, the nano is a wren44/P60 aeroplane the perfect model for you is Falcon 120/navycat/tornado fantastic flyer, easy to land and looks fast, unquestionable best all-round jet on a budget.
_____________________________
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to BillJohnson)
       Post #: 1378
RE: Boomerang Nano!!! - 11/8/2012 1:25 PM
raptor30se
Score: 100
Status: offline
I fly mine with a VT-80 and it fly's awesome, VT80 is lighter than the K80 though, closer to weight of the P60. Just pull it back on the down lines. Make's for spirited take offs.
Hide Signatures
(in reply to Xairflyer)
       Post #: 1379
RE: Boomerang Nano!!! - 11/8/2012 3:29 PM
BORLEX
Score: 100
Status: offline
Thank you all for your replies!
K-80F
Diameter: 95.25mm ( 3-3/4" )
Length: 254mm ( 10" ) - including starter
Weight: 1304g ( 2 lb. 14oz. ) - including starter
P60-SE
Diameter: 83mm
Total length: 245mm
Weight: 845g including launch control
Size of P-60 that is extensively used in Nano, as we see in this thread, is similar to K-80. Wheight is different, the K-80 being almost 500gr heavier, same as P-80. CG might be an issue but I could move all batteries and UAT forward and use the fixed gear to save weight.
What mostly concerns me is K-80 mount size that seems to be much wider than the jetcat one
Can somebody provide me the dimensions A, B and C in the following picture
Xairflyer, which would you consider best as a lead in trainer for scale jets. Nano or Falcon 120?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1380
RE: Boomerang Nano!!! - 11/8/2012 4:30 PM
BaldEagel
Score: 118
Status: online
I have never seen a P80 in a Nano, I would have thought it was to wide.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to BORLEX)
       Post #: 1381
RE: Boomerang Nano!!! - 11/8/2012 4:46 PM
Chris kerby
Score: 100
Status: offline
Not sure on the size of a P80 but I had a wren 54 in mine 90 mm casing and I had to take a fair bit of the engine bearers.
Great little plane with the wren wish I had kept it.
Hide Signatures
(in reply to BaldEagel)
       Post #: 1382
RE: Boomerang Nano!!! - 11/8/2012 5:56 PM
BaldEagel
Score: 118
Status: online
Don't shoot the messenger, but if memory serves the P80 is 112mm the same size as a P120.
Mike
Hide Signatures
(in reply to Chris kerby)
       Post #: 1383
RE: Boomerang Nano!!! - 11/8/2012 6:31 PM
Xairflyer
Score: 105
Status: offline
You even have to mod the bearers of a Elan to make a P80 fit, way too big for a Nano.
Nano P60 is a great combo and it flys really well as do all Boomerangs, but to answer Borlex question I would go with the Falcon 120 it will give you more in regard to what you asked as it will fly fast if you want but also teach you about flying around the circuit slow.
www.jmaireland.com
Hide Signatures
       Post #: 1384
RE: Boomerang Nano!!! - 11/8/2012 8:27 PM
BORLEX
Score: 100
Status: offline
BaldEagel You are correct, thats why I had a hope, but K-80 mount seems to be veeeery wide.
Xairflyer I will study the Falcon 120 build again, my basic concern there is structure strength, but since others do it with success I 'll try too and fly it in a more conservative manner (I should do the same with a Nano/K-80 combination anyway).
Thank you all again
PS If anybody has done though please show us, just to know ...
Hide Signatures
       Post #: 1385
RE: Boomerang Nano!!! - 11/8/2012 9:27 PM
littlepiston
Score: 105
Status: online
I have the falcon 120 with a jc rabbit and a nano with a wren SS, they both fly great thought its been a wile, I'm dusting them off as I type.
Hide Signatures
       Post #: 1386
RE: Boomerang Nano!!! - 11/9/2012 11:49 AM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: BORLEX
The Falcon 120/navycat/tornados all require work to make them suitable, but easily done and loads of information on the Falcon 120 thread.
www.jmaireland.com
Hide Signatures
       Post #: 1387
RE: Boomerang Nano!!! - 11/9/2012 6:13 PM
GIOMBO
Score: 100
Status: offline
hi guys........... my Nano with P60 haven't any ballast in font......... 6kg dry and jettech 79oz fuel tank............ it flies great and handling special.
Hide Signatures
       Post #: 1388
RE: Boomerang Nano!!! - 11/9/2012 7:37 PM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
If you put the bigger motor in the nano, beef up the wing mount a little with a dowel, and some tristock at the glue points.. Use Hysol.. its back in the thread here on my yellow one..
