lipo's in paralell?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> lipo's in paralell?
Page: [1]
Login
lipo's in paralell? - 12/5/2008 4:32 AM
thestratcat
Score: 100
Last Login: 11/6/2010
Status: offline
ok, I'm a heli guy, and very electrically impaired.
with that said, I got an e-flite pitts bi-plane that requires an 11.1 4200mah lipo pack to power it... my question is, can I wire the packs I have that are 11.1 volt, 2100 mah in paralell to get the power I need? if I can, how do I do it?
thanks....
_____________________________
"If guns cause crime, all of mine are defective" ~ Ted Nugent.
Hide Signatures
       Post #: 1
RE: lipo's in paralell? - 12/5/2008 7:30 PM
Rodney
Score: 169
Last Login: 5/22/2013
Status: offline
Yes, works very well.
Hide Signatures
(in reply to thestratcat)
       Post #: 2
RE: lipo's in paralell? - 12/5/2008 10:26 PM
Druss
Score: 126
Last Login: 2/22/2012
Status: offline
quote:
ORIGINAL: thestratcat
thanks....
You can either direct wire them to one connector or you can make/buy a parallel connector like the one in the pic.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3
RE: lipo's in paralell? - 12/5/2008 11:33 PM
BarracudaHockey
Score: 280
Status: offline
Batteries in series: Add the voltage, capacity remains the same.
EX: 2 10 volt, 1000mah batteries wired in series would result in a 20v (2s) 1000mah battery pack.
Batteries in parallel: Add capacity, voltage remains the same.
EX: 2 10v, 1000mah batteries in parallel would result in a 10v 2000mah battery pack.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to Druss)
       Post #: 4
RE: lipo's in paralell? - 12/6/2008 3:06 AM
thestratcat
Score: 100
Status: offline
ok, great!!! thanks....
now the question that crossed my mind, they also have a hotter setup for 3d which requires a 14.4 volt 2250mah pack....
if I'm going to have two three cell packs on board, couldn't I wire them in series giving me 22.2 volts and 2200mah from what i have now and then use a stepdown regulator to lower my voltage to 14.8 volts? maybe it would be a better setup?
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 5
RE: lipo's in paralell? - 12/6/2008 6:24 AM
BarracudaHockey
Score: 280
Status: offline
4 cells is 14v, regulating from 6s down to 4s is bleeding off a lot of voltage as heat. Seems inefficent to me.
www.JaxRC.com
Hide Signatures
       Post #: 6
RE: lipo's in paralell? - 12/6/2008 11:00 AM
thestratcat
Score: 100
Status: offline
'cuda..... thanks man...
thanks man.. thinking it through, if I was going to go to the added expense of dropping the voltage, I may as well buy a charger that will to 4 cells (both of mine only do 3 cells) and a battery.... I guess I'm just trying to play out options in my mind..
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
