Weatronic and Futaba MPDX    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Weatronic Support Forum >> Weatronic and Futaba MPDX
Page: [1]
Login
Weatronic and Futaba MPDX - 12/13/2008 5:00 AM
Edgar Perez
Score: 100
Last Login: 6/20/2013
Status: offline
Guys,
Wondering if anybody has used this combination with success?
I have this setup, since I'm running in PCM 1024. It does not work correctly. I have measured the pulse width of each MPDX channels and its all over the place! Tried with two different MPDX, so I guess weatronics does not pass the transmitted signal intact.
When I use a futaba receiver, it does work.
_____________________________
Edgar Perez
Puerto Rico
Hide Signatures
       Post #: 1
RE: Weatronic and Futaba MPDX - 12/13/2008 7:34 PM
morelli
Score: 100
Last Login: 12/21/2010
Status: offline
Hi Edgar,
we do not understand exactly what your problem is. Can you explain more precisely and give us an email under info@weatronic.com.
Best regards
weatronic GmbH
Managing Director
Rolf Alexander Westphal
Seidenstr. 57
D-70174 Stuttgart
www.weatronic.com
Tel: +49/711/253 9274
Fax: +49/711/870 30 994
Hide Signatures
(in reply to Edgar Perez)
       Post #: 2
RE: Weatronic and Futaba MPDX - 12/14/2008 2:10 PM
Edgar Perez
Score: 100
Status: offline
Dear Rolf.
Tried to send you an email. However it seems your inbox is full. Please see description of the problem below:
MPDX (http://www.futaba-rc.com/radioaccys/futm4158.html) is a decoder that connects to a futaba PPM, PCM or G3 receiver. It will take a single proportional channel from the receiver and "split it" into eight individual proportional channels. In order to use it, the transmitter must have the special software and be configured to use the =
MPDX. I currently uses a Futaba 12FG. I have two of those devices and can confirm they work fine with a standard Futaba receiver.
The problem that I have is that I wanted to use that device with my Weatronic. The Weatronic is setup in the Futaba PCM protocol. However when I connect the MPDX to one of the Weatronics channels, the MPDX does not work properly. Specifically, measuring the pulse width of each of the MPDX output I do not get the standard pulse width values (~900-2100). Note that with a standard futaba receiver, each MPDX output provides a signal to a servo in the same range as the standard pulse widths. This does not work with the Weatronic. It seems like the Weatronic changes the original signal from the Tx in such a way that confuses the MPDX. (My Weatronic socket is setup as a "Analogue" output, not "Digital". Have not tried with the setup as a "Digital" output)
Edgar Perez
Puerto Rico
Hide Signatures
(in reply to morelli)
       Post #: 3
RE: Weatronic and Futaba MPDX - 12/15/2008 2:49 PM
morelli
Score: 100
Status: offline
Hi Edgar,
100% sometimes is not 100 %. Choose in the weatronic RXctrl software servo configuration: - 118 % till -120 %, then "MPDX-1 Multi" works.
weatronic GmbH
Managing Director
Seidenstr. 57
D-70174 Stuttgart
www.weatronic.com
info@weatronic.com
Hide Signatures
       Post #: 4
RE: Weatronic and Futaba MPDX - 12/15/2008 11:13 PM
Edgar Perez
Score: 100
Status: offline
Hi Rolf,
Ok, will try it this coming weekend.
I understand to go to the RXctrl software and 'configure' the servo socket output with the straight, 45 degree line, but making sure the line extend to the max travel of 120%, right?
Edgar Perez
Puerto Rico
Hide Signatures
       Post #: 5
RE: Weatronic and Futaba MPDX - 2/26/2011 12:39 AM
Edgar Perez
Score: 100
Status: offline
Now I need to use the MPDX with a 2.4 Micro 12 channel RX. Tried adjusting the MPDX channel values int the Weatronics software, but it did not work (the values given in the above posts worked fine for the 72 MHZ version(
Ideas?
Edgar Perez
Puerto Rico
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.157RCU1
