Fuel pump on the fuel jug setup (electric or manual).
Tower Hobbies
Logged in as Guest
  Printable Version
Fei Bao 1/6 Scale F-9F Panther - ARF
Seller:  rcjetmodels
Details:   $1,800.00   |  8/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Fuel pump on the fuel jug setup (electric or manual).
Page: [1]
Login
Fuel pump on the fuel jug setup (electric or manual). - 6/1/2003 7:45:53 PM
ny_rc
Status: offline
Electric or manual. I saw some guys have fuel pump screwd on the jag (where the top goes). Some others have manual pump on the metal piece on the side. Unfortunately they don't know where to get them now.
Where I can get this setup or at least who makes it?
Thanks.
I'm fed up with remote electric pump. 3 of them (Magnum crap) got broken in a year.
       Post #: 1
Fuel pump on the fuel jug setup (electric or manual). - 6/1/2003 8:13:26 PM
Dsegal
Status: offline
I just hold my fuel pump in one hand and crank with the other hand. Works fine.
Dave Segal
(in reply to ny_rc)
       Post #: 2
Fuel pump on the fuel jug setup (electric or manual). - 6/2/2003 2:07:47 AM
ny_rc
Status: offline
This is one big pump !
How reliable is it ?
(in reply to ny_rc)
       Post #: 3
Fuel pump on the fuel jug setup (electric or manual). - 6/2/2003 4:51:11 PM
dant-RCU
Status: offline
Slimline Products makes both an electric pump that screws to the top of the fuel jug and a mechanical that also mounts to the top of the jug on the fuel cap.
I have used them both - both work just fine.
Here is their link:
http://www.slimlineproducts.com/
Dan
_____________________________
Dan Taylor
American Turf Flyers, Inc.
(in reply to ny_rc)
       Post #: 4
Fuel pump on the fuel jug setup (electric or manual). - 6/2/2003 6:06:56 PM
Dsegal
Status: offline
> How reliable is it ?<
The Six-Shooter is probably the most reliable pump on the market. It is just a crank that revolves pressing two plastic lobes along a piece of plastic tubing to force the fuel. But I hated its awkward mounting to the jug and the bumpy way it felt when cranking. I went for a smaller geared hand pump.
Dave Segal
(in reply to ny_rc)
       Post #: 5
Fuel Pump - 6/2/2003 7:59:41 PM
dickj
Status: offline
I have one each of the Slimline Electric Pumps that screw on the Plastic jug and one metal sealing cap that fit the plastic jug. I have used their electric for two years without any problems. I personnally like the cap and manual pump arrangement as there is no battery to lug around. Something you might want to consider: I purchased both types to fit the plastic jugs and then the fuel containers (Power Master) turned into metal gallon cans. I now have the wrong type and have to transfer the fuel to the old plastic jug. Slimline makes caps and pumps for the metal cans also. The wave of the future is metal due to EPA regs I am told. Their reliability is excellent. Here is the link for the two products, listed under Fuel Pumps. http://www.slimlineproducts.com/rc_plane_intro.htm
< Message edited by dickj -- Jun 2 2003 3:05PM >
Whatever goes up, doesn't necessarily come back in the same conditon.
(in reply to ny_rc)
       Post #: 6
Fuel pump on the fuel jug setup (electric or manual). - 6/2/2003 10:08:24 PM
ny_rc
Status: offline
Thanks dickj !
That is exactly i'm looking for!
(in reply to ny_rc)
       Post #: 7
Fuel pump on the fuel jug setup (electric or manual). - 6/3/2003 1:28:44 AM
Spaceclam
Status: offline
slimline makes the one you see on top, or baybe sullivan, i forgot. but i have had good luck with electric pumps. i guess some of them are crap, you get the smae one and it lasts longer than you do
Duct tape is like the force. It has a light side, a Dark side, and it holds the universe together.
(in reply to ny_rc)
       Post #: 8
Fuel pump on the fuel jug setup (electric or manual). - 6/3/2003 7:08:46 AM
david a
Status: offline
I use the Hanger 9 manual pump and I mounted it to the side of my flight box. Works fine. I have found that I get better service with less down time by keeping things simple.