A "bigblock" size P80/120, wren120....etc will not fit.. you need a "smallblock" motor ( Wren SS/100/Mk3, P70/60..etc)..
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to GIOMBO)
       Post #: 1389
RE: Boomerang Nano!!! - 11/10/2012 5:34 PM
Terry Holston
Score: 100
Status: online
I flew my "Smallblock" Wren (15Lbs) powered Nano again Wed. Since the weather was warm and not too windy, to use up the rest of my fuel. Almost 8 min and still had 1/2 a tank of fuel left. Great flying combo.
It is the one "Goose" is talking about.
Terry Holston,I Fly Jets
I''''m NOT speeding, I''''m QUALIFYING
Hide Signatures
(in reply to gooseF22)
       Post #: 1390
RE: Boomerang Nano!!! - 11/10/2012 8:33 PM
gooseF22
Score: 103
Status: offline
raptor, I found the wire struts.. see pm
Goose
Hide Signatures
(in reply to Terry Holston)
       Post #: 1391
RE: Boomerang Nano!!! - 11/10/2012 8:35 PM
gooseF22
Score: 103
Status: offline
Why did I sell it? dunno...Terry has 100+ on it since..
Goose
Hide Signatures
       Post #: 1392
RE: Boomerang Nano!!! - 11/26/2012 1:50 AM
nxconvict
Score: 100
Last Login: 4/29/2013
Status: offline
Anything wrong with using Hitec's HS-5645MG all the way around with the expection of the nose gear?
< Message edited by nxconvict -- 11/26/2012 9:46 AM >
Hide Signatures
(in reply to kev-o)
       Post #: 1393
RE: Boomerang Nano!!! - 12/26/2012 6:15 AM
ira d
Score: 123
Status: online
quote:
ORIGINAL: BORLEX
The link you listed is for the intro and it's larger than the Nano closer to the Sprint in size, There no way you will get a P80 in a Nano and I doubt you will get
K80 in one either.
Ira d
Hide Signatures
       Post #: 1394
RE: Boomerang Nano!!! - 2/20/2013 10:16 PM
jet junkie
Score: 100
Last Login: 5/13/2013
Status: offline
My Home made Struts!
just finnished the nose strut ....will be setting the spring tension once fitted
have some light weight ali wheels the same design as the plastic ones in the mail ...
I have a couple of home built cnc machines in my shed so have lots of fun making stuff just waiting for my Nano in the mail as we speak Have a P60SE for it and make a lot of stuff..
here is my baby bommerang that I gave to a friend in Perth Australia as a gift...
I love these Planes!
nice thread guys lots of usefull information and will be useing as much as possible
cheers
Haydn
here is a vid of the travel
http://youtu.be/bJwI6Wja3MI
< Message edited by jet junkie -- 2/21/2013 5:48 PM >
Hide Signatures
(in reply to ira d)
       Post #: 1395
RE: Boomerang Nano!!! - 2/25/2013 5:13 PM
jet junkie
Score: 100
Status: offline
Its on the way
yeeehaaaa!
with P60SE in the box as well!
NICE!
Hide Signatures
(in reply to jet junkie)
       Post #: 1396
RE: Boomerang Nano!!! - 2/25/2013 6:35 PM
Dave Bugz
Score: 100
Last Login: 5/17/2013
Status: offline
Well done Jet Junkie i also got a P60 in mine and it flies great. As you are in Reading do you fly at Classic Jets Abingdon?
Hide Signatures
       Post #: 1397
RE: Boomerang Nano!!! - 2/25/2013 7:41 PM
jet junkie
Score: 100
Status: offline
G-day
thanx..
I dont have a Jet club yet ....I flly my planes and Helis here..
http://maidenheadradiomodellers.yolasite.com/gallery-2013.php
wher do you fly?
cheers
haydn
Hide Signatures
(in reply to Dave Bugz)
       Post #: 1398
RE: Boomerang Nano!!! - 2/27/2013 6:46 PM
jet junkie
Score: 100
Status: offline
Now with Ali Rims and single down arm with dual rims....
Hide Signatures
       Post #: 1399
RE: Boomerang Nano!!! - 2/27/2013 8:16 PM
siclick33
Score: 125
Status: offline
Is it just a grainy photo or are they sponge tyres?
I would swap them for something a little more heavy duty if it was me.
It was all going really well, then I suddenly ran out of talent!
Hide Signatures
       Post #: 1400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
