Spektrum DX5e will not turn on with AFPD
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Spektrum DX5e will not turn on with AFPD
Page: [1]
Login
Spektrum DX5e will not turn on with AFPD - 12/7/2008 5:14 PM
hobdean
Score: 100
Last Login: 10/19/2009
Status: offline
My Spektrum DX5e will not turn on when connected to AFPD and AFPD says it can't find the controller/radio. I have the newest adaptor for JR/Spektrum (AFP 02). New batteries and the radio does come on when I turn on the power switch. The adaptor works great with my 9303.
Please Help
Hide Signatures
       Post #: 1
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 12:13 AM
rajul
Score: 100
Last Login: 11/8/2009
Status: offline
Hi hobdean, please post a photo of the usb interface cable you have. Did you push the connectors fully in, between the radio and adapter, and between the adapter and the usb interface? Did you disable the trainer mode in the radio? Thanks
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
(in reply to hobdean)
       Post #: 2
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 1:24 AM
hobdean
Score: 100
Status: offline
All cables are connected good. I switched between 9303 and the DX5e and the 9303 works fine but, not the DX5e. What mono connector are you talking about? If you read my request, I have the latest connection for JR/Spekrum.
Maybe the trainer port is broke? DX5e is a new radio from Horizon.
Hide Signatures
(in reply to rajul)
       Post #: 3
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 1:55 AM
rajul
Score: 100
Status: offline
Hi hobdean, I need to see a photo or description of the type of usb interface that you have, the usb cable that plugs into your computer. This will help me narrow down the possibilities. Thanks
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 4
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 3:15 AM
hobdean
Score: 100
Status: offline
here you go
thanks
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to rajul)
       Post #: 5
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 3:28 AM
rajul
Score: 100
Status: offline
Thanks for the photo. You have the right adapter. It could be the mechanical tolerances of the trainer socket in this new JR radio is different causing a contact problem. Try plugging in the usb cable directly into your radio, without the adapter. Do you get an intermittent connection with AFPD?
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 6
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 4:52 AM
hobdean
Score: 100
Status: offline
there is an intermittent connection without the adaptor but, it never stays on long enough. I can't find my regular JR buddy box cable to see if it works. Is the adaptor the same size as the JR buddy box cable? I do appreciate any help you can give me
Thank you
< Message edited by hobdean -- 12/8/2008 4:59 AM >
Hide Signatures
(in reply to rajul)
       Post #: 7
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 5:00 AM
rajul
Score: 100
Status: offline
Can you do soldering work? I can suggest some modification to the stereo plug at the end of the usb cable. This may work, but no guarantees
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 8
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 6:38 PM
hobdean
Score: 100
Status: offline
Sure I do some soldering. What do you suggest?
To ask the question again, I guess the adaptor plug is different than the regular JR buddy cord?
< Message edited by hobdean -- 12/8/2008 6:39 PM >
Hide Signatures
(in reply to rajul)
       Post #: 9
RE: Spektrum DX5e will not turn on with AFPD - 12/8/2008 11:21 PM
rajul
Score: 100
Status: offline
The buddy cord is wired differently. You can't use that. PM or email me your email address and I'll send you a diagram for soldering
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 10
RE: Spektrum DX5e will not turn on with AFPD - 12/9/2008 1:38 AM
hobdean
Score: 100
Status: offline
The sim adaptor seemed like it was too loose in the 5e. I know the adaptor and jr trainer cord are wired different but, are they the same size?
I sent you an email and a PM>
Hide Signatures
(in reply to rajul)
       Post #: 11
RE: Spektrum DX5e will not turn on with AFPD - 12/9/2008 1:56 AM
rajul
Score: 100
Status: offline
Hi hobdean, yes I received your email and I will prepare a diagram for you later. Jr is known to have inconsistencies with its socket tolerances, and can change from batch-to-batch, and radio-to-radio. The plug used is basically a mono 3.5mm.
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 12
RE: Spektrum DX5e will not turn on with AFPD - 5/27/2009 1:16 PM
sam@ata
Score: 100
Last Login: 11/6/2009
Status: offline
i just found this thread after PM you about this very same issue.  I didnt go back far enough!  My i request the same wiring diagram and my cable is the same as pictures in this thread.
Sam Woodard
AMA 51401
Hide Signatures
(in reply to rajul)
       Post #: 13
RE: Spektrum DX5e will not turn on with AFPD - 5/28/2009 12:31 PM
rajul
Score: 100
Status: offline
I need to check with hobdean if my suggestion worked
Mike Marks
RCU Moderator
Hide Signatures
(in reply to sam@ata)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU1