(in reply to ny_rc)
       Post #: 9
Fuel pump on the fuel jug setup (electric or manual). - 6/3/2003 7:23:53 AM
Spaceclam
Status: offline
my pump is really fast. it is electric, a hobbico mk III. it has not yet even degraded in it's performance, but is almot 3 years old. considering that a cheap electric pump is about $2 more than a good manual one, it's worth the extra bucks
(in reply to ny_rc)
       Post #: 10
Fuel pump on the fuel jug setup (electric or manual). - 6/3/2003 8:27:09 AM
glowplug
Status: offline
I didn't have the same luck as SpaceClam with my Hobbico MK III electric pump. It lasted less than a year. I switched to a hand-held pump and hold it in my hand as Dsegal said.
Mike
(in reply to ny_rc)
       Post #: 11
Fuel pump on the fuel jug setup (electric or manual). - 6/4/2003 7:53:50 PM
Mustang Man-RCU
Status: offline
I use a Six Shooter and have for the last five years. I do more flying than the average guy due to being retired. I have used the small, geared, manual pumps in the past ( Hobbico, Hangar 9, etc.) but they don't last as long as the Six Shooter. As for electric pumps, most of the guys I see using them spend more time trying to get them to work than they spend pumping fuel with them. I have my Six Shooter mounted to the side of my flight box next to the fuel jug. Works great for me.
Steve
Take-off's are optional.....Landing's are mandatory.
(in reply to ny_rc)
       Post #: 12
Fuel pump on the fuel jug setup (electric or manual). - 6/4/2003 11:18:56 PM
scottrc
Status: offline
I had a manual pump but then it leaked. I now use a 12v windsheild washer pump motor that I bought at Wallmart for $9.
I went electric and will never go back to manual.
(in reply to ny_rc)
       Post #: 13
Fuel pump on the fuel jug setup (electric or manual). - 6/5/2003 7:25:48 PM
Mustang Man-RCU
Status: offline
Scottrc,
I've had 3 of those electric W/S washer pumps from WalMart and all packed it in after a month or two. I think the gears are plastic and get softened by the fuel but good luck with it.
Steve
(in reply to ny_rc)
       Post #: 14
Re: Fuel Pump - 6/5/2003 8:04:11 PM
visioneer_one
Status: offline
[QUOTE]Originally posted by dickj
I have one each of the Slimline Electric Pumps that screw on the Plastic jug and one metal sealing cap that fit the plastic jug. I have used their electric for two years without any problems. I personnally like the cap and manual pump arrangement as there is no battery to lug around. Something you might want to consider: I purchased both types to fit the plastic jugs and then the fuel containers (Power Master) turned into metal gallon cans. I now have the wrong type and have to transfer the fuel to the old plastic jug. Slimline makes caps and pumps for the metal cans also. The wave of the future is metal due to EPA regs I am told. Their reliability is excellent. Here is the link for the two products, listed under Fuel Pumps. http://www.slimlineproducts.com/rc_plane_intro.htm [/QUOTE]
I have a couple of Slimline's products. One of their Boxxer pumps mounted in my flight box, one of their aluminum fuel caps (also mounted in my flight box), and one of their M1 pump/cap combos.
The Boxxer is fairly new, and works fine. It does seem to have a low pumping rate, though... filling a 12 oz. tank seems to take over a minute even though I use a 14V battery in my box. (I need to time it.) My old manual Kavan pump was much faster.
I have one complaint with the M1. The Pump they supply has a plastic cranking handle which is attached to the plastic output shaft with a single screw through the center. This arrangement worked well for a while, until the handle started slipping on the shaft. I tried gluing the handle in place, shimming it with flat sheets of metal, etc. - no luck. I finally ended up drilling a pilot hole through the side of the handle & shaft and aded a single screw to lock them in place.
One other problem with the Slimline caps lies with the fuel nipples they supply. They corrode after being exposed to fuel and fail. The 'in' nipple on both the regular cap and the M1 cap have broken off inside the cap, and cannot be reteieved... I've switched the lines around and am still using the caps, but I expect them to fail at some point as well.
(in reply to ny_rc)
       Post #: 15
Fuel pump on the fuel jug setup (electric or manual). - 6/5/2003 10:00:38 PM
